Pressed the Rinse hold button (on the IFB Front-loading fully automatic Senoritsa Dx washing machine) - so that it was activated. After the washing cycle was over this automatically switched off and the Start light was flashing....was unable to open the door of the machine to take out the clothes, so pressed start button-the flashing stopped but then the clothes were spin-dried which I DID NOT WANT! Finally the clothes are out but are dry and creased! Wanted them to come out wet so that the clothes could drip dry and hence have NO CREASES.
FitzOriginal
  • 842 Answers
SOURCE: Servis Washing machine clothes wet
I don't know the specific machine, but this is a fairly generic problem, so I hope the following helps: The empty pump cycle is a timed operation, the fact that there is still water in the drum after the time allowed for the pump to drain it has run out means that the water isn't clearing out fast enough.
In order of probability, the problem is usually caused by:
1. A blocked filter
2. An obstruction in the empty pipe or drain
3. A Faulty pump
1 Blocked Filter: Many machines have a small door in the bottom of the chassis. Behind this door (Usually about 5 inches square) is a filter, which will usually unscrew. In this filter you will find fluff, string, coins, the odd small sock and all sorts of nasty stuff if you haven't had the filter out before. If the filter is blocked then the pump is having to draw water through all that gunk and it will run out of time and leave water in the drum. Clean the filter in the sink, pocket the coins you find and make a note to clean it regularly in the future Most manufactures will suggest you check it every 2 months or so, depends how often you are using the machine of course.
Unfortunately, other machines do not have filters so easily accessible. If there is no door or obvious access to the filter, some manufacturers put a trap in the rubber hose that feeds the pump. The pain here is that the access to these traps is gained by dragging the bachine out of its place under the work surface and tipping it on to its back. Track the waste pipe back to locate the pump. On the other side of the pump will be a thicker (usually black rubber) pipe and built into this pipe is usually a little bucket that stuff can fall into before it gets to the pump. You can usually squeeze the pipe and feel if there is stuff in it. If there is, then depending on the machine again, some of these traps will have a plug in the bottom that is held in place by a spring clip (Pliers to compress the spring to get it off) or a screw clip (Unscrew with a screwdriver). Enev if there is no trap as such, squeeze the rubber delivery pipe and feel for obstructions (Often a sock!), if necessary, disconnect the pipe from the pump to gain access to the blockage. WARNING!: Never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, to the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend butting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
2. An obstruction in the empty pipe or drain: Start at the point that the pipe enters the household drain pipe, pull out the empty pipe and check that water will flow freely into the drain (Stuffing the garden hose down there and turning it on (but not TOO FAST) will usually demonstrate if there is a blockage. If this is free, check the pipe that runs from the pump to the drain (This will need the machine tipping as described above, and possibly the pipe removing from the pump to check it.
3. A Faulty Pump:If you have done everything described so far, then you have checked for obstructions in the pipe leading to the pump, the pipe leading away and you have cleaned out any filters or traps... If you still have a problem, you have a faulty pump. This is highly unlikely. These pumps have induction motors (no brushes to fail) and in my experience, they either work, or they don't. They very seldom "work a bit". If SOME water is being pumped (check by putting the empty hose in the sink and watching) then you really need to double check your work before replacing the pump. Good news is, if you do have to they are usually reasonably priced.
Posted on Feb 09, 2009
  • 20 Answers
SOURCE: On and off light and energy save and reduces creases lights flash
Hi Snarey, it sound like your door lock has passed away, you will need to make sure the appliance is unpluged, empty the water out of the drum, and check the vacuum switch which opperates the lock.
Posted on Mar 10, 2009
plumber_man
SOURCE: Hotpoint WF340 wont drain
I have the HOTPOINT WF540 with the same problem ....So remove the front panel at the front of the machine and you will see the filter plug unscrew anti clockwise, you may find it difficult to unscrew as the filter may be blocked solid with coins ans long objects but once you have started it off wiggle it back and forth with some force till the objects dislodge you may be scared of breacking it but the worst you can do is snap of the plunger which is attached to the filter plug, behind the filter plug its self which will do no real harm and you can put it back in unattached to the filter plug with no worries when your done
you can also drain of the water out of the drum drum from this point but you will need a very slim try to fit under the front of the washer below the filter plug DO NOT totaly remove the plug if the is washing machine is full of water, just release the plug till water slowly trickles out and drain it a bit at a time or you will flood your floor
Posted on Jun 01, 2009
  • 86 Answers
SOURCE: Hotpoint Aquarious WF210. Machine stops mid
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Posted on Mar 06, 2010
  • 662 Answers
SOURCE: Hotpoint Aquarius not completing finally spin and pumping out
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The filter is inside the machine. Turn off the power and pull out the machine to get to the rear. Pull out the hose you see going into the wall pipe, lay at floor level or plastic bag to drain out remaining water in machine. Remove the panel at the bottom (2 screws) where the discharge hose comes out. You should see a black concertina type tube coming from below the drum attached by a jubilee clip. The filter is inside. Loosen the clip and pull away the tube, take out the filter and clean it. When you replace it don't forget to put the ball float back in (exactly as you found it) and check it’s well fixed by running a spin cycle before sealing up. Caution, the exit drain hose shd be fitted at the exact location where you found it, abt three feet up from ground level.
Pl rate me nice for the free help, thnks.
Posted on Jun 04, 2010
What to do when h1 is flashed in ifb automatic front load washing machine
Cannot find anything about H1, but error code E01 is door not closed properly. An instrument at work sometimes reads "h1" and this indicates a "high" reading, but don't know if that is really relevant here. Sorry I can't help any further. Good luck.
May 19, 2015 | IFB Washing Machines
In IFB front washingmechain AC h1 error is coming what to do
AC h1 is actually AC hi error which means input voltage is too high. Wait for sometime for voltage to stabilize Washing machine will automatically start. If not call electrician to check electrical fault for high voltage
Jul 03, 2014 | Kenmore Elite 45986 Front Load Washer
IFB washing machine front load Showing ' Lo' what
Error code LO normally means the filter is blocked. this would be the best place to start. refer to your owners manual for instructions on cleaning this.
Aug 10, 2013 | IFB Washing Machines
Burning smell along with fumes came out after a ghastly spin of the drier. after that it can't be switched on. Mine is a front loading washing machine (IFB executive plus).
Don't try to turn on again. Call a service agent for that brand of machine and leave it to them. Obviously a major problem and could cause major damage to your home if you force it on again
Jan 14, 2013 | IFB Washing Machines
Ckt diagram of supremo dx ifb front loading washing machine
idonot have the manual which has been actually lost i am new to this machine iwant to know the working of program knob
Nov 29, 2012 | Washing Machines
Ifb front pcb diagram
What is the model number of your unit?
Nov 01, 2012 | IFB Washing Machines
Ac voltage become hihg or low when start ifb washing machine
We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
Sep 30, 2012 | IFB Washing Machines
My ifb machine is around 10-12 years old. It is SUPREMO DX Fully Automatic Model. Presently it is not completing the washing program and gets jam in between. One technician of IFB has checked it around 15...
In general, the life of a washing machine is about 10-12 years. Depending upon how much your machine has been used, etc. It may be at the end of it's life.I would keep this in mind before putting very much money into repair. I would certainly contact the person who looked at your machine and inquire whether or not they have ordered parts for it and their schedule for repairing it. I would also ask for their estimate for the cost of repair. You can then make a decision based upon how much you paid for the machine, if it has had normal to heavy use, and how much the repairs are going to cost, before you have it repaired. You might have in mind how much you are willing to put into this machine before you call.
Good luck to you. Thank you for using FixYa.
Jan 07, 2011 | Washing Machines
Washing machine IFB,senorita model, PCB cost
Any one who buys IFB washing machine is made as fool both by the Company and by the Service Centers.
.. an idiotic owner of SENORITA DX, fully automatic from Pondicherry.
Aug 04, 2010 | Washing Machines
Washing Machines Logo
243 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
