Question about Kenmore Elite 45986 Front Load Washer
Thank you!! I no longer have a problem, and this looked like the only way to contact you. I had a problem with my washer showing the "DL" sybmol. While trying to fix it: I had the door open, and I caused the lock to snap down into the "locked" postion. The door was "locked" opened! The manual override pull tab thingy only worked if the door is closed since the action of pulling the tab with the hole in it (on the door itself) causes the lock to snap back into the open position. I tried taking the bottom off but noticed that even after taking the top button board off in order to access the last two screws for the front of the washer, I was still going to have a problem since the rubber gasket was still conected to the door/front of washer. I did not want to unhook the gasket seal thingy because I was afraid of it leaking later on. I eventually decided to look on the internet to find the answer. I found FIXYA and found your answer. Taking off the top of the washer allows better access to the whole lock mechanisim and even the manual pull unlocker thing. Thank you for your clear directions and pictures. Sincerly, Washer Fixer P.S. I could not give you the high rating I wanted to because I am not a member. Sorry. :)
    President:
  • 1,294 Answers
Cool...
Posted on Jun 13, 2008
Error showing "F dL" what does that mean?
The reason for "F dl" flash is that if your machine doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely if it's frozen or stiff replace it. If the pump belt is broken or looks quite worn, replace it but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Thank you !!
Aug 15, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer wont turn on. code is F dL. any thoughts?
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 07, 2010 | Whirlpool GHW9400SU Front Load Stacked...
My kenmore elite oasis washer has a dl code with nothing blocking the door. i have jiggled the grey wire on the control panel but that no longer helps.
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 15, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Getting message F DL. ASSUME MEANS DOOR NOT
IT APPEARS YOU HAVE A MAGNETIC CONTACT FOR THE DOOR,YOULL HAVE TO HAVE A REPAIR MAN REPLACE THAT CONTACT,
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
An error signal "DL" - door lock signal keeps coming on
Check for loose wires from the door lock to the control board.If no loose wires,
Replace the door lock switch.
May 23, 2009 | LG WM2277H Front Load Washer
My screen in showing code "dl" and then "f", please help?
The "dl" code is "doorlock" indicating a problem with the door locking mechanism or switch
Apr 19, 2009 | Kenmore Elite HE4 Electric Dryer
Washer displays message of dl when trying to start washer
Hello bculwil Welcome
“dL” (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid
keeping it from closing. Press PAUSE/CANCEL once to clear
the code.
Or the lid lock sensor is faulty and needs to be diagnosed and replaced
Please remember to leave a solved rating before signing out.
Thank You Huum
Dec 21, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool duet washer code
Hi Keitha1
I'm Harvey the Master Plumber
You want to know what code dL means on a whirklpool duet washer.
This is what works for me 99% of the time:
Simply unplug the washer for ten minutes. The onboard computer will reset and work like new.
Please understand that you are not being shortchanged. There are hundreds of codes and with this new computer tech. they mostly require a repareman. To save you money the manufacturer has designed it to reset itself after ten minutes to solve most problems. Try this first, you can always call a local pro later if you want.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code
If you see "dl" or "du" error codes, these are usually indications of a failed door latch assembly and will require replacement. You can click on the following link if you need step-by-step instructions on how to replace the door latch:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Hope this helps!
Thank you for contacting us at FIXYA.com
Jun 06, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
