Question about Asrock K7VT4A-Pro Motherboard
No hace nada no arranaca ni manda señal de video tarjeta nueva
4 Suggested Answers
SOURCE: Encontrar el Controlador de Sonido para una tarjeta VIA_P6- M925LR
mnkpm
Posted on Jun 11, 2008
  • 5 Answers
SOURCE: tengo una tarjeta INTEL D945GCZ SE DESCOMPUSO LA
hi its easy download drivers
Posted on Dec 16, 2009
bronk50
  • 27725 Answers
SOURCE: ecs 945GCT-M/1333 problema de audio
google translated
945GCT-M/1333 ecs audio problem
I'm trying to run a headset for Skype, so far had no problems with my speakers, now there is noise interference (?) Sometimes, and skype does not recognize the micro (and it works because I tried it on another compu ) .. not if some codec or something .. everything that relates to sound hardware refers to "Sigma tel audio" and not if the modem ... any information is welcome! garcias!
Click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam.
Click start right click on my computer select properties then device manager scroll down image devices you could see a yellow question exclamation mark? ! or a red X
right click to reinstall drivers or update driver W7.
Click start control panel administrive tools computer management device manager scroll down image devices you could see a yellow question mark?
Some webcams and programs require additional software, although that should be installed with the webcam if things are right.
But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date.
But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing.
Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10).
http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer
Also during a video call at the top of your screen you will see an option to for a video call using yahoo messenger this might vary if you are using another messenger service
Open skype go to tools from the drop down list select options scroll to audio settings
you can make a free test call before you try to make a call.
Make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment.
Click start control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings.
Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
Select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
Hope this helps
Posted on Nov 15, 2012
Mi control de dish es 21.0 IR/UHF PRO no prenden las luces del sat tv dvd y aux no hace nada de nada y tiene sus baterias nuevas necesito ayuda URGENTE mi televisor es sansui y solo tenemos una caja para...
Solimar, disculpe la demora en responderle. Espero que a este punto su problema ya haya sido resuelto. Al leer el problema parece que necesita ser reemplazado. Si usted necesita asistencia adicional con su servicio sientase libre de contactarme a: kimberly.escobar@dish.com
Kimberly escobar
Social Media Representative
DISH L.L.C
Aug 03, 2013 | Televison & Video
Como Reparo un Plasma Panasonic Viera TH-42PD60X no enciende ni el led de Standby
AMIGO YO TE VENDO LA TARJETA DE PODER PARA QUE NO SUFRAS MAS CON ESE APARATO , O TE COMPRO LA PANTALLA PARA EL MIO QUE ESTA QUEBRADA ,
Compro pantalla para PLASMA PANASONIC TH-42PD60X la mia esta rota, o vendo mi plasma para repuestos , tambien vendo una base para este plasma ya que tengo 2 unidades . gracias interesados escribirme a jaimolb@hotmail.com informes tel 0057 3207250204 colombia
Jan 21, 2012 | Cars & Trucks
Por que la luz de network card esta prendida todo el tiempo color rojo a ambar es normal ? o esta fallando gracias. Dimenson 5150
La luz de la tarjeta de red se vuelven de color rojo o ?mbar si la tarjeta es mala, la tarjeta no est? conectado correctamente, o si la tarjeta no est? recibiendo una se?al de la red.
Soluciones:
1) Aseg?rese de que todos los cables se conectan correctamente desconectando ellos y conectarlos de nuevo in Compruebe que est? recibiendo una conexi?n de su proveedor de servicio.
2) Apagar el ordenador y desmontar la tarjeta de red y si es capaz de volver a montar la misma.
3) Si todo esto falla es posible que necesite obtener una nueva tarjeta de red para su equipo. Si la garant?a de Dell sigue siendo bueno debe ser capaz de obtener de Dell para reemplazar su tarjeta de red en contacto con su atenci?n al cliente.
May 23, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Tengo una cannon power shot sd600 digital elph, en ella tengo 15 fotos y dos videos de 2 minutos cada uno la memoria es de 500 mb, pero el display dice memoria llena y no me deja sacar fotos ni capturar...
¡Hola!
Bienvenido a Fixya. Posible que sus videos y fotos se guardan en su memoria interna no en la tarjeta SD / tarjeta de memoria. S?lo tienes que seleccionar la tarjeta de memoria de dolor o guarda sus im?genes.
Gracias por usar ou Fixya,
seancarlisle
May 13, 2011 | Canon PowerShot SD600 Digital Camera
Al encender mi camara Nikon S80 me aparece que la tarjeta esta protegida para escritura como lo puedo quitar
¿Por qu? mi c?mara de decir "tarjeta bloqueada" o "protegido contra escritura"?
Los conceptos b?sicos. De la misma manera que las grabaciones en casetes de audio y cintas de VHS pueden ser protegidos por la ruptura de la ficha poco en la esquina posterior, el material en una tarjeta de memoria se pueden proteger contra la que se sobrescriban. En lugar de una ficha para romper, protecci?n de escritura se realiza mediante un control deslizante peque?a en el borde de la tarjeta (frente a la esquina cortada). Antes de que la c?mara tomar? im?genes, es necesario que este control en la tarjeta cuenta con un micro en la c?mara, que s?lo lo har? si no es en la posici?n de "bloqueo". El control deslizante en realidad no hace nada dentro de la tarjeta, por lo que yo no lo llamo un "interruptor" a pesar de que parece como tal. Su ?nico prop?sito es que sea detectado por el micro en la ranura de la c?mara, y es la c?mara que se encarga de la protecci?n de escritura, no la tarjeta.
Diagn?stico. Obviamente lo primero que debe hacer es comprobar que el regulador no est? en la posici?n de bloqueo. Si la c?mara te da este error en la posici?n de desbloqueo, esto significa que el regulador no ha podido hacer funcionar el micro, o que el propio micro est? defectuoso, o tal vez que hay alg?n error de sistema de archivos con la tarjeta. Para diganose el problema, ser?a muy ?til si se pudiera tratar de dos o m?s tarjetas de memoria diferente en la c?mara y ver si s?lo uno, o todos ellos presentan el problema.
Si s?lo uno presenta la tarjeta de memoria del problema: En este caso, es claramente algo que ver con la tarjeta de memoria. Es el regulador desgastados, doblados o que faltan? Una barra de desplazamiento que faltan de protecci?n contra escritura de la tarjeta de la misma manera que el deslizamiento a la posici?n de "bloqueo" se. Hay otra posibilidad. Recientemente he descubierto que algunas c?maras que utilizan tarjetas xD-Picture Card tambi?n dan este error a pesar de que esas cartas no tienen ni siquiera deslizadores de bloqueo! Adem?s, algunos usuarios han informado de la fijaci?n de este error a formatear la tarjeta. Por lo tanto, creo que tambi?n es posible que el error puede ser fijado por cambio de formato. Antes de hacerlo, aseg?rese de que usted ha copiado todo lo que quieras de la tarjeta y luego utilizar "formato" de la c?mara funci?n para formatear la tarjeta. Te aconsejo utilizar la c?mara durante la funci?n de formato porque as? se garantiza el sistema de archivos correcto. Si usted utiliza su computadora para dar formato, usted puede f?cilmente obtener el equivocado. Sin embargo, si es necesario hacerlo de esta manera, ver qu? sistema de archivos est? actualmente en uso en el disco antes de empezar. Vaya a "Mi PC" y haga clic derecho en la unidad que es la tarjeta de memoria, y seleccione "Propiedades". Ejemplos de sistemas de archivos son "FAT" (probablemente FAT16), "FAT32" y NTFS, para asegurarse de que su formato se realiza correctamente, asegurarse de que usa el sistema de archivos igual que antes.
Si alg?n trabajo tarjetas de memoria, y otros no, o las mismas cartas de trabajo, pero a veces s?lo a veces: El control deslizante es muy peque?o, as? que es posible que el n?mero de personas que informar de este error se debe a la falta de precisi?n en los tama?os de fabricaci?n. Debe ser dif?cil hacer un micro que puede sentir una cosa tan peque?a. ¿Tiene una mejor marca de trabajo de la tarjeta? ¿Puedes soportar quedarse simplemente las mejores marcas, o los que trabajan m?s fiable? Como remedio de ?ltima instancia, podr?a intentar envolver una peque?a tira de cinta adhesiva sobre el control deslizante para aumentar su espesor, pero creo que esta es una soluci?n de riesgo. Hay un riesgo de que la cinta saldr? en la ranura y causar a?n m?s problemas, o que la cinta ser? tan espesa que la tarjeta de atasco en la ranura y que tendr? problemas para sacarlo.
Si todas sus tarjetas de memoria se comportan de la misma manera: En este caso, es claramente algo que ver con la c?mara. Podr?a ser que el micro se rompe, o hay alg?n error de software. Aunque es menos probable, vamos a cubrir el error de software de primera; por favor, encontrar la funci?n del "restablecimiento del sistema 'en el men? de configuraci?n y uso para todo claro. ¿Es bueno? Si no, pruebe la soluci?n de cinta adhesiva en el ?ltimo p?rrafo en la esperanza de que se trata de un tama?o o el problema en forma con el funcionamiento de la micro, pero si eso no estamos fuera de las opciones en realidad, m?s all? de la reparaci?n de dicho micro.
Apr 22, 2011 | Nikon COOLPIX S8000 Digital Camera
Cyberamigos luego de 3 a 5 minutod de encender monitor aparecen rayas finas horizontales negras y a veces se quitan a veces no luego de mucho tiempo --gracias
Amigo tienes una pc de escritorio o una laptop.?
la falla es tipica de un problema en la tarjeta de video, creo que ya esta a punto de dañarse totalmente, te recomiendo compres una tarjeta de video nueva, En la laptop puede ser que se afloje la cinta que va al monitor. tendrias que abrir la laptop , limpiar los contactos y ajustar la cinta.
Mar 03, 2011 | Computers & Internet
Tengo una camioneta jeep grand cherokee, 97 que en la computadora me manda un mensage, coolant sensor bad y no lo e podido corregir y sale mas cuando hace mucho calor
Ese es un mensaje comun en este tipo de camionetas; tengo una '93 GC Limited 5.2L V8 y presento el mismo problema por algun tiempo.
Solamente hay dos cosas por hacer:
1. Desconecta el harness del sensor y dale una lavada con solvente dielectrico para contactos electricos. Previamente desconecta los bornes de la bateria.
2. En caso de que el procedimiento anterior no funcione, podriamos pensar que el sensor de refrigerante es el que esta da?ado, enviando una falsa se?al al VIC (Vehicle Information Center) que es el que te envia el fallo.
OJO que cuando desconectas los bornes de la bateria el ECU se resetea, con lo cual podriamos tambien probar que era un error antiguo almacenado.
Aqui hay un tema en una web Jeepera de Espa?a: http://www.jeepy4x4.com/foro/viewtopic.php?p=311758
Espero que esto te sea de ayuda; recuerda calificar esta respuesta. Suerte.
Oct 05, 2010 | 1996 Jeep Grand Cherokee
La tarjeta no me pita y no me da video
Una pregunta, cuando esta conectada la fuente de poder y enciendes el ordenador, el ventilador del procesador se mueve? Si no se mueve quiere decir que hay un problema de corriente.
Esto se puede deber a:
1. los cables/la conexión de encendido no esta bien conectada (eg. Los cables que van del gabinete a la placa madre)
2. La fuente de poder esta pagada, desconecta o defectuosa.
3. La placa madre no esta bien aislada. Es decir la placa madre esta siento “tocada” en sitios donde no debe. Eg. las monturas del gabinete están haciendo contacto fuera del las zonas aislada, o un tornillo/tuerca esta tocando la placa madre fuera de sitio.
Suerte,
Ed
Oct 04, 2009 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
Perdi el disco de drivers de la tarjeta Abit SG-72
Bajalos del website de ellos, problema resuelto.
Apr 18, 2009 | Abit SG-72 Motherboard
Asrock K7VT4A-Pro Motherboard Logo
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
