Question about Bosch Dishwashers
Our integrated dishwasher is stuck on pumping. How do we fix it?
    Problem Solver:
  • 7 Answers
Maria, try to remove whatever it is stuck in the pump.
Most of the time you can remove the housing of the drain pump,
take out what doesn't belong there and mount it again.
Posted on Oct 16, 2010
I have a Samsung Dishwasher DMT800RHS, dishes have brown film, tried Lemon Magic, fixed 9e code, still dirty dishes. Used liquid detergent, still dirty dishes. Sometimes white film.
Sounds like its not draining properly between cycles. Its time for an appliance engineer I'm guessing. Can you access the drain pump hose area to see if its clogged.
Nov 06, 2014 | Samsung 800 Series DMT800RHW 24"...
John lewis integrated dishwasher
make this test and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/control board
Jul 24, 2013 | John Lewis JLBIDWS1804 Builtin Dishwasher
My GE profile dishwasher is not draining, is it fixable?
Yes, it is fixable. I would fix check to make sure the float on the inside of the unit is not stuck (not a probable, but easily checked). Then I would pull the unit out and check the pump. If something is clogging the pump intake then it wouldn't drain. If there isn't something blocking the pump intake, then it is probably the pump itself.
Sep 20, 2011 | GE Profile 24 in. Built-In Dishwasher...
Ikea Whirlpool integrated dishwasher door front
how do i take door off to fix handle back on dishwasher
Jan 03, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
Bosch integrated dishwasher water pump wont go off
sounds like the drain pump stays on. take the kickplate off and check for water in the base. if no water then make that little red bar to the left of the watervalve in the base go up and down a few times. you could have a stuck microswitch on the pressure chamber
May 29, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch sgv53e13gb Integrated dishwasher - wont start a new cycle!?
As the machine is only two weeks old I would go straight back to the seller and report the fault to them - and take a copy in writing. Don't be fobbed off with any instructions to get in touch with the makers - your contract is with the seller and it is up to them to fix it! And if you mention compensation for the inconvenience caused by this defective product, it might help speed things up.
Hope this helps! D.
Jul 13, 2008 | Bosch 24 in. SGV53E03 Built-In Dishwasher
Philips Whirlpool Integrated Dishwasher
Model numbers that are worn or missing are hard to find. When you go to whirlpool's website you might find your dishwasher there, other wise it might not have them listed because it is obsolete.
One place to look is on the panel below your dishwasher door. In some cases it is stuck there, or somewhere else under the dishwasher.
I have seen them inside of the dishwasher housing (under the cabinet between cabinet and dishwasher.
Very rarely will you find the model numbers inside of the dishwasher doors. However according to Whirlpool, if you open your door, you will find a sticker or a riveted plate on the right hand side of the dishwasher's frame, near the seals.
One thing I suggest however once you have discovered the model number, write it down and put it someplace safe.
Good luck
Apr 29, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Tecnik integrated dishwasher 795/2
make sure all filters are clean.make sure the wash arms are not cracked at the seam.if all that checks good you could have an obstruction to the pump.also check to see if you lose any water when running a cycle because the drain valve may be stuck open.the other possibility is that the impeller on the pump is worn or broke.
Aug 27, 2007 | Frigidaire 25 in. FDP750RC Free-standing...
Dishwasher stuck on "drain"
not easy to fix - it has a leak. the tray at the base is full of water which ooperates a float which switches drain pump on. remove front panel at bottom front and mop out water or tilt backwards 45deg and water will run out. leak is usually main pump
Mar 18, 2007 | Neff 24 in. S5543X2 Built-in Dishwasher
Dishwashers Logo
97 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
