Turn heat pump on hot out side unit works but no warm air inside house
  • 24 Answers
Check the circuit breaker for the air handler
Posted on Oct 16, 2010
Hear pump keeps running constantly, why won't it shut off?
if some units detect ice they will leave the fan running in an attempt to defrost the coils. If it's the outside coils and it's warm enough inside, try running the air conditioning for a few minutes, that will put hot coolant through the coils and could melt the ice for you.
Mar 16, 2015 | Amana PTH153B50AJ Heat Pump Air...
Coleman 8000 compressor only comes on and cools when cool outside like in Am or late pm
Clean the coil inside and outside. try putting it in a window on a shady side of the house. I worked on a outside unit wher it was 90degrees outside but 107 degrees where it was in a hot location, close to road on sunny side of house.
Jul 28, 2012 | Dometic Rooftop RV Air Conditioner
The air conditioning fan outside the house is showing frost on the coils, what is the problem
Are you using your Air conditioner as a Heat Pump (Making heat in the house)- or as an Air Conditioner (making COLD air in the house.)
If as a heat pump, then remember-- that the WARM coil is now inside the house-- and the COLD one is outside-- So, if it is COLD outside, there is not enough HEAT out there, to keep the coil from going below freezing-- The unit may have to be turned off, and allowed to defrost, if you want more heat from the Heat Pump-
Let me know if this helped
Mack B
Jan 15, 2011 | Ruud Heating & Cooling
I had the same issue...the temp is 30 degrees out side and like 50 inside...every time i turn on the heat the aux heat turns on...i tried to turn on the EM Heat but then the aux heat still turns on...i had...
You obviously have a heat pump. A heat pump is basically an air condition running in reverse. By way of example, during the summer time you will notice cold air coming from you vents and hot air being blown out of the outside section of you unit. And in the winter time it switches the flow of refrigerant (freon) and sends the hot air inside and the cold air out. So when the temp drops below about 45 and/or there is a high demand for heat inside the aux light will come on. When this happens it bring in the resistance heat (back up heat stripes) to accommodate for the added need for heating. Heat stripes do in fact burn a lot of electricity. My suggestion to you is not to make more than 5 degree increments of temp rise at a time on your t-stat. For instance if it is 50 inside, set the t-stat to 54, as the temp in the house rises you may continue to raise you setpoint...just never more than 5 degrees of room temp. Otherwise there is not much you can do for it on your own.
Dec 14, 2010 | GE Zoneline AZ55H09D Air Conditioner
What's the difference between EM HEAT and AUX HEAT?
Sorry, neither of these answers are completely correct.
You have a heat pump (or the wrong thermostat). Let's assume you have a heat pump.
In air conditioning mode, it works like every air conditioner you have ever had, but...
In heat mode, it reverses its operation. Have you ever felt the air coming out of the outdoor unit of your A/C unit? It's hot, isn't it. And the air coming out of the indoor unit (out of the registers) is cold. Now for a heat pump to produce heat it simply runs the air conditioner in reverse and the heat comes out in the house and the cold is released outside. Neat, huh!
Here's the problem with heat pumps...when it is really cold outside the heat pump can't produce enough heat to heat your home. So it has an additional heat source called "Auxiliary Heat". This heat comes on automatically when the house doesn't get warm enough. The source of this heat is based on the region of the country you are in. North/Northeast generally have oil heat, other regions have gas, and still others have to use electricity to heat. In Texas, we usually use electricity as the supplementary heat on heat pumps. VERY EXPENSIVE!
Now the "Emergency Heat"...this is exactly as stated in Solution #2. This is manually turned on by YOU at the thermostat when your heat pump fails. This turns on the auxilliary heaters and turns off the heat pump (remember, the reverse air conditioner). Again, this can be quite expensive to run if your heat source uses electricity! Gas and oil may be cheaper. The emergency heat is only designed (normally) to keep the house livable (not comfortable) until the Heating Tech can get out to you and fix your heat pump.
Something else you should know. It is normal for a heat pump's outdoor coil to frost up during heating mode. It will detect this and go into DEFROST mode and melt the frost off the coil. While it is doing this, it will turn on the auxilliary heater to keep the air blowing in the house at a reasonable "warm" temperature, but it will not be as hot as normal. In fact, heat pumps produce a lower temperature heat than traditional heaters. So the air may feel cooler during heating than you are use to anyway. This is normal and is not a sign of a problem.
So what do you do: Set your thermostat to the temperature you want and set the controls for HEAT/COOL and FAN-AUTO/ON and leave the EMERG HEAT off unless your heat pump breaks.
As always, keep your filters clean and your outdoor unit's coils clean and free of debris.
Hope this explains your question for you!
Oct 16, 2009 | Ruud Central System Air Conditioner
I have a Intertherm heat Pump. Everything turns on inside the house. Blows warm air and the outside Fan wont turn on. Both the outside copper pipes are same temp, neither hot nor cold. Don't know the modle...
If the fan outside doesn't work the compresor will overheat and shut off by the thermal protection inside the compressor , to fixed this you have to replace the fan motor and its capacitor.
Aug 26, 2009 | Heating & Cooling
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Parkray Cumbria efficiency problem
Some circulation pumps have a 3 phase mixing valve (cold,warm,hot) to regulate the water pressure in the building; no way to know unless you trace the plumbing. Basically, the hot water temperature could be lost because the circ-pump is cooling it with the cold water supplied to it. This is used to balance the pressure (aka Pressure Balancing Circ-Pump), so heater is really working overtime to heat the water. If the pump has two in and one out that's more than likely your problem; but you should consult a "old-school" plumber in your area.
Nov 25, 2008 | Water Heaters
Amana heat/air conditioning pump
You are going to have to increase the amount of heat absorbed by the evaporator coil on the indoor section of your system. First change the filter. Second turn the power off to the outdoor section and leave the indoor fan running until all the ice on the evaporator coil has thawed this could take a few hours. Third you need to verify that you are getting adequate airflow across the indoor evaporator coil and the outdoor condenser coil both fans should be spinning at full speed and airflow should be unobstructed by dirty coil fins or debris Hopefully after you've done this you will have cold air blowing inside and the larger of the two lines entering the unit outside will be cool to the touch but not frozen or even frosted regardless of run time and the small one should be the slightly warm but not hot. If the larger line continues to freeze then it could indicate a number of problems but essentially your condensers cooling capacity is outrunning your evaporator coils ability to absorb heat from air stream circulating in your home.Hope it works out for you GL!
Jun 10, 2008 | Amana PTH123B25AJ Heat Pump Air...
Non-working outside unit
If your unit is blowing heat inside and it's not a heat pump. It will be most likely electric heat in your case.
Sounds like you have a split unit meaning the condenser is outside and the cooling and the heat features are inside or under your home.If your Rudd is a heat-pump the outside unit will cycle/blow cold air outside in winter and hot air will cycle/blow outside during the summer season. Now, if for some reason the heat  is not coming on inside the house, would be the only reason that you would need to be concerned. Being a heat relay or breaker of could cause that problem. Hope this helps you, Sea Breeze
Oct 27, 2007 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
