Question about Microsoft Computers & Internet
I'v re-installed Windows Vista, but met with the one and the same problems like these: 1. "The Windows Installer Service could not be accessed. This can occur if the Windows Installer is not correctly installed. Contact your support personnel for assistance." 2. "Windows Defender encountered an error: 0x80040154. Class not registered" & etc. Do You know any reason concerning these? Many thanks in advance!
2 Suggested Answers
Rider On Way
  • 1679 Answers
SOURCE: Windows Vista: I cannot install anything at all.
Is your Vista a 32 bit or 64 Bit O/S
open this link and run the Windows readiness tool, This will help the PC unblock any failed updates for Windows and help you install the new updates.
http://www.microsoft.com/downloads/details.aspx?FamilyId=b4d90b06-c27d-4483-bc1f-04d43fa7b293&displaylang=en
Windows installer for Vista is Installer version 4.5, so the updates should fix the issue.
Posted on Jun 29, 2010
Unwanted windows installer start up
Go to Add and Remove and uninstall windows installer. Use windows update to make sure you have the newest installer. Then go here
http://www.toggle.com/lv/group/view/kl39621
/Microsoft_Windows_Installer.htm
Load the new installer, that should solve your problem.
Jul 11, 2010 | Microsoft Windows Vista Home Premium with...
Jun 29, 2010 | Computers & Internet
Windows Vista:: to Install Problems: 1."Windows Update cannot currently check for updates, because the service is not running. You may need to restore your computer." 2."The Windows Installer Service...
Windows Installer cannot be accessed in Windows Vista 32
TRY sfc/scannow command at command prompt u need your operating system cd inserted while the operation
Oct 15, 2009 | Microsoft Windows Vista Home Premium for...
Vista window installer cannot be accessed/incorrectly installed for some downloads
Start the Windows Installer service
  1. Click Start, type Services.msc and press {ENTER}
  2. Double-click Windows Installer
  3. Set the Startup type of Windows Installer to Manual
  4. Click Start to start the service. (Write down the error message if any).
  5. Click OK.
Windows Installer Registry Fix If the above steps do not help or if the Windows Installer service is not listed in the Services applet, follow these steps:
  1. Download msiserver.zip and save it to Desktop.
  2. Unzip the file and extract msiserver.reg to the Desktop.
  3. Right-click msiserver.reg and choose Merge.
  4. Click Yes when asked for confirmation.
  5. Restart Windows.
May 27, 2009 | HP Pavilion a1610n PC Desktop
Quicktime will not load on vista laptop dv9626us HP
hello, the quick time player installer you are trying to install is corrupt.
Jan 12, 2009 | Microsoft Windows Vista Home Premium with...
Windows Installer prob
Do you experience this kind of problem whenever you attemp to install an application in windows box (2k, xp)?
"The Windows Installer service could not be accessed. This can occur if you are running Windows in safe mode, or if the Windows Installer is not correctly installed. Contact your support personnel for assistance."
The ms website knowledge article 324516 gives 2 methods as a way of fixing this problem, but you might be very lucky if any of the 2 fixes the problem, alot of guys end up formating their systems and doing fresh windows installations or try wired ways of fixing it.
Well, the solution is very easy:
1. right click your root windows installation drive i.e drive where you installed windows 2. click properties at the bottom 3. select security tab 4. click Add and scroll down to SYSTEM account click add and click OK. 5. allow Full control permission and click Apply and then Ok.
This should solve your problem with windows installer.
Oct 19, 2008 | Computers & Internet
I can not install OfficeSuite. I have Windows Vista home Premium. I had downloaded updates all afternoon and it still shows error 1719 Window installer not correctly installed. Help!
Download:Windows Vista Service Pack 1
I tried personally in WIN-XP worked same applies to Vista.
Error Message:
Error 1719. The Windows Installer Service could not be accessed. You may be running in safe mode or Windows Installer may not be correctly installed. Translation:
This message might appear when you’re trying to add or remove a program that installs via a Windows Installer MSI (Microsoft Software Installation) package file. The Windows Installer Service is the standard method for installing and uninstalling software on Windows XP. It keeps track of all of the components that need to be installed for a particular program to run and ensures that any files that are shared by programs are not removed when one of those programs is uninstalled. The Error 1719 is an indication that some Windows Installer Service files are missing or have become damaged. Solution:
The first thing to try is re-registering Windows Installer in the Windows registry. Make sure that no other programs are running and then click Start, Run, type msiexec /unregister in the Open field, and click OK. Next, click Start, Run, type misexec /regserver in the Open field, and click OK. Restart your computer and try installing or uninstalling again.
If you’re still getting the error message, the next step is to try reinstalling the Windows Installer files. In order to do this, you’ll first need to rename the existing files.
First, click Start, Run, and type msiexec /unregister in the Open field, and click OK.
In My Computer, click Search and locate the following three files: msi.dll, msiexec.exe, and msihnd.dll. They are hidden files so you’ll need to select Search Hidden Files And Folders under More Advanced Options. When you’ve found the files, rename them, by removing the .dll and .exe extensions and replacing them with an .old extension(for example msi.dll becomes msi.old).
Once you’ve renamed the files, WinXP will automatically replace them with a new copy from the dllcache (a hidden folder where copies of important system files are kept in case you mistakenly delete or rename critical system files). Restart your computer and try to install or uninstall the program again.
Finally, if neither of the above processes corrects the problem, boot into Safe Mode, and go through the above steps again, first re-registering and then reinstalling.
or
Go through the following links:
http://www.vistax64.com/vista-general/45784-windows-vista-error-1719-help-3.html
Hope this will be helpfull
Please rate me...
Thanks & Regards.
Nandu
Sep 02, 2008 | Computers & Internet
Windows installer package
I've ran into windows installer issues on vista(especially around windows update) You have two options... Try and install the Vista Service Pack 1 standalone(google it.) or reinstall windows Vista.
I'm sorry, if I had a better solution that worked for me in the past I would tell you, but reinstall or try to see if SP1 fixes it are the only solutions that have worked for me.
Apr 30, 2008 | HP Pavilion dv6000z Notebook
Open Questions:
What is Microsoft office applications? Microsoft office is a set of interrelated desktop applications, servers, and services, collectively referred to as an office suite, for Microsoft Word: a word processor included in Microsoft Office and some editions of the now-discontinued Microsoft Works Microsoft Windows and macOS operating systems. Microsoft Excel: a spreadsheet. Microsoft released the first version of Excel for the Mac OS in 1985, and the first Windows version (numbered 2.05 to line up with the Mac) in November 1987. Microsoft PowerPoint: a presentation program used to create slideshows composed of text, graphics, and other objects, which can be displayed on-screen and shown by the presenter or printed out on slides. Microsoft Access: a database management system for Windows that combines the relational Microsoft Jet Database Engine with a graphical user interface and software development tools. Microsoft Access stores data in its own format based on the Access Jet Database Engine. Microsoft Outlook: a personal information manager that replaces Windows starting in Office 97, it includes an e-mail client, calendar, task manager and address book. Microsoft OneNote: a notetaking program that gathers handwritten or typed notes, drawings, and audio commentaries. Notes can be shared with other OneNote users over the Internet or a network. Microsoft Publisher: a desktop publishing app for Windows mostly used for designing brochures, labels, calendars, greeting cards, business cards, newsletters, website, and postcards. Microsoft Project: a project management app for Windows to keep track of events and to create network charts and Gantt charts, not bundled in any Office suite. Microsoft Visio: a diagram and flowcharting app for Windows not bundled in any Office suite
Dec 28, 2017 | Microsoft Computers & Internet
Computers & Internet Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
