Question about Frigidaire 24 in. FDB126RB Built-in Dishwasher
No water Thanks for the try, but I have already replaced the inlet valve. Still no water. I also checked and confirmed that I am not getting 120v to the inlet valve and/or float switch.
Check your heat dry options I have seen them short out a lot and that will prevent the water valve from getting 120v.
Posted on Aug 08, 2008
No water getting to machine to start its cycle.
Posted on Aug 02, 2008
I have a tricity bendix dh101 stopped working cold water not going in to manchaine many thanks if u can help
Possible that the INLET valve is faulty /clogged or there is no voltage to switch ON the inlet valve.
So measure the voltage at the inlet valve, also check if the inlet filter is clogged.
Check the water pressure at the inlet to confirm, remove the line from the inlet valve and confirm the flow when activated.
Aug 08, 2011 | Tricity Bendix Dishwashers
I need to know how to install a cellanoid in my Whirlpool Duet washer Mod # GHW9150PW4 is there a place to get the instructions?
Are you meaning the Water Inlet Solenoid Valve??????
If yes .... you need to know if your W/P Duet GHW9150P Front Load Washer really has a bad Water Inlet Solenoid Valve for the Hot and Cold water. This valve is where the Hot and Cold water hoses connect to the rear of your washer on the upper top left side in the rear as you are facing the washer. In my opinion it is highly unlikely that your Water Inlet Solenoid Valve is bad....but it is possible. Sometimes the filter screen in the inlet(s) of the Hot & Cold water valve can be stopped up with dirt, sediments, etc. If you turn off the water faucets and remove the Hot & Cold water hoses from the washing machine... you will be able to see the screens...if they are stopped up you can remove them with a small screw driver and clean them and reinstall them.
Hook up your hoses and turn on your water supply Hot and Cold faucets.
Here is a quick test procedure that you can do to verify the operation of the Water Inlet Solenoid Valve.
Verify that your water hoses are hooked up and the water faucets (Hot & Cold) are turned on.
Unplug the washer's 120Volt AC power supply cord from the electrical plug on the wall.
(1) Remove the top cover...There will be three screws on rear area of the cover: Left - Middle -Right.
(2) Once the top cover is removed...you will be able to see the Water Inlet Solenoid Valve...just follow the Hot & Cold water hoses from the wall to your washer. Usually the water inlet solenoid has a blue plastic housing assembly with (2) separate push-on or pull-off quick disconnect electrical connectors. One connector pair provides 120volt AC to the Hot water solenoid and the other connector pair provides the 120volt AC to the Cold water solenoid.
(3) Remove the push on or pull off quick disconnect electrical connector to one of the water inlet solenoids..It does not matter which one at this point in time.
(4) You will need an electrical 120v AC Test Cord. You can make this from an old lamp AC power cord or and old 120v AC Extension Cord. You will need two alligator test jumpers or leads (Radio Shack has them). The end of the test cord that plugs into wall is not to be modified. The other end of the test cord will have to be modified in order to conduct this testing. Strip back the insulation to reveal the two leads that will carry the 120v AC power. You should have one black lead (120v AC HOT) and one white lead (120v AC Neutral). Connect (1) alligator test lead to the black lead and insulate with electrical tape as necessary and connect (1) alligator test lead to the white lead and insulate with electrical tape as necessary You now have your 120v AC Test Cord ready. If you have a VOM test meter..you can connect the VOM meter to the two remaining alligator test leads. Have your VOM test meter set for AC Volts and on a scale that will measure 120v AC. Plug in your test cord to the 120V AC wall power. If everything is OK your meter should read approximately 120 Volts AC.
(5) Unplug your 120v AC Test Cord from the wall power.
(6) Connect your 120v AC Test Cord to your Water Inlet Solenoid Valve electrical terminals.
See Step (3).
(7) Plug your 120v AC Test Cord into wall power. If the water solenoid valve is good you should hear water surging thru the water solenoid valve. If you do not hear the water running thru the valve you can verify if the 120v AC is getting to the valve with your VOM. It should read 120v AC. If it does read 120Volts AC at the terminals of the valve and you do not hear the water then the valve is probably defective: Either stuck shut and won't open or the solenoid coil is open (Bad).
(8) Unplug your 120v AC Test Cord from wall power.
(9) Disconnect your (2) alligator test leads from the solenoid valve and re-install the electrical push on connectors that was disconnected in Step (3)
(10) You can now repeat this test on the other side of the Water Solenoid Valve (See Step 3).
(11) If both sides of the Water Solenoid Valve check out good...then your Water Inlet Solenoid Valve is good. If it does not check out then replace it.
(12) If your Water Inlet Solenoid Valve is good...then ....unfortunately, there is a good chance that the CCU module is bad. The CCU module is in effect a computer control unit and controls the overall operation of the washer. The CCU module will cost approximately $150.00
Mar 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water not coming into washer
water will not enter the tub. Replaced water inlet valve. Checked inlet voltage 120v. No outlet voltage at water inlet valve.
Jan 07, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
I'm trying to get my GE GSD1200G00WW to work. When it is put on the wash cycle, I can hear the pump running but the tub does not fill with water. I checked the float and it seems fine. Water valve...
Confirm 120V across the water valve terminals in a couple of minutes into a wash or rinse cycle. (when you turn it on at the beginning of the wash cycle it will drain first, and then will energize the water valve to fill up.)
If there is 120V across the terminals - it may have:
  1. faulty solenoid coil - check for continuity, replace valve if none
  2. clogged filter or nozzle inside the valve. Try cleaning the filter, replace valve if it didn't help
Apr 16, 2010 | GE GSD1000 Dishwasher
Dishwasher is not filling.
Hey I dont know the brand at all but I can tell you the first thing that I try on any dishwasher is to check the shut off valve (usually located under the sink) to make sure you are getting water up to this point (maybe it even got shut off) otherwise you could find the inlet valve which im assuming should get 120v during fill. If its getting 120v and you are getting water through the shut off valve then I would replace the inlet valve. If you are not getting power down to the valve then I would check the float switch make sure nothing is stuck underneith it. Other than that you would probably be looking at a control board issue but keep in mind ive never worked on this particular brand just trying to help you out.
Jan 11, 2010 | Gaggenau Dishwashers
No hot water comming out. Both water valves open. Doesn't matter which temp switch is on still comes out cold.
Remove the top & unplug the harness from the hot water side of the valve and with a meter check for 120v at plug. If you have voltage replace water inlet valve, if thers is not 120v at plug at valve replace control board
Dec 22, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My refrigerator does not make ice. I have to manually poor water in the icemaker to make ice.My water dispencer works but no water refills ice maker
Hi, The first thing you want to check is the inlet tube where the water spills into the icemaker. Most of the time, the tube gets plugged with ice preventing the ice maker to fill. If there are no blockages, check the inlet valve on the ice maker side of the valve. You can test the valve when the ice maker cycles and see if it is getting 120V. If there is voltage and the solenoid does not engage, replace the inlet valve.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 26, 2009 | Amana ASD2625KE Side by Side Refrigerator
No hot water to machine when selected ... Its a cw22b6 model crosley
Hi, When you select hot and turn the washer on, do you hear a humming sound coming from the inlet valve?
If there is a hum, remove the inlet hose and check the screen inside the valve. Do not remove the screen. If it is plugged, scrap it with your finger and try and flush the screen using the hose you removed. It will only take a short burst of water.
If you hear no humming from tje inlet valve, remove the valve and check to see if there is 120V going to the solenoid. If there is voltage but you get know water, replace the inlet valve.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 12, 2009 | Washing Machines
Dishwasher tub will not fill with water
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
May 24, 2009 | Dishwashers
NO WATER OR ICE AT DOOR OR IN ICE MAKER
This is Gene's solution not mine, for a Ge fridge.
Assuming the ice dispenser works fine, the first thing I would check is the water filter, then the water inlet valve on the back of the fridge.
If the water filter is more than a year old it will cause restriction to the water flow.
Locate the water inlet valve on the back of the fridge. Remove the wires from the blue solenoid and check for 120V coming to the solenoid while the water dispenser lever is depressed.
If there is 120V then the water inlet valve has to be replaced.
May 03, 2008 | Refrigerators
Frigidaire 24 in. FDB126RB Built-in Dishwasher Logo
51 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
