Question about Alpine CDA-9813 CD Player
Hi, I had just my Alpine CDA-9813 at the electronics repair shop that I usually go to because whenever I would turn the unit up past 22 the sound would drop out and then back in so fast that was almost as if the CD was skipping. But it did it when the tuner was on as well so I ruled out a skipping CD. I've also ruled out any vibrations, but vibrations also wouldn't cause the tuner to skip. So I'm left with two more options that I can think of. With the first possibility being that the unit is starving for power, and the second possible cause being that whatever controls the cooling fan isn't sending any power to the fan. I bench tested the fan an it works beautifully. But I'm a little reluctant with me and my shaky hands testing inside of a powered up and opened up unit. I honestly think that it's just not getting enough power supplied to it and that's exposed during the heavier amp drawls when the bass hits. If it was a fan problem, the unit wouldn't be overheated and kicking out first thing in the morning when I get it after in sat for at least 8 hours not being hot. The place that I used so many times in the past I will use no more. The store has been passed down from the original owner to his young son who doesn't seem to have clue about electronics. His ideas have been from it needs a new laser, all the way to I must hit too many bumps on the road, which did I thought was funny anyway. Whaddya Say? Should I connect the constant power supply directly to the positive output terminal on the alternator, just run it to the battery terminal, or install a capacitor and run it to the battery? oh I forgot, should I have the alternator redone? I know a place that's been doing that for years and will get me 120 amps out of my alternator instead of the stock amps it's putting out now, which I think is maybe 80 amps. I should mention that this is just the beginning, I'm going to add my old and trusty Kenwood 1021, an Alpine 4 channel, 2 sets of Polk 6 1/2" components, and 2 12" subs (I'm not sure what brand subs I'll be using). But the Kenwood 1021 pulls a whole lot of amps. Help me, Help me!!
Alpine cda 9813r. Turns on and off all the time. Checked supply conections and cleaned front face contacts but made no difference.. Fairly sure it is something interrmittent in the unit. Does not seem to...
I had the same problem it was a bad solder joint on one of the surface mount IC's. I reflowed the joint with a hot air soldering station and new solder and it's been fine since the repair.
Jun 13, 2011 | Alpine CDA-9813 CD Player
Cda 9813 alpine say ERROR
the problem is with the reader.
Feb 25, 2008 | Alpine CDA-9813 CD Player
Alpine cda-9813 no power
You check the radio fuse in the fuse panel?The wire connections are right? Check the Owners Manual for other details or troubleshooting: ALPINE CDA-9813
Hope helps.
Jan 29, 2010 | Alpine CDA-9813 CD Player
CDA-9813 No sound, will not eject CD
There is a very tiny dot located either on the actual face of the alpine head unit or on the front plate of the radio once the face has been removed. Once you find this dot(if on the actual face) you need to make sure unit has power turned on and witha tiny needle or pick you may push this reset buton in for about 2 seconds. The face will automaticaly fold down and the disk will eject itself. Once this is done do not place the same disk back into the unit. Hope this solves your problem
Jun 09, 2009 | Alpine CDA-9813 CD Player
make sure that the acc and ground are hooked up right. acc has to be 12v. if you hooked it up to any other wire it will work until you(turn it up) draw more power than the wire you have it connected to can produce. or you have speakers that are faulty or too big for the alpine head unit.
Sep 18, 2008 | Alpine CDA-9813 CD Player
Alpine CDA-9813 CD Player problem keeping the power stay on
i have that same problem. when i turn the volume up, it shuts off but comes back on right away. the only thing i can think of is i'm not running the constant power directly from the positive terminal on the battery (which is what is recommended). not sure if thats the solution but im gonna try and wire it right anyway...
May 18, 2008 | Alpine CDA-9813 CD Player
No sound
The stereos audio amplifier IC is damaged.
May 07, 2008 | Alpine CDA-9813 CD Player
No Sound
everybody here got took by alpine. get together form a class action suit.
Jan 07, 2008 | Alpine CDA-9813 CD Player
Alpine CDA-9813 CD Player Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
