Question about Canon Office Equipment & Supplies
I have a Canon MP620. It shows error and no paper in tray even though there is paper loaded.
    Genius:
  • 1,584 Answers
Try unplugging power for 5 min then plug power back in.
Posted on Oct 16, 2010
I have an envelope stuck inside my canon mp620 printer somewhere. How do i get it out?
There are three areas for paper jam clearing.
1. Under the scanner cover
2. At the rear of the printer is a small door with rollers at the top. it comes away from the printer from the left. There are some small pins to hold it in on the right. Swing it out to remove the door.
3. The cassette tray. Remove the tray to expose jammed paper or envelopes.
Here is the diagram for the rear door.
Do not touch any components inside the printer.
May 21, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Paper out canon pixma ip200
Either you have selected the wrong feeder, it can feed from the back or the front tray, the little green light shows which tray is selected. If you have paper in both, the feed roller may need cleaning since it gives that error if paper doesn't get picked up.
Sep 01, 2009 | Canon PIXMA iP2000 InkJet Printer
Sir, can anyone help me with my fax (canon fax l295)for a problem, it was always indicating that "load paper" even though i put paper on the tray once it was start feeding it makes an paper jam error and...
You either have a paper path blockage or your feed rollers are worn. You'll need to take it apart to check though. Try removing paper, turning machine off and on and re-inserting paper. Remember to fan (separate) paper before loading, it could be static causing the sheets to stick together and jam in the machine.
Jun 11, 2009 | Canon L295 Plain Paper Laser Fax
MP630 print ERROR - ''There is no paper. Load paper and press OK''
You have to set up NOT "cassette"(in this case "cassette" means the front side of the printer where you are supposed to place a cd or dvd) Choose "rear tray" ! You might have changed the settings by mistake. I had the same problem. I was wondering why is the printer not taking the paper but i figured it out. Try the settings on the mini display of your printer.
Jun 10, 2009 | Canon Office Equipment & Supplies
Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Jun 02, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Need Canon MP620 Paper Tray
Gmack1142, If you haven't already found one, I have an extra I'll sell for 10 bucks plus postage. E-mail me at schaefferrw@hotmail.com and we can set it up. Roger
May 26, 2009 | Canon PIXMA MP620 All-In-One InkJet...
I have a Canon Pixma MP 620 woreless printer and have a paper jam
Had the same problem. Turn off the printer (completely) and turn it on again. That fixed the problem for me (without even touching the paper tray!)
Mar 08, 2009 | Canon PIXMA MP620 All-In-One InkJet...
No Paper Recognised
What paper type is set in the driver? ie plain, letter, A4, cardstock?? Also which tray source is accepted. Might try re-setting driver settings to defualt.
Aug 29, 2007 | Canon Pixma MP500 All-In-One InkJet...
60 people viewed this question
old marine
old marine
