Question about La Pavoni LaPavoni Bar S3 Semi-Automatic Espresso Machine Espresso Machine
I have a La Pavoni espresso machine and it has a problem with pressure buildup. Starting last night every few hours, and continuing today up to every five minutes the pressure builds up to where the gage is in the red and I have to turn on the steamers to let the pressure out. I don't know what is wrong with it, and I have no manual as it was bought with the restaurant I took over so I'm looking for any suggestions.
  • 100 Answers
Pressurestat
Posted on Feb 13, 2011
Why water drop before lever raised until top position?
\\this might be caused by a worn piston seal. see here how to replace seals.
dr pavoni
May 15, 2014 | La Pavoni Europiccola EPC-8 Espresso...
What causes my la pavoni europicola to make a whistling when it;s turned on?
hi
it is normal when water heating up and pressure begin to be built in the boiler until the vacuum braker at the safety valve close
but if it continue to whistle when the green light goes off
after few minutes it means you have too much pressure in the boiler and it is realesed through the safety valve
in that case you have to replace your pressurestat or you have scale at the bottom of boiler in the entrance of the pipe leading to the pressurestat
regards
Guy
Apr 26, 2014 | La Pavoni Coffee Makers & Espresso...
La pavoni stops boiling water
Run some WHITE vinegar through it, followed by plain water a few times. The heating system gets a buildup in it and requires cleaning from time to time.
Feb 06, 2012 | La Pavoni Coffee Makers & Espresso...
La Pavoni high pressure also, but all of a sudden
check pipe for pressurestat and pressurestat,maybe just gauge is not corect
Aug 01, 2009 | La Pavoni Professional Black Base
My La Pavoni Europiccola "exploded" this morning - I think it is the heating element. Is that a common problem - how expensive and easy is it to fix the machine?
Hi there, i am a domestic espresso machine engineer based in Glasgow and i specialise in La Pavoni machines. If you could get in touch with me at my e-mail address (coffeeservice@live.com) i will be able to help you but i will require some info from you about what happened. It sounds like a pressure problem or the thermostat has gone allowing the water to over boil and build up too much pressure. Pressurestat is most probable i reckon. If you give me an idea of what happened i will be able to help you. I work alongside the UK's lead supplier of La Pavoni spairs so have all bits in stock. E-mail me or give me a buzz on 0141 425 1083 and i can sort you out.
David Martin
The Domestic Coffee Service
Jul 14, 2009 | La Pavoni Pisa PA-35 Espresso Machine
Unregulated pressure then safety valve releases pouring out steam
It seems to me that your pressure stat which is inside the base of your machine needs replacing. I would try to give it a good descale and if this doesn't do the trick then a new pressure stat is what you need. Prob around £20 if you buy it and do it yourself. www.theespressoshop.co.uk and just click on the little la pavoni machine for full parts list.
All the best
LaPavoniBoy
Apr 13, 2009 | La Pavoni PC-16 Espresso Machine
La pavoni professional
Make sure your filter is clean.
Jul 21, 2008 | La Pavoni PC-16 Espresso Machine
La Pavoni Losso Espresso machine not working.
Fill the tank with a strong De scale soulition , sounds like its blocked with limescale. REMEMBER to rinse thru clean water several times after the process...
Feb 08, 2008 | La Pavoni Lusso PL-16 Espresso Machine
No pressure
I have the same problem are awaiting reply from la Pavoni direct...I suspect there is a fualt with the pressure gauge as it is steaming up too!!
Jun 10, 2007 | La Pavoni PC-16 Espresso Machine
La Pavoni LaPavoni Bar S3 Semi-Automatic Espresso Machine Espresso Machine Logo
185 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
