Question about Microwave Ovens
How to change the battery`s in a Leisure Provence s1 gas cooker
CAN a ZANUSSI gas cooker be converted to utilize NG ? Without affecting its programs and controls ?
usually any gas cooker can be converted as long as the gas jets are changed to the right size. they also have to be the right fitting. it would involve a lot of work as you will need to get into the nitty gritty of the gas lines inside the cooker and if you make a mistake it can cost to get it fixed.
Jul 02, 2017 | Microwave Ovens
My electronic ignition has gone and the cooker clock doesnt light up, also the fan isnt working is there a battery and if so how can I change this. Thanks
I would say that you have a power failure. A battery cannot run all of that. Check the mains supply to the cooker.
Feb 14, 2011 | Microwave Ovens
Its a gas oven is it safe to cook the dinner while i wait for a new one
It depends entirely as to the reason for buying a new cooker.
Was it safe? Was it broken? Did it no longer work? Were you just wanting a change?
You have not disclosed any of that information and therefore I am unable to offer an opinion. Sorry
Jan 23, 2011 | Microwave Ovens
I have double cylinder fecility of Indane LPG gas. Now I have shifted to a house fitted with Adani gas pipe which I am not using as I am staying on rent and don't want to loose my cylinder membership. I...
As far as I can see it, if you want to use your cylinder gas then you will have to collect it yourself if there is no company in your area that sells LPG. To use pipes gas you will have to change the burner mixture setting on your cooker otherwise is may not burn properly.
Stupid rules I know.
Dec 31, 2010 | Microwave Ovens
I have a belling range gas cooker, i have just changed the thermo couple but now the gas is not coming through as much as it should, the relaese of gas is normally fast and you are able to hear it but now...
There is no reason why the gas level has dropped after the thermocouple was changed but the ONLY reason can be an accidental fault in the fitting or refitting.
So go over the same job and check from the gas line, the regulator and the burner. Use a good air jet to blow the passage clean. make sure there is good contact of the burner to the base for a good fuel mix.
check if there was any restriction inthe gas flow when the fitting was done. The fault can be only here, remove gas and use a air pressure to check the flow line, clean and set back.
Sep 18, 2010 | Microwave Ovens
Gas cooker elc starter not working , iv have all ready change fuse in plug.
it could be the coil in the spark ignighter,,,or dirty spark plugs!
grease can get into the switch as well
Aug 30, 2010 | Microwave Ovens
Can a cookworks microwaves be placed next to a cooker?
yes you certainly can do this without any problem.
Sep 21, 2009 | Whirlpool MH7140XF Microwave Oven
Microwave Ovens Logo
48 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
