Question about Toshiba CX36H60 TV
Hi My toshiba CX36H60 has a problem -- no picture but sound is good. what could be the issue and how to rectify it. Please suggest.
    Top Expert:
  • Toshiba Master
  • 74,106 Answers
As sound output is ok, main board is correct with respect to sound output, video IF and ther stages. The fault lies on the horizontal output section. It may be LOT fault. Check it further for horizontal oscillator stage, and horizontal output stage. Check the collector voltage at the horizontal driver transistor. If you have a frequency meter, check the frequency of that point. It should be somewhere near 15625Hz. If the frequency there is Ok, then proceed to horizontal output stage. Check the horizontal output transistor. If it seems to be faulty, replace it with similar type and number. If the replaced horizontal output transistor heats abnormally within seconds after swich on the set, surely LOT has troubel. Replace it also with same model mumber and type.
Posted on Oct 16, 2010
Testimonial: "It helped a lot to understand and get it fixed. thank you."
Samsung un46d6000sf now has no picture/ no sound backlights are on. had sound, placed tape on ribbons with left improving then when applied to right lost all, removed tape still nothing???
Hi Kevin,
That happens many a times. You try to rectify one thing, the other one pops up. In this condition, please let a good local TV tech handle your set.
Good Luck.
May 31, 2015 | Samsung Televison & Video
Toshiba 37XV505D. Sound but no picture
Since sound is ok but there is no picture, you should try the following:
1) check whether brightness & contrast controls are adjusted properly. If necessary increase level of these controls.
2) If brightness & contrast are ok and even then there is no picture then most probably, there is fault in the horizontal supply circuitry which drives picture tube and is responsible for picture to appear on the screen. you will have to take the TV to service center.
Good luck and Good day.
Rating the solution is appreciated please.
Aug 19, 2010 | Toshiba Televison & Video
I have a toshiba model CX36H60 and the picture keeps going black. I have the hit the menu button on the remote to get the picture back. This is happening every 3 to 4 minutes. When I get the picture back...
Your tv has a defect ,maybe in the board, maybe its only loose connection. you need to sesolder all the parts in the main board .but you need a qualified technician to fix your problem.
Jun 28, 2010 | Televison & Video
Toshiba 46in DLP No Picture, but good sound.
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like a bad lamp assembly , search for one online by model# for between $100-$200
easy to install yourself
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Sep 09, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Toshiba CX36H60 Cold start woes
check the capacitor in the SMPS and around Mr. Flyback
Nov 13, 2008 | Toshiba CX36H60 TV
Toshiba cx36h60
check the sound section if there's a 12volts supply of the sound ic or check the speaker.
Jan 09, 2008 | Toshiba CX36H60 TV
Low sound to none
What kind of TV is it - And how do you have your TV hooked up, as in, cords in the rear coming from and going to...where..?
Jan 08, 2008 | Toshiba CX36H60 TV
Toshiba Color Television CF32G50
I have a toshiba cx36H60 sound no picture
Dec 17, 2007 | Toshiba CF32G50 32" TV
Toshiba model Cx36H60
Yes, I have been seeing a lot of those Toshiba IR receivers bad lately. Replacing it with a new one should take care of your remote problems. If you have never replaced small parts on PC boards then have a qualified tech handle it for you.
Aug 09, 2007 | Toshiba CX36H60 TV
Televison & Video Logo
136 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
