Question about Kenwood Audio Players & Recorders
My SW-301 Subwoofer is not functioning well. It will work for the first few minutes and sound fades and gone.
3 Suggested Answers
SOURCE: Subwoofer works - sound goes away after some time
POSSIBLY A BREAK IN THE SPEAKER SUPPLY LEADS TO THE ACTUAL BASE UNIT
WE HAD THIS AND IT WAS NOT THE SPEAKER BUT THE BOLT ON CONNECTION UNDER THE SPADE TERMINAL ON THE BACK OF THE BASS UNIT
Posted on Dec 31, 2008
Marinmeister
  • 11 Answers
SOURCE: i have a problem with my yamaha subwoofer yst sw
could be a problem with one of the filters inside or a short circuit... your best bet would be to have someone skilled in electronics look at it, and stop using it as you may permanently damage your speaker.
Posted on Jan 15, 2010
Subwoofer deconnects
I have no experience of wireless speakers but I think you should contact the seller, if the unit is still under warranty or perhaps the support section of the manufacturer's website.
Certainly do read the instrucion manual.
I am guessing but either the wireless signal is being lost (depends on the function of the blue light) or the subwoofer is malfunctioning after a few minutes and the built-in thermal or overload protection is switching it off. The thump sound could be it trying to switch on again and finding the fault is still present.
Just my thoughts...
Apr 02, 2016 | JBL Cinema SB350 Home Cinema 2.1 Soundbar...
Klipsch sw 350 subwoofer not working in auto on off position
The audio signal on the subwoofer output of your amplifier turns on the subwoofer after a brief delay to prevent "popping". Sometimes you have to crank up the gain to turn on the sub, then turn it down to a comfortable level. If this approach does not produce results, there may have been a component failure in the input circuit.
Jan 14, 2014 | Klipsch SW-350 Subwoofer Speaker
Protection light is activated since i installed extra speakers- nothing works now
What do you mean by extra speakers? If you hooked more than one speaker up to one output, you probably blew the amp.
Jul 18, 2013 | Denon S-301
Dpx-u5120 dosent show subwoofer option in function mode , how to fix it ?
I manage to slove to my DPX-U5120 Subwoofer level adjustment. In STANDBY mode, Press the Main Volume button and turn to Setting, turn until you find the SW Preout, Swith to normal mode, its won't work if u switch to REAR
Go back to CD/USB Mode, Then Press the Main Volume and find Audio Adjustment and now u can find the Subwoofer Level , Sub Phrase and Sub LPF adjustment.. Um Glad i found this and Happy Setting
Mar 22, 2012 | Car Audio & Video
Subwoofer will not play with other speakers
Hello
It looks like you have posted this before. Unfortunately, I don't know what you have tried so I may be repeating some of your earlier troubleshooting.
The subwoofer needs its own power supply to function properly. if it isn't getting enough power, the sub will not work at all.
On the back of the unit, you should see a green LED when the power is turned on. Is this light on all of the time of does it fade / flicker? This would indicate the power supply is going bad and you need to replace it.
http://forums.creative.com/t5/Speaker-Systems/GigaWorks-S750-power-problems-green-LED-faded-and-flickering/td-p/547311;jsessionid=9B7C9D2D939336148A9036D7E7D18A12
Apr 30, 2010 | Creative Labs Gigaworks S750 Computer...
Powered subwoofer doesnt work .stopped a couple of months ago.it reads SW on the amp display.sw is turned on -green light on-wiring is all healthy and snug.home theater hasn't suffered any abuse.always...
I sounds like you have blown the woofer. open the unit and check. first disconnect the leads on the woffer, then use an ohm meeter. If you don't have an ohm meeter use a 9v battery across the speaker terminals. If you hear a thunk when the battery touches the terminals the speaker is okay. If tyou don't it's gone. If the ohm meeter reads some number like 4 to 9 the speaker would be okay. If it reads nothing or 000 then it's gone. If you need a speaker you can order it from Pro Line Music 215-736-8055
Jan 15, 2010 | Audio Players & Recorders
I have a problem with my yamaha subwoofer yst sw 215 after about 5 minutes of use it gets this continuous bass vibration through the the sound outlet like its stuck on a bass sound any ideas
Jan 15, 2010 | Yamaha YST-SW215 Subwoofer
Connecting a subwoofer to JVC KW AVX800
Hello pmdharan, It sounds like the subwoofer is not turned ON. Go to MENU ITEM > SPEAKER SIZE >SW (subwoofer) and select ON. Hope this helps.
Jun 06, 2009 | JVC KW-AVX800 CD Player
Dec 16, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
76 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
