Question about Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity Gas Dryer - White
DV338AG We are having trouble with our brand new (got it on May 31) dryer, it takes forever to dry the clothes. They seem wetter than when they came out of the washer. I tried one outfit that was dry to get the wrinkles out and used the refresh mode. The clothes became wet and were not done in the 15 minute cycle.
  • 172 Answers
Hi Linda,
First I would make sure the dryer is heating. If the dryer is heating then I would check the airflow out of the machine. Check the dryer vents, and check the opening outside where the air comes out. Make sure they are all clear and the air is flowing out properly. Any blockage in the vents will cause the dryer not to dry your cloths. If you find that your dryer is not heating, you should check the voltage to the machine. You should have 220-240 volts AC. If you only have 110 volts then you may have a blown fuse or a tripped breaker in your box. Reset the breaker or replace the fuse if you find one bad. If you are getting the proper voltage to the machine and you have good airflow and still not drying well. Call for warranty service. Do not attempt to do any internal repairs yourself. If you do this will void your warranty and you sure dont want to pay for service on a 1 week old dryer.
I hope this will FixYa, and if you have any other questions please feel free to ask. I am happy to help.
Mike Anderson
Posted on Jun 03, 2008
Why do clothes take a long time to dry even if dryer is heating?
One basic reason is your washer could NOT be spinning most of the water out, therefore your clothes are wetter than they should be, thus taking longer to dry:-)
Jan 22, 2015 | Whirlpool Dryers
Dryer not working. Clothes wetter than when they went in?
Could be that the RPM is not enough for the spin as the BELT is loose or slipping or if the motor speed is less due to a worn out CAPACITOR.
Try with a longer drying time or manually dry to confirm .
Also check if the inlet valve is working at any time during this cycle to we the clothes, if so there could be output from the control panel which could be a suspect.
Jul 05, 2012 | Fagor 24" Washer/Dryer Combo with LCD...
CLOTHES WONT DRY. IT GETS REALLY HOT INSIDE. THEY SEEM WETTER AFTER IT RUNS FOR AWHILE. TAKES PROLLY 3 HRS TO DRY.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
May 22, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
I have A ge DBXR463ED2WW .it takes about 80 minutes to dry A load.dryer seems to only have A fourth to half heat.
This could be the clothes are coming out of the washer wetter than normal, or poor air flow. 80 min in a little long but a lot depends on the wetness and amount of clothes. If the vent system is clear then I would try smaller loads and checking the washer.
Eric
Jul 21, 2010 | GE DBXR463EDWW Electric Dryer
My LG dlg2532 takes forever to dry clothes. When the drying cycle ends, the clothes are still quite damp. It's a gas dryer and the dryer seems to be getting gas since it does eventually dry the clothes...
How long are the vents? do they go for miles in your house?(sarcasm) Does the dryer have good ventilation? Check the vents again and make sure it is clear.
May 27, 2010 | LG DLG2532 Gas Dryer
Dryer gets clothes hot, but forever to dry them.
I have exactly the same problem. My unit is 2 years old and has suffered this same problem since the day I bought it.
HELP
HELP
HELP
May 14, 2010 | GE Spacemaker Washer and Dryer Electric...
My kenmore dryer heat element goes on and off. The clothes take hours to dry.
It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Dec 31, 2009 | Kenmore Dryers
Dryer takes forever to dry clothes
firstoff, youll need to check for a clean not kinked vent, mosttproblemswith "too long to dry are genrelly tracedback to innadequate/poor venting"
Jan 26, 2009 | Whirlpool Dryers
NOT GETTING HOT ENOUGH TO DRY TOWELS IN AN HOUR
It takes the dryer forever to dry a load of clothing, no matter how many pieces or thickness. Yes, I have already checked the vents out of the dryer, there not clogged. Any other suggestions?
Jul 09, 2008 | Whirlpool GEW9200L Electric Dryer
Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity Gas Dryer - White Logo
304 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
