Question about Acer Extensa 4620 Notebook
I left the pc on and after an hour i found the screen totally blank and it werent react to any button. then i turn it off and back on, and the screen was white with the ACER aign on it. it was like that for about 30 minutes, then it whent black and 30 more minutes later finally it came on properly. the secon time i tryed to turn it on it whent through the same process but this time it took longer. is it a hardwear or softwear problem? can it be fix? is it better to get a new pc?
    Genius:
  • 1,584 Answers
You need to adjust the hibernation / sleep mode in control panel / power options. Set hard disk to never and the monitor to whatever. I prefer to disable all.
Posted on Oct 16, 2010
I was surfing the web, left the room for a few minutes and came back to a blank screen. My remote mouse wouldn't work, I couldn't get it to react by wiggling the laptop mouse or hitting keypads. Two lights...
Your laptop went into sleep mode/hibernate. In many cases windows could not recover from these situations. One solution is to update the BIOS of your laptop on the acer website. Easy way to fix it is setting your power options under control panel. You can configure the settings here if your pc is idle to prevent sleep mode or hibernate.
Sep 08, 2010 | ASUS Computers & Internet
I own an Genesis react pro nitrox/air computer but I need the owners manual to reset, does anyone know where I can find a manual
The instructions are not in the manual. If your is a few year's old, then press the left button to get to the temp screen.
Then press both buttons simultaneously and you will get a screen that says CLR and ID and a number xx xx.
Use right button to change the first number to "7". Press the left button to once advance to the next number. Use the R button to select "19". The screen should now say CLR ID 7 19 and the 19 is flashing.
Press the L button and the computer will power off and will erase all dive logs.
Our family has a total of five React Pros and this works on all of them except the one I recently purchased (May 2010). I think they changed the code on the new ones.
Feb 18, 2010 | Genesis Scuba Diving & Snorkeling
Can't get the Hourly chime to shut off - tried going to alarm, then hitting adjust Button - alarm shuts on or off , but not Chime
using the mode button (lower left, go to the alarm. once at this screen, hit the "12/24H" button (lower right). now hit the "adjust" button (upper left), that should toggle the hourly chime on and off. you'll see the bar next to 'SIG'. when it's lit, it's on, when it's blank, it's off.
Oct 27, 2009 | Casio Illuminator AQ150W1EV Wrist Watch
My laptop turns on, but the screen stays blank.
1. Make usre you charge ur laptop for max 1-2 hours.That increase ur laptop life.
2. Take out the battary,Press and hold the power button for 1 min.Put the battary back and turn on.
Oct 06, 2009 | HP Pavilion DV6700T Notebook PC
Back screen (no screen) upon powering my T60 thinkpad
  1. Take out your battery and the power button for about 60secs.
  2. Start the laptop using the Adapter [without the battery]
  3. Lighten up your laptop...remove any external device attached [printer,scanner,pen drives etc.].
  4. It could also be a RAM problem,try changing the RAM if you have two start with one and exchange them.Clean the edges of the RAM where it get fits into the slots and blow some air in the slots to clean it up of any dirt.
After that when the system starts you can do the system restore START--ALL PROGRAMS--ACCESSORIES--SYSTEM TOOLS--SYSTEM RESTORE to restore it back to an earlier date when laptop was ok. THEN LATER ON PUT THE BATTERY BACK IN.
  • Try restarting after an hour gap.
  • If this doesn't solve your problem call the company people.Their might be a Video Card problem or any other internal hardware problem.
Aug 05, 2009 | Lenovo ThinkPad T61 Notebook
Blank Screen
it sounds like a malufunctioning screen.. to test try to see if the computer reacts the same with another screen attached to it*if its a laptop connect and external screen to the port and when u start up press f4*
Jul 12, 2009 | Dell Computers & Internet
Won't turn on or off screen is blank
I had this problem for about 3 hours except that it was a totally blank screen. Unscrew the back of it and take the battery out for about 10 seconds. Put the battery back and it should reset totally. Don't worry about the songs, they'll be fine.
Mar 10, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
My computer turns on but the creen is totally back n it says that it have no signal as the screen werent connect it but it is
well it should be one of two things either you do not have a good connection to your monitor cables or you have a faulty video card. It would be the only thing that would cause this.
Dec 04, 2008 | E-Machines T6420 PC Desktop
How to unfreeze mp3 player
We have a toshiba gigabeat f20. today it worked fine, listened to it for hoursbefore turning it off. turned it on within a hour to play it and got a blank screen. nothing in the environment could have caused this. battery had been replaced a week before. so, took the case off to opened it and take a look. realized that one of the plug ins for the screen had come loose or slightly lifted inside. it did not totally unplug, just not pressed down tight. pushed it back in. put the case back on. hit the power button and it's back on, nothing that had been previously loaded was lost.
Nov 13, 2007 | Audio Players & Recorders
Acer Extensa 4620 Notebook Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
