Question about Microsoft Computers & Internet
How we can create Forms & queries in access - Microsoft Computers & Internet
    Problem Solver:
  • 9 Answers
For forms, open a data table in view mode, while there locate the forms setup wizard. For your first try just answer the questions the best you can for the wizard. When there are no more questions to answer wizard will create a form for you. From what you learn doing that you may get enough hints to make a form from scratch. Just keep in mind you always build a form from the fields in a table.
Now for the Query, start out the same way and use the wizard. Query to most folks means ask a question and get an answer. In access query is a way to present sub sets of data or ways to modify data in the fields of your tables.
Posted on Jun 27, 2008
I need to perform access database repair
The repair method attempts to recover only the tables, indexes and queries in the database. Do not attempt to repair damaged forms, reports, macros and modules. Before executing the Compact and Repair tool, please ensure the following condition:
1. Do not Open Access database must closed
2. Sufficient storage space available - minimum double in size of your Access database on that Disk.
3. Close the .mdb file related to .ldb file before you delete the .ldb file.
4. Then Run the Compact and Repair tool
Read more about Access Repair Toolbox
On:- http://www.access.repairtoolbox.com/
I tried lots of the suggestions and eventually found that this page was the most helpful http://www.filerepairforum.com/forum/microsoft/microsoft-aa/access/1385-%E2%80%8Bhardly-corrupted-access-2007-database
Feb 28, 2015 | Microsoft Office Access 2007 for PC
Access database 2003 problem with a copy of database file. How to fix?
You say corrupt, in what way exactly? Do you get any specific error numbers/messages?
Have you tried Access repair program? Compact and Repair. If not, use it. But ensure that you made a backup, it is necessary because all the recovery tips can make the damage even worse.
Also try Jet Compact Utility. This tool created by Microsoft and it is much like Compact and Repair, but more successful in repairing.
If no one of above advice helps, then perhaps you need more powerful solution. In this case try to run a good third-party. I would recommend Recovery Toolbox for Access. It must help you. https://access.recoverytoolbox.com/
Feb 23, 2015 | Microsoft Access 2003 for PC
How to invoke a ms.access using parser
To parse a Text field that contains two words separated by a comma, follow these steps:
  1. Open any existing database.
  2. Create a table with the following structure: Table: Parse2Words
    Field Name: Empl
    Data Type: Text
  3. View the Parse2Words table in Datasheet view and type the following three records in the Empl field: Smith, John
    Callahan, Laura
    Fuller, Andrew
  4. Create the following query based on the Parse2Words table: Query: QueryTest
    Field: FirstName: Right$([Empl],Len([Empl])- InStr(1,[Empl],",")-1)
    Show: True
    Field: LastName: Left$([Empl],InStr(1,[Empl],",")-1)
    Show: True
    NOTE: You can modify the QueryTest query to account for spaces between the two parts in the Empl field. For example, if the text in the Empl field is "Smith,John" without spaces, remove the -1 from the FirstName field expression.
  5. Run the query. Note that the QueryTest query separates the text in the Empl field into the two fields below: FirstName LastName
    John Smith
    Laura Callahan
    Andrew Fuller
Jan 08, 2011 | Microsoft Office Access 2003 (077-02871)...
I have DataBase in MS Access But I want connect it to my HTML Page for Add, Edit, Save date in access through HTML Page-
Under the pages tab in the Database window is a wizard that will walk you through creating the page. You can then copy the code or tweak it as you need to. If you do this and want to continue to mange using forms however, you may want to split your database. that means load all the forms in one file and link them to the tables in another. There is a tool to do this automatically under TOOLS > Database Utilities > Database Splitter.
Mar 08, 2010 | Microsoft Office Standard for PC
CAN WE ENTER DATA IN TABLE THROUGH QUERY CALCULATION
Yes, you can add the resulting calculations to an existing query by using and update query, or you can create a completely new table with the results of the query in it by using a make-table query.
Oct 28, 2009 | Microsoft Office Access 2003 (077-02871)...
Application and example of relationship in access
Relationships
After you've set up multiple tables in your Microsoft Access database, you need a way of telling Access how to bring that information back together again. The first step in this process is to define relationships between your tables. After you've done that, you can create queries, forms, and reports to display information from several tables at once.
A relationship works by matching data in key fields - usually a field with the same name in both tables. In most cases, these matching fields are the primary key from one table, which provides a unique identifier for each record, and a foreign key in the other table. For example, teachers can be associated with the students they're responsible for by creating a relationship between the teacher's table and the student's table using the TeacherID fields.
Having met the criteria above, follow these steps for creating relationships between tables.
  1. In the database window view, at the top, click on Tools ---> Relationships
  2. Select the Tables you want to link together, by clicking on them and selecting the Add Button
  3. Drag the primary key of the Parent table (Teacher in this case), and drop it into the same field in the Child table (Student in this case.)
  4. Select Enforce Referential Integrity
    • When the Cascade Update Related Fields check box is set, changing a primary key value in the primary table automatically updates the matching value in all related records.
    • When the Cascade Delete Related Records check box is set, deleting a record in the primary table deletes any related records in the related table
  5. Click Create and Save the Relationship
Apr 09, 2009 | Microsoft Computers & Internet
Access 2007 forms wizard
If you run a repair install of office 2003
Jun 04, 2008 | Microsoft Office Professional 2007 Full...
Ms access
Stored Procedures don't exist in MS Access. You do have the following options though. Queries, which are just select or action queries. VB Code, which you can write using Query Objects as if you were writing a Visual Basic application. These can be Functions or Subroutines. In these, you would use the standard programming techniques with while and for loops, etc.
You can create complex situations combining the two of these. A function in the VB code area can accept through parameters, the single values (line by line, record by record) in a query and act on them and manipulate the values.
For example: create a query that does a select phone from address. Create a function in vb called public function StripDashesInPhone(Phone as string) which then uses VB coding to strip dashes from each phone value passed in. To make it all work, in the query on one of the field columns put "NewPhone: StripDashesInPhone([Phone])" and for every record processed in the query, the function is called with the [Phone] field value passed in to the function and the action is processed and returned.
Other than writing a function that is activated by a form button click, which opens the current db and opens a table and process it, just like in VB, this is about as close to cursors and oracle procedures as you get.
I wish it was more, but ...
Oct 09, 2007 | Microsoft Office Standard for PC
Running SQL queries on Excel
Another way to do it is to use the SQL Drill freeware Excel addin (http://www.sqldrill.com)
hth
Aug 14, 2007 | Microsoft Office 2003 Basic Edition...
Computers & Internet Logo
120 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
