Question about Garmin Quest GPS Receiver
My Garmin Quest has stopped working. It is trying to acquire satellites and also 'drawing' appears on the screen. I have re-booted the unit and it still does not work. Any ideas?
  • 24 Answers
If the screen is otherwise "normal" and it is just not able to acquire satellites, I am guessing you have a problem with the antenna. One way to determine that is if you got an external "patch" antenna, plugged it in and it started working as it should, that is definitely an antenna issue. I have run into several of the "flip up" antennas recently that have exhibited this problem. What happens is, the connector from the antenna breaks loose from the solder joint inside the antenna. If you have a small soldering iron, you can CAREFULLY pry the antenna case apart to access the connector and it is a simple matter to solder it back in place. You will need a very small screwdriver to pry the two outer sections of the antenna case apart. Wedge the screwdriver blade in between the two sections of the antenna covering. Pry the larger part (the part that would face the sky with the antenna at 90 degrees), and with CARE you can get it apart. The small gold connector solders to some circuit traces on the antenna board. To get the antenna off the GPS, place the GPS face down with the hinge part of the antenna away from you. With a small jewelers screwdriver, remove the right two screws on the back of the GPS on the right end. There is a small plastic retaining piece that holds the antenna in place. CAREFULLY lift it up and off the GPS. Be VERY CAREFUL at this point because there is a small spring loaded plastic piece that fits against the retainer piece you just removed. It is very easy to lose the spring and plastic piece if you are not careful. Gently pull the antenna to your right, away from the GPS. The antenna should pop out. If the connector has completely disconnected from the antenna circuit board, you may need some small pliers to get it off the GPS side of the antenna connection. Once you have the antenna removed, separate the antenna case as I described and resolder the connector back on the board.
Posted on Apr 28, 2011
My Garmin quest unit has stopped acquiring satellite signal. All other functions appear normal.
I had a similar problem - and was told that the issue was with the satellites not the unit and that it would be ok in a couple of days. Mine is now working OK again.
Jun 23, 2009 | Garmin Quest GPS Receiver
Acquiring satellites
Did you try reseting your nuvi?
Jul 09, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Edge 305 won't acquire satellite signals
If the option of working without GPS receiver enabled is turned off, then it may be a real damage.
Only thing is to check this option.
Jun 20, 2009 | Garmin Edge 305 GPS Receiver
Garmin 680 -cannot acquire satellites
If a factory reset does not work, your antenna will need to be replaced.
- Jim
Oct 28, 2008 | Garmin Nuvi 660 GPS Receiver
Try this and see if it fixes your problem...follow these steps.
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to try recover from the problem.
Oct 19, 2008 | Garmin Nuvi 660 GPS Receiver
Is not able to access the satellite
Update your unit. Garmin has this problem where you try to enter a location before it acquires satellites. It is very noticeable on the Garmin Nuvi 650 also. Another thing you can try is wait for it to acquire the satellite and see if you don't get up and running. In some cases, it can take up to 4 minutes to acquire satellite information. If this is also your case, updating the firmware to 6.10 should fix that also.
To find what your firmware version you have, click on the TOOLS icon (wrench), click on SYSTEM, ABOUT (bottom of your screen). Anything less than 6.1, you'll have issues.
Jul 21, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin Quest is out of whack
Hello, I currently own a Garmin quest myself, and some time ago I had some strange problems myself, I am a electronics technician, and I do have a work around for you. I will explain the problems and a cure for you to try, none of the work arounds depend on any parts to be removed.
1. NO RECEIVING SATELLITE TELEMETRY. I beleieve this could be due to a number of reasons, but more so at sometime corrupted telemetry was the problem to fix this,
a turn GPS on when booted (initialised)
b. depress menu
select settings
select Time Setup
when in Time Setup depress MENU
Select SET DATE
Depress OK button
Depress OK button again on the numberic keypad that appears on the screen (DONE)
what this seems to do is resets the internal date/time clock and the unit starts to work again.
the Second workaround is this but takes hours to perform.
Simply turn the Guest on and allow the battery to fully discharge, usually this works to TOTALLY flush the Memory again, but on my unit I have to setup all the maps again, this is easy to perform, but just takes time. I hope this helps you.
phil
Apr 04, 2008 | Garmin Quest GPS Receiver
Garmin Quest
b. depress menu
select settings
select Time Setup
Select SET DATE
Depress OK button
phil
Mar 21, 2008 | Garmin Quest GPS Receiver
No Reception with Garmin Quest
You can find a discription how to reset the GPS here (http://www.elsinga.net/quest-first-aid).
I've already tried it and all the suggested solutions like discharging the battery, changing the date, ... , but it diden't help.
littletramp on worldtrip
Aug 28, 2007 | Garmin Quest GPS Receiver
Can't acquire satellite via my navigation unit.
b. depress menu
select settings
select Time Setup
Select SET DATE
Depress OK button
phil
Feb 18, 2007 | Garmin Quest GPS Receiver
Garmin Quest GPS Receiver Logo
101 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
