Question about Optoma / CTX EzPro 610H / 615H Replacement Projector Lamp - SP.81218.001 Projector Lamp
I have a second - hand Optoma EzPro 615H projector. I temporarily replaced the broken UHP bulb with a 150W 110V QH bulb, which gives just enough light to see the image at close range. This image shows the Optoma logo, but the buttons relating to the image ,e.g. The menu button, do not work, Also, connecting it to my laptop is ineffective. Does having the wrong bulb in scramble the electronics? Also, is a service manual available?
Benimur
  • 6966 Answers
SOURCE: CTX Optoma EzPro 580
Hi, Optoma USA recommend that you set the PC resolution to SVGA (800 x 600) or XGA (1024 x 768). Your HP Pavilion ze 4900 default resolution is S = SXGA (1400 × 1050) or X = XGA (1024 × 768). I would assume that your cable(s) are properly mated/attached from the laptop to the projector. If on pressing TV Now! One-Touch button with a TV icon at the top of your keyboard to switch the display to the TV-Out mode, there is no picture projected, you can try to manually lower the screen resolution of your PC. Try lowering it to the 800 X 600 setting in your Display Properties. Also, you may want to check if the Dual Display Mode is enabled/activated. You can try different resolution setting as long as the projector can handle it. Hopes this works and give you an idea. Should you need more assistance, pls post/comment. Good luck and kind regards.
Posted on Aug 11, 2007
  • 4 Answers
SOURCE: Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Posted on Mar 10, 2009
realbat2
  • 68 Answers
SOURCE: Optoma Projector Only Displays White Screen
did u use your function key on your laptop?or did u configure your graphic card so that the output of your computer can be recognise by your projector?or do you try to use your contrast or brightness control at your projector?
Posted on May 12, 2009
SOURCE: Image upside down
I'm on this site because my projector is down after swithcing out the bulb or I could jot down the exact steps for you. It's a very easy fix. When you push the menu button on your projector to get into settings, there is one that will allow you to flip the image. Sorry I can't be of more help
Posted on Aug 08, 2009
projdoc
  • 2237 Answers
SOURCE: optoma ezpro 610h projector displays
over heating and/or bad fan. if the fan stops or slows down, replace it. try www.projectordoctor.com
Posted on Jan 12, 2010
I looking for a replacemnt bulb for ctx ezpro 500
I get all my lamps from
www.avprojectorlamps.com
Just checked, they have the lamp you require in stock
Hope that helps you
Aug 05, 2011 | CTX Optoma EzPro 500 Multimedia Projector
I NEED TO FIND A BULB FOR THE ezpro-610
This is it (in the USA) http://www.myprojectorlamps.com/projector/Optoma/EzPro%20610.html
You mention CTX & Optoma. The link above is an Optoma lamp for the EZPro 610....also note there is a 610H
Feb 16, 2011 | CTX Optoma EzPro 610 Multimedia Projector
How do I correctly wire/connect a Ballast/Capacitor and Timed Ignitor to a 150W Metal Halide light fitting? Regards, Mike Pye
well mostly these lights come with a ballast and the right connector to go from the Ballast to the bulb, if you dont have these then it might just be cheaper to get another set-up. these bulbs run at the high end of the spectrum , in the infa red end of it actually , but really are an ineficient bulb like the mercury-vapour that preceded them compared with the later models , lets say from the 'sonti-agros' till now ( a much more usable spectrum of light and more efficient ) there are a huge range to choose from, as far as the scematics of it well they differ from light to light and brand to brand, hope this has been of some help. geoff
Sep 16, 2009 | Optoma EZPRO 540/585 Metal Halide...
Image upside down
May 15, 2009 | Optoma / CTX EzPro 610H / 615H Replacement...
Optoma 716
on the projector, restart your laptop/computer, this will detect automatically. if not then try display settings to 800x600.
Dec 13, 2008 | Optoma (BL-FU180A) Projector Lamp for...
I am trying to replace a bulb on a optoma ep732h. I have the fixture out but am not sure about the bulb proces.
The fixture and bulb are designed as one piece. When you order a new bulb it comes with the black fixture.
Dec 09, 2008 | Optoma EP732H EZPRO DIGITAL PROJECTOR...
Will not turn on
Hi I have a Optoma EZPro 610 that does not turn on. I know it's getting power because I can see the fan trying to move but it does not spin. I have no lights at all. I just got this from a friend and I don't know if the bulb is good. Is there a way to test the bulb? Any help on this would be much appreciated. Thanks!
Jul 18, 2008 | CTX Optoma EzPro 610 Multimedia Projector
Optoma EP732H Projector - Image is Whitewashed
Hi tourblack
I wouldn't think that this is a lamp issue , as the lamp will make the picture fade away in brightness and wouldn't look white washed.
Check if the brightness is set to 50% and the contrast on 50% as well.
This could be a colourwheel that is in need of replacement.
May 12, 2008 | Optoma EP732H EZPRO DIGITAL PROJECTOR...
Owner manual CD
Follow this link; http://asia.optoma.com/Product_User_Menu/EP757UserManualEn.pdf Gives the manual for the EzPro 757 which may help you out. There do appear to be quite a few similarities and differences between the models, but unfortunately if a manual is available online for the 756 then i couldnt find it. Hope it helps at least a bit :)
Mar 31, 2007 | Optoma Technology EzPro 756 Projector 2000...
144 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
