Question about Bosch Dryers
Bosch excel dryer only working on half heat. Only warm. Anything I can do to rectify this? Thanks G
  • 44 Answers
Best off to call a certified repair company such as Sears.
Posted on Oct 16, 2010
My Bosch Nexxt 500 dryer stopped heating. All other functions work fine except heat. I've checked continuity on heating element & overtemp breaker- both OK. What else could be the problem? Fuse?
CONSIDER THIS
BOTH LEGS OF AC MUST WORK TO GET HEAT FOR DRYER
Maybe you don''t have power to both legs of your receptacle. Both legs of the 220 volt AC have to work go get heat. Only one leg is used to run the motor etc.. Your motor runs so this can fool you into believing that the electrical connection is ok when it really is not. Your dryer is on a double circuit with two breakers. If one fails you lose one 110 volt leg which can be the one giving the full 220 Volt needed for the heater. This happens quite frequently and people mistakenly replace heating coils. You could have a bad breaker, one of the two. You must check this first before assuming anything else. Get help if you are uncomfortable with potentially deadly voltages
Dec 14, 2015 | Bosch Nexxt 500 Dryer
Bosch Nexxt 500 series dryer
Make sure the vent outside isn't blocked either.
May 21, 2012 | Dryers
I think the water in the tank is frozen, is there a way to get it heated up and moving again?
Take the cover off and use a hair dryer to get it warmed up so the water will melt...hopefully it has not broken anything...
heatman101
Jan 13, 2011 | Bosch Water Heaters
My Bosch electric dryer wta3510uc heats but doesnt get hot like other dryers. why is that? it takes over an hour to dry or even more and it use to seem much hotter. clothes are still cool and damp after 40...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Bosch Axxis WTA 3510 Electric Dryer
My dryer is not getting hot or even warm
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
Jun 10, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer all of a sudden does not get warm
If the dryer is not heating at all or is heating poorly, the problem is probably due to a bad thermal fuse or heating element. The thermal fuse is located close to or on the exhaust duct just inside the rear of the dryer. The fuse is about one inch long. Both the thermal fuse and the heating element are easily checked using an ohm meter or multimeter. They should have continuity and if either component doesn't, that component will have to be replaced. Sure hope this helped and good luck.
Jul 20, 2009 | Dryers
Bosch Excell washing machine programme fault
This video will show you how to replace the Bosch washing machine heating element and thermostat with step by step guide on the process
Jun 28, 2009 | Bosch Washing Machines
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Bosch WTL 5400 running, but not heating
I've just fixed mine. The heating element at the rear under the covers was broken - crappy design BTW!
Mar 18, 2008 | Bosch Axxis WTL 5400 Dryer
Washer dryer
Here is the link for a manual for your washer/dryer if you need it; https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM sounds like the heating element has failed, or just possibly the thermostat for the hot air. follow this link for a list of spares if you want to try it yourself, or for bosch repair centre details if not. http://www.bshappliancecare.com/Bosch/boschspares.html ask if you want to do it yourself for any guidance you need. Hope this helps :)
Sep 29, 2006 | Bosch Logixx WFT 2806 Front Load...
Dryers Logo
59 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
