Question about MSI 875P Neo-LSR (MS-6758-010) Motherboard
MS-6758 does not start from hibernation. This happens quite offten and the only help is to switch off main power switch and discharge the motherboard by pressing power button in 10 secs. I am using Windows 7 Ultimate.
  • alexeitsygan Oct 16, 2010
    Hello!
    Already disabled. The same problem can happen if the MS-6758 based system was just powered off (not hibernated). It is home PC and I have to switch it off or hibernate at list during nighttime!
    Thank yo.
    Genius:
  • 1,584 Answers
Disable the power save option in control panel power options.....most versions of windows has this problem also.
Posted on Oct 16, 2010
How to install bios
the bios is already on the board,
when you are booting the computer you have to push down on the F10, if that doesnt work than try F1 and thanF2, every time you try to enter the motherboard bios you have to start from a cold boot.
website for motherboard bios configuration and settings is at
http://www.msicomputer.com
if you want a copy of the bios setup and configurations and everything explained in detail go to your browser and type the following information.
MS-6758-040 BIOS MANUAL OR
MSI MS-6758-040 BIOS MANAUL
the bois controls everything the that runs you computer, video, ram, HD, CPU, PORT FUNCTIONS, BOOT SEQUENCE, SMART FAN CONFIGURATION, HD CONFIGURATION, TEMP. SETTINGS, AND ALOT MORE STUFF AND VERY LONG LIST.
MAKE SURE THE BATTERY IS MIN. 3VOLTS
Jun 25, 2014 | MSI MS-6758-040 Motherboard
MSI 875P Neo-LSR (MS-6758) sound drivers
Download here at msi:
http://www.msi.com/product/mb/875P-Neo-LSR--FIS2R.html#/?div=Driver&os=All
Select first your windows 32 or 64 bit.
Download your files and unzip before you install.
Good luck
Sep 19, 2011 | MSI 875P Neo-LSR (MS-6758-010) Motherboard
I need MS-6758 sound drivers, BIOS version 1
There are two versions of your motherboard listed under the MS-6758 model. I've posted links for the sound driver for both models. Try and download and install the driver from the first before trying the second link.
32 bit/64 bit Sound Driver for the MSI MS-6758: http://download2.msi.com/files/downloads/dvr_exe/Realtek_AC97_MB.zip
If the installation fails after you download and install the driver from the first link, then try this link next: http://download2.msi.com/files/downloads/dvr_exe/ADI_ICH5.exe
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
Apr 18, 2011 | MSI MS-6758-040 Motherboard
How to calibrate battery laptop toshiba satellite m45-s359
Calibrate laptop battery pack under the following conditions:
? When the battery status display seems inaccurate.
? When you observe a significant change in normal batteryrun time.
? When the battery pack has not been used for one monthor more.
How to Calibrate laptop battery
To Calibrate laptop battery pack, you must fully charge, fullydischarge, and then fully recharge the battery pack.
Discharging the Battery Pack Disabling Hibernation
To fully discharge the battery pack, disable Hibernation temporarily.
To disable Hibernation:
? Select the Power Meter icon on the taskbar or access Power Options > Hibernate, and clear the Enable Hibernate support check box.
    To fully discharge the battery pack:
  1. Select the Power Meter icon on the taskbar, or select Start > Control Panel > Performance and Maintenance > Power Options > Power Schemes.
  2. Write down the 3 settings in the Plugged In column and the
  3. settings in the Running on Batteries column, so you can reset them after calibration.
  4. Select the drop-down lists and set all 6 options in both columns to Never.
  5. Select the OK button.
  6. Disconnect the notebook from the external power source, but do not turn off the notebook.
  7. Run the notebook on battery power until the battery pack is fully discharged. The battery light begins to blink when the battery pack has discharged to a low-battery condition. When the battery pack is fully discharged, the power/Standby light turns off and the notebook shuts down.
Dec 13, 2010 | Toshiba Satellite M45-S359 Notebook
No sound
MSI MS-6758 Motherboard Sound Driver Download<--click .
Instructions to install the sound driver.
After successfully downloading the driver,open the downloade file.
When it's successfully installed , please restart your computer.
Nov 28, 2010 | MSI MS-6758-040 Motherboard
Where can i find installation and set-up docs for a msi microstar ms6758 motherboard?
http://www.retrevo.com/support/MSI-MS-6758-manual/id/17425bh042/t/2/
you can download it from that website.
Hope this helped
Apr 12, 2009 | Computers & Internet
MSI 875P Neo-LSR (MS-6758-010) Motherboard Logo
106 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
