Question about Maestro Lutron Dimmer 600 Watts Ma-600-wh
Wired up dimmer light output is not the same as when i hook it up to a regular switch
1) Overview of product indicates it dims by electronics (they say saves 15% electricity)
The electronics might be bad
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/MaestroDimmerSwitch/Pages/Overview.aspx
2) Load types
Different dimmers are made to work with different types of lighting
Depending on your model number, the type of load may be a factor
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/MaestroDimmerSwitch/Pages/Models.aspx
3) Total load
A regular 15 amp light switch carries 1440 watts
If you have the 600 Watt dimmer, load wattage should not exceed 600W >>> add up total bulb wattage
4) Lutron seems to have about 60 different manuals
A quick look at the wiring seems straightforward 1-1 wiring replacement with ordinary switch
Did you connect ground wire to green screw on dimmer?
5) If the dimmer and load requirements match with the dimmer you own, I think the problem might be a short .... exactly where the short is located is solvable by testing the lights and timer and surrounding circuits with a multi-tester >>> the testing would start at the dimmer.
6) All considered, you could replace the dimmer with another one from Home Depot and see if same problem persists.
Posted on Oct 16, 2010
  • Anonymous Oct 16, 2010
    One other thing you might try... on a single pole dimmer (Load controlled by one switch)
    Reverse the two wires and see if problem continuues
Kingfisher halogen pir flood light wiring digram
most halogen lights hook up the the same way as regular fixtures but some do have taps for 120/208/240/480 need more intel to give u an answer
Nov 12, 2012 | Electrical Supplies
I want to replace a dimmer knob with a normal on/off switch but the dimmer has two black wires that are spliced together on each side so a total of 4 wires. Which two would be the live and why are there...
Could be several reasons, but here's what i think is most likely. First, there are other wires in the box that are not connected to the switch - 4 ground wires all connected together, and 4 white wires all connected together. You only 1 hot black wire coming into the box. This wire goes to one side of the switch, but it is tied to a 2nd black wire that is going on to something else (like another switch or an outlet). That counts for two of the black wires. The other two black wires are on the output side of the switch and are going to two places - pehaps the switch is used to control two ceiling light fixtures. The good news is that unless you have a lighted switch there is no difference between the IN side and OUT side of the switch - it works the same either way, and you can connect the switch just like the dimmer was hooked up - even if my explanation of why is not exactly your situation. Good luck!
Oct 23, 2012 | Cooper Wiring Devices 6009W-K ROTARY...
I have one (black) wire and one (red) wire in the same box. Both wires are constantly hot... When I disconnected them from the broken dimmer switch, I only lost power to the top half of the first outlet...
You should check for power after the dimmer is disconnected. now only one wire should have power. If so, one wire to each on a regular switch, does not matter which screw.
Mar 03, 2011 | Solar Leviton Decora Sureslide Dimmer...
We just bought a house and the living room has a light fixture and there is a dimmer switch that controls it. I removed the light fixture and installed a ceiling fan but the fan barely moves and the light...
You're correct. The dimmer switch was not made for that fan.
The Green is ground > so you're right there too. I assume other plugs nearby are working when dimmer is on. Check that to make sure.
By your description, I assume there is NOT another switch or dimmer that connects to same light. If so, you need a 3-way switch and the following instructions are void.
I suspect when you wired the new fan, that you saw the red and small black wires in the ceiling box. Did you connect the fan and light to those wires? If so, the following information will help you wire the switch.
Your incoming Hot line is probably the larger black wire that connects to Dimmer black >>> this wire will connect to either screw on the new switch
To test Hot wire for sure: Take out dimmer and mark wires for identification. Separate wires. Turn on power and test each wire to bare ground. Tape tester leads to wood sticks so hands are away from power. You'll be fine. Tester lights up on Hot wire.
Next: The smaller black and a red wires are a toss up.
Here's how I would proceed. Connect the black Hot to either screw on switch. Connect red wire to other screw. Put wire nut over small black. Turn on power. Flip switch. Check both lights and fan to see which works with red wire.
Next reverse the toss up wires. Put wire nut over red. Connect small black to switch. Check both lights and fan.
If red and small black control the light & fan, then connect them together on the same screw, and you're done.
If you want to control the fan and light separately, buy double switch, and then Hot connects to dark-colored screw on one side of switch, and red and small black connect to two different screws on opposite side of switch.
Oct 04, 2010 | Solar 10 Eagle Almond Commercial Double...
I have a leviton dimmer and no instructions. It has two black wires and one green wire. how do I hook it up as a single pole dimmer?
One black is will hook up to one of the black wires inside the switch box in the wall and the other will hook to the other black wire in the box, The green will connect to the bare copper wire which is the ground wire.
Sep 28, 2010 | Leviton Decora Light Dimmer Switch
Master bathroom: GFCI combination outlet/switch to a dimmer to 3 recessed lights. I am not an electrician but I've wired most of the house myself with advice and Internet diagrams. This GFCI combo to a...
Dave, So you have a GFCI outlet, and a 3way switch and a 3way dimmer switch, right? First off, if you want the GFCI to protect the switches & light you will use both output terminals of the GFCI which have tape over them. The white wire (from the silver screw output of the GFCI) will go to the lights, passing through the switch boxes, but not connecting to anything. The black wire (from the brass screw output of the GFCI) will feed the first switch. Both the switch and the dimmer must have 3 terminals (plus ground). One terminal is the input/output, the other two are "travelers". On a full size switch the input/output will be on the top and the two travelers will be on the bottom (or upside down from this - the key is that the travelers will be on two sides of the switch but on one end. There will be 3 wires (plus ground) going between the two switch boxes 1-the neutral which does not connect to either switch, 2,3 the two travelers. Connect the two traveler wires to the two traveler terminals on the dimmer. The other terminal on the dimmer is the hot wire output to the lights. I hope you found this helpful. Good luck
Aug 17, 2010 | Home
I attempted to install a slide dimmer yesterday. when i pulled the existing switch off I had three black wires (two pushed in to the back of the switch and one wound around a screw) and one white wire...
The white and the black wires are both hot wires, and the green wire is for earth ground only. The green wire does not belong hooked up to the white wire.
The two black field wires should be attached to one side of the dimmer switch (one of the black wires from the dimmer switch)
The white field wire should be attached to the other side of the dimmer switch (the other black wire from the dimmer switch)
The green wire from the dimmer switch should be hooked up to earth ground only (any un-insulated copper wire that is inside the switch/outlet housing) and if you can not find it attach the green wire to the inside of the light switch outlet housing and be sure that it is attached to metal.
The other hall light switch that you are talking about must be connected inline with that light switch you trying to turn into a dimmer, and it should operate again nomally once you have connected that light switch properly, and if not check for any tripped circuit breakers.
May 17, 2010 | Leviton #L32-06631-WWP White Decora Slide...
I just wired 2 3way switches with 3 lights in between them. Tried 2 different dimmer switches on the circuit but neither would dim the lights nor operate the lights as they should. The lights perform...
In general practice, you can only install ONE 3-way dimmer switch to control the lights. If you use two regular 3-way dimmer switches, the circuit won't work.
However, newer technology allows for double 3-way dimming from different locations. See this article about how to do this:
http://www.smarthome.com/2494M3/SwitchLinc-3-Way-Dimmer-INSTEON-3-Way-Dimmer-Kit/p.aspx
Mar 12, 2010 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
House has two black and one white. dimmer has one black, one green and one red. WHat connects to what? THanks
Black wires are the hot side the power line, white is the neutral, and green is ground. On your dimmer, the black wire is for the AC input and the red wire is the output to the lamp you want to control.
If you are replacing an old switch with the dimmer, the two black wires will be connected to the screw terminals on the switch. One of those black wires is the AC feed to the switch, the other black is the one that goes to the light fixture. You'll need to determine which is which so you can hook the dimmer up correctly.
For a few dollars you can pick up a tester that lights and chirps when it's near a hot wire. Turn off power to the light circuit at your circuit breaker or fuse panel. Remove the old switch and disconnect the wires. Make sure the bare ends are not touching anything and turn the power back on. Hold the tester near each of the black wires. One of them will cause the tester to light up and the other one will not. The unpowered wire is the one going to the light fixture. This one connects to the red wire on the new dimmer. The hot wire is the feed that connects to the dimmer black wire. The green wire on the dimmer connects to the other green wires already in the box. Turn the power off again and make your connections using UL approved twist-on connectors (wire nuts), which probably came with the dimmer. Fit the wires and dimmer back into the switch box, secure it with the mounting screws, replace the cover plate and turn the power back on.
Voila! You'll have a working dimmer. A Google search for "installing dimmers" will turn up several links to sites with good pictures.
Apr 11, 2009 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
Electrical box not working
unfortunately it sounds like the main electic wire is shorted out. Not the one to your fan, but the one that provides the power supply FOR the fan. The only way i know to fix this is to get an electrician. I am certain the wire needs replacing.
Nov 29, 2008 | Hunter 52" Ceiling Fan With Light And...
Maestro Lutron  Dimmer 600 Watts Ma-600-wh Logo
393 people viewed this question
Top Maestro Electrical Supplies Experts
Craig Butler
Craig Butler
jdthefixer
Steve
Are you a Maestro Electrical Supply Expert? Answer questions, earn points and help others
