Question about Epson STYLUS R230 InkJet Photo Printer
Multiple pages were jammed in feed tray in it not automatically ejected whay to do?
    Scholar:
  • 120 Answers
Jast open paper feeder tray. To open the paper feeder you need to open 6 scrue. there ware a roller in the left corner in the feeder whice is made by rubber of plastic( White or gray) . Push both end of the roller. When it will open, there ware spring inside the hole of the roller. Put off it. and reassenble the parts with out spring. If you apply it carefully, I thing you will be relive from your problem. Thank you
Shohagtush
Posted on Oct 16, 2010
The belt inside my scanjet 4200c has come off. How do I reattach it? I have opened the scanner. It looks to be relatively easy but I don't know how to attach the belt to the motor etc
Instructions
1 Lift the hatch on the feed tray and pull up the large green tab to the left of the roller. Remove any jammed or torn paper from under the roller and around the feed tray.
2 Pull the input feed tray out of the automatic document feeder. Grasp the feed tray with both hands and pull it straight out.
3 Check the interior of the automatic document feeder for jammed paper. Remove any jammed paper, then reinsert the feed tray into the automatic document feeder. Push down the feeder cover until you hear a click.
Mar 08, 2011 | HP Scanjet 4200c Flatbed Scanner
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
When i give print command the paper was jammed in printer.
The following sections describe how to load media into the different input trays. CAUTION: If you try to print on media that is wrinkled, folded, or damaged in any way, a jam might occur. Priority feed slot The priority feed slot holds one sheet of media up to 163 g/m2 (43 lb) or one envelope, transparency, or cardstock. Load media with the top forward and the side to be printed facing up. To prevent jams and skewing, always adjust the side media guides before feeding the media. Back to top 150-sheet main input tray The input tray holds up to 150 pages of 75 g/m2 (20 lb) paper or fewer pages of heavier media of 25 mm (0.9 inches) or less stack height. Load media with the top forward and the side to be printed facing up. To prevent jams and skewing, always adjust the side and front media guides. NOTE: When you add new media, make sure that you remove all of the media from the input tray and straighten the stack of new media. This helps prevent multiple sheets of media from feeding through the printer at one time, reducing media jams.
Also go to this link to do a Printer Cleaning
Dec 03, 2010 | HP LaserJet 1020 Printer
Paper keeps shifting during loading and eventually gets jammed every time
Seems like the rollers are either dirty, or worn out. Probably the latter.
“Paper jams” on page 68
“Paper or specialty media misfeeds” on page 68
“Printer does not feed paper, envelopes, or specialty media” on page 69
“Banner paper jams” on page 69
Paper jams
Is the jam in the paper
support?
1 Press to turn off the printer.
2 Firmly grasp the paper, and gently pull it out.
3 Press to turn the printer back on.
Is the jam in the printer? To automatically eject the paper:
2 Press again to turn the printer back on.
The paper automatically ejects from the printer.
To manually remove the paper:
If paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together, try the following solutions.
Check paper
condition
Use only new, unwrinkled paper.
Check paper loading Load a smaller amount of paper into the printer.
Load paper with the print side facing you. (If you are not sure which side is the printable
side, see the instructions that came with the paper.)
See “Loading various paper types” on page 21 for information about:
Maximum loading amounts per paper type
Specific loading instructions for supported paper and specialty media
Troubleshooting
68
Remove each page as
it is printed
Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper
guides
Adjust the paper guides:
When using media less than 8.5 inches wide
To rest against the edges of the paper or media, making sure it does not buckle
Jul 22, 2010 | Lexmark X2500 All-In-One Printer
My laserjet 1020 develops a paper jam after printing the first page of a multipage print instruction .I have deleted the printer and re-installed it including all drivers but problem still...
Reinstalling the printer is related the Software.
If the paper gets physically jammed than its the driver setting issue or hardware issue.
Check if two sheets get jammed or only one sheet.
If it is two sheets than printer is picking up multiple sheets and paper gets jammed.
If the printer is jamming a single sheet than remove the Tray and look there is rubber roller inside if there are marks or lines on that rubber roller or if the roller roller is worn out than that rubber roller called as paper pickup roller need to be replaced.
If that looks fine than try to priny using manual feed and if the problem persists from manual feed too than try another toner cartridge
If the problem is not from Manual feed Tray that Replace the main Tray with known good Tray and check if the issue resolved.
Jul 01, 2009 | HP LaserJet 1010 Printer
I can only print by manually feeding in each page -HP 4MV Printer
Good old 4MV.
paper jam is just the way the printer i stelling you "something" wrong with paper feed".
you need to locate a "4MV repair kit" , they are not cheap. but, if you wan to keep the printer, it is worth it.
http://www.fixyourownprinter.com/kits/hp/K78 cost of the ket is $50
includes Instruction CD rollers, and other repairable parts.
Dec 15, 2008 | HP LaserJet 4mv Printer
Paper feed
Have you tried a different brand of paper?. When choosing the paper try and select one which the sheets can slide easily over each other. I had loads of problems with multiple feeds and paper jams with a cheap paper. I then changed to a heavier 90gsm all in one paper from staples and have had no more problems since.(and i just chuck the paper in straight from the packet with no fanning etc)
Dec 15, 2008 | HP OfficeJet Pro k550 Printer
Paper feed jams
try to clean the rollers of the ADF at the same time the separator pad of the ADF.some the issues why this will encounter jam because of the dirty rollers.but if the issue is occuring you need to SERVICE the product
HP TECH support
Aug 27, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP 4700n Paper Late Jam
duplex area related jam in other printers. is problem only occurring in tray 1. If so, there is a problem with the tray. If it's happening from tray 1 and tray 2, replace try replacing transfer belt.
May 27, 2008 | Office Equipment & Supplies
Paper wont feed propaly
Something probably fell into that tiny pinch of an area where the paper goes. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over, poke it if you have to, and shake it around til the little bugger falls out.
Sep 22, 2007 | Lexmark X1270 All-In-One InkJet Printer
Epson STYLUS R230 InkJet Photo Printer Logo
115 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
