Circuit breaker on laundry circuit has started to trip
I have a Kenmore Elite top-loading washer that's 7 years old. During the past 3 months or so, I have noticed that it sometimes makes about 5 to 7 rapid thumping noises just prior to starting the spin cycle, but otherwise has worked fine. However, just in the past two weeks, the circuit breaker protecting the circuit powering the washer and gas dryer has tripped several times when the gas dryer was running and the washer was preparing to enter the spin cycle. This is a 20A circuit with nothing else on it. It has never done this before. Any suggestions?
    Scholar:
  • 110 Answers
If the machines are both on the same outlet i would attempt to run them on seperate outlets first to see if it improves. as time lapses breakers or gfi's can weaken and a continous amp draw esp. in the spin and the ignition stage at the same time which are the largest amp draw from either machine at any give time could be causing the issue. if this does not work you need a tech to look at it
Posted on Jun 03, 2008
Is there a fuse or circuit breaker within this washer? where?
if you try to fix it your warranty is void. so ring them and let them fix it .sounds like the main board is shot
Aug 10, 2014 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite 45986 Front Load dryer wont get hot ?
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Nov 16, 2010 | Kenmore Elite 45986 Front Load Washer
Top loading Kenmore washer runs for a few seconds then shuts off
It's quite possible, however,
If you're mechanically inclined, I'd check the motor, transmission and pump first.
See the following Whirlpool / Kenmore Service manual for top load, direct drive washers and it's trouble-shooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
See the following for how to pull the cabinet, pump, motor and transmission to check them all.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
YOU DON'T HAVE TO PULL THE TUB.
Mar 15, 2010 | Kenmore 43142 Front Load Washer
My Kenmore Elite front loader has no power.
the power is on but the start button does not start the machine
Jun 29, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore top load washing maching tripping the breaker
the breaker is likely worn out, have that checked by service person first, then check that machine does not need to be lubed etc. for too high a load on the circuit.
Feb 09, 2009 | Kenmore 15864/15862 Top Load Washer
Trips GFCI receptacle for laundry circuit.
I ran into this problem with a washer this summer. the gfi breaker needs to be replaced. it is weak and trips easily. if you can run an extension cord to an outlet without the gfi andrun your washer, you probably will not have any issues. that is what I found with the washer this summer. when it was plugged into the gfi, itwould trip. but when I had it plugged into a regular outlet, it was fine. Joe
Nov 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Oasis
You want to charge me to get answers from you but you want me to tell you my fix for free???!!! I don’t think so!!!
Aug 11, 2008 | Kenmore Oasis HE 27082 Top Load Washer
HE4 Kenmore Dryer tripping Circuit Breaker
If you put a light load in the dryer will not trip the circuit at all. That means heavy load made the motor work harder and over heat, it going to trip the circuit , pretty soon, the motor will be warn out.
Jul 01, 2008 | Kenmore Elite HE4 Electric Dryer
Washing machine has high amp draw
yes sounds like your motor is breaking down
Jun 15, 2008 | Washing Machines
Open Questions:
Washing Machines Logo
165 people viewed this question
Top Washing Machines Experts
