Question about Candy Dishwashers
BUTTONS ARE STUCK IT WONT WASH - Candy Dishwashers
  • 44 Answers
Replace console.
Posted on Oct 16, 2010
Testimonial: "thankyou i will get an engineer to look "
  • Adam Behic Dec 13, 2010
    OMIGOD ICANTBELIVEITJNBLAKEMORE9
Radio keeps scanning wont stop
On the steering wheel is the hand controls. Scanning is stuck because of dirt or something. Push the buttons, blow out dirt, wash it off. Mine worked fine after that. (How annoying up til then though. Hope this works. Russ Werth Bowman ND
Apr 21, 2013 | 1999 Chevrolet Silverado 1500
Dish washer the clean light stays on and the dish washer wont run
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Whirlpool Dishwashers
Mn# is 665.16042402 Green clean light blinks 7 times. Wont go into any functions.
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Dec 09, 2010 | Dishwashers
My dishwasher is starting it's cycle, then running for a minute or 2, then it stops and drains itself, then starts the cycle over and repeats this. It won't continue it's cycle and it seems to be stuck in...
you seem to be stuck in a 'quick rinse' cycle. double check your buttons as well as your timer/dial to see if you are using the normal wash cycle. especially check the buttons. good luck
Nov 02, 2009 | Frigidaire Dishwashers
The buttons on my dishwasher wont work
One of the buttons on the control panel is stuck. Unfortunately, the only way around this is to replace the panel because of the moisture that gets trapped underneith.
Good luck :)
Jul 13, 2009 | Kenmore HE2 Plus Front Load Washer
Model A6T12F2A. digital control panel is stuck on
More than likely you is gonna have to replace the control.Sometimes getting a wash rag real hot and going over the buttons will help unstick them.
Jun 25, 2009 | Heating & Cooling
The hobart lxih is stuck in delime.
To reset or clear delime message, on control board there are 3 buttons. from power off, drawer open, manget on door switch, door closed, hold PROG on board and press the ON key on keyboard. pressing select moves to next poption, up arrow increases setting. step through select until you see delime, settings for LXi are de for disabled, and 1 through 65= x100 cycles. rg if set at 5, after 500 cycles the message apears. To keep the settings and clear the message a delime sequence needs to be run precisely as described.
DO NOT MIX DELIME ACID, RINSE AGENTS OR OTHER ACID WITH BLEACH PRODUCTS, OR HAZAEDOUS GASES WILL FORM.
With machine off, remove rack , close door, press and hold wash/delime key and press ON. Delime will be lit on display, release wash/delime key, and let machine fill. you should then see ADD and DELIME on the display, open the door and add the delime agent following supplier's instructions precisely. close the door, press wash, delime will flash. After delime is complete power is turned off. Inspect the machine and repeat if necessary.
DO NOT LEAVE THE ACID IN ANY LONGER THAN RECOMMEDED.
Jun 18, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Samsung washing machine F1245 control panel stuck??
I have Samsung/korea-SW905Washer.When power is switched on the Fault-'1E' appears. what could be the reason.( narrate list of control component failure).
Bought in the year 1996 at India ( voltas mega washer top loading-7.5kg) and working till last month.
after few wash cycles the machine stopped at aforesaid indication and it is not functioning due to above fault indication'1E'
provide me remedial measures or electronic control board circuit.
May 29, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
Normal wash cycle constantly blinking no other buttons responding dishwasher wont start
one of 3 things is happening, either your "start" button is not funtioning, the door latch is not operating, so the uint doesnt recognize the door closing there fore wont operate, or the "normal" button is "stuck"( electronic switch possible shorted)
the fact that you cant get any other function out of it leads me to believe that you have a stuck button/shorted keypad. this is not available as a seperate part and requires replacing the "console with active overlay"
Mar 03, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Will not reset stays only on normal wash can't cancel a wash
This model has problems with the two door closed switches. If they are not both working right, then the buttons on the panel will not work right either.
May 11, 2007 | GE GLD5800L Dishwasher
Dishwashers Logo
249 people viewed this question
Top Candy Dishwashers Experts
Charles T Nevin
Charles T Nevin
 Evgeniy_Getz
Evgeniy_Getz
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
