We have a Grundig GULCD42HDIV TV. We have just had Sky out to connect us to HD but the TV will not work in HD. It will show a picture but no sound is available when connected to the HD box
  • AliTinker Oct 29, 2010
    Thanks - I had tried your suggestions, but it turns out that the TV model was set to a lower (freguency?) of output than Sky actually now transmit at and we need to get an increased support panel - there is a panel on the side of the TV that takes a credit card size motherboard/frequesncy card - hope that makes sense!
  • 4,889 Answers
Did you try another HD port? I have seen that some HDMI ports are video only(DVI type). SO I strongly suggest that you try another port. Also the HD-box will have its own separate volume controls. So make sure its not muted or the volume is set to very low.
Posted on Oct 16, 2010
LG 37LC2D-EC
It sounds like the TV is having sync issues with your Sky+HD box. HDCP is the "High-bandwidth Digital Content Protection" that is used between components. It requires a sync between the devices to ensure that you are not trying to "steal" the video content you are watching. This intermittent message and blacking of the screen is good evidence that this is your problem.
Even though the HDMI cable worked fine on another set, I'd try a new one anyway. Some TVs and components are more sensitive than others, and a weakened cable may not show a problem on one set, yet show it on another.
Barring the new cable not working, check LG's website for a possible firmware update for your TV, and also try using a different video source, like BluRay and see you have the same problems.
Beyond that, it may just be an issue with the TV itself starting to die.
Sep 15, 2012 | LG 37LC2D Television
My sky remote wont operate the sound of my grundig 37fhd1080p tv is there a code that can help this
The code you have to input is 527. Press and hold select and red on the sky remote until the red light flashes twice, then input 527 and press select. Now try the volume control on the sky remote. Should work. Hope this helps.
Jan 12, 2011 | Grundig GU22DVDPX 22 in. LCD TV
Could you please tell me if my LC-32GA5E tv can work with sky HD.The manual tells about switching to hd mode,but there seems to be no where to connect hd to the set.The tv is about 5 years old. thanks...
This is an HD ready TV and can definitely be used with Sky HD, but ONLY if the Sky box is connected to the TV with an HDMI cable. It will not work if connected with a scart cable.
So you need 2 things. Firstly, you need to buy an HDMI cable (see picture) if you haven't already got one. Secondly you need to locate the HDMI sockets on your TV and Sky box. The sockets will have the HDMI logo (see picture) next to them.
Oct 16, 2010 | Sharp LC-32GA5U/LC-32GA5E 32 in. HD-Ready...
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
Bravia & Sky+HD, aspect problem
There is nothing wrong with you Sony Bravia TV and it suppport all HD and SD formats.
Are you viewing the HD version of the channel when it is showing a standard defination show. e.g SKY1 HD instead of SKY1.
This means that regular standard defination shows are in a 4:3 ratio and does not fill the whole screen. In order to view these type of shows you will need to tune to regular channel instead of the HD version.
You can check if a show is brocast in HD by going into the tv guide and checking for the HD symbol in the programme symposis.
Example
Apr 13, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No sound on hd tv thru freesat
HDMI to DVI adaptors do not always support audio.You have to run seperate audio into the TV.
Jan 12, 2009 | Televison & Video
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Probem getting sky to work with a new TV
An HD TV connects in the same way as a standard TV.
Connect a scart lead from the TV scart of the Sky box to the TV.
When you switch on the Sky box it should automatically switch the TV to the correct external input.
May 19, 2008 | Televison & Video
LG 42LC2D-EC NO SOUND ON HDMI
your setting for source of the audio is probably defaulted back to original setting in receiver. reassign audio input and problem may go away. it sounds like its not in the tv. i assume you have a receiver and are not trying to listen with speakers in tv. is this correct? if you are not using an amplifier, you may need to go to the tv menu to make sure the audio source is selected as the hdmi input. should take a bit to read thru the manual, but it ought to show you how to accomplish the correct settings.
let me know if it does not.
good luck
mark
Dec 22, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
