Question about Candy CPL321K Refrigerator
The rubber seal has been damaged (ripped) can I replace the door seal?
  • 4,793 Answers
Yes you can,if you google "candy fridge spares"you will find lots of suppliers.
Posted on Oct 16, 2010
Door seal leaks
Most commonly, the source of the leak comes from the door bellow (gray rubber seal). They do wear out with age and can develop small rips and tears. A routine inspection of the perimeter of the door seal can determine if you have any holes. If the seal is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If no obvious rips or tears are found, it is also common for the bellow to stretch over time and no longer provide a good seal around the door glass. Make sure you check to see if the bellow is sealing properly all the way around the perimeter of the door.
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, or require additional assistance, please post back and let me know. I hope you find this information helpful.
Apr 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The rubber seal on my LG WM2016CW has a rip on it and needs to be replaced. The door still seals but water runs out of it. Is there a name for this part or is it just called a rubber seal? How do I...
If the door is sealed water wont run out of the seal? A small rip does not mean it is failed...I am a bit confused but I can tell you that there are also seals in the pump and moter and discharge areas in the BOTTOM of the machine that can fail ... I would need more information to help you further...a reply would be appreciated
Feb 14, 2011 | Washing Machines
Maytag epic z-ripped piece of door seal
I would say that the rubber may have gone into the system, and is probably clogging up the water outlet hose, and or the Pump. This is a bit of a "Fix' it will require the taking off of the motor and Hoses, connected to see where that bit of rubber is.http://www.letsfixit.co.uk/html/washing_machine_faq.html
http://www.appliancerepair.net/apnet/frameset?http://www.appliancerepair.net/apnet/washer/toc.htm
If you do not choose to repair this yourself, using those links above. Then please get a "Quote" for repair.
Mar 24, 2010 | Maytag EPICz 3.7 cu. ft. Washer
BOSCH: How to replace rubber seal (boot) of front loading washer
remove soap draw take screw out lower right.
remove boottom panel screw in filter flap push to the right panel comes off undo 2 x screw,take front lip off door seal off 2 screw from door interlock then front panel will come off you will beable to whole seal and spring cilp
slightly longer but easy you can see what you are doing.
Jun 30, 2009 | Washing Machines
Water is leaking in the back on the drivers side
You may have a bad door seal strip. Check the rubber seal that goes around the door frame on the body and make sure it's first in place correctly, and secondly not torn, ripped or damaged. also make sure your window seals are good too. Good Luck
Dec 14, 2008 | 1999 Ford Explorer
Door seal replacement
This video will show you how to change a door seal on this Bosch classics 1200 WFL 2463GB/12 FD
Jul 24, 2008 | Washing Machines
Kenmore 110 45862404
noavatar_s.png marklfixit
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Replace the front bellow or front seal, as it may be called. It is an inner tube shaped rubber liner that seals between the front of the washer door and the front of the drum. The cost is about $35.00-$40.00 and you will need the kit as it includes the rubber spacers that are essential to doing the job. The job takes about 1 1/2 hours to complete. It is not hard, but it is dedious and requires some basic skills. Directions included in the kit are helpful.
Jan 24, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Maytag dishwasher mdb5000awa leaking
Well did you check to see if the door seal is ripped or not on tight??? The door seal is the rubber strip that is used to seal the door shut tight, if this is wrecked in any way that might the the answer to your solution?
Dec 20, 2007 | Dishwashers
Candy CPL321K Refrigerator Logo
81 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
