Question about Ovens
I have a relatively new (about 3 years old) Candy FNP 602 X UK oven. The fan works (so there is power) but there is no heat. Friends say the 'element' can be replaced, but I can't see where this would go - do you know where the housing is for the element? Thanks.
  • 7 Answers
SOURCE: Broken oven
First, verify it is the problem. (A working element has a conductive core, or wire, all the way through it). If the core wire is broken, it is defective. To verify it is broken, use an Ohmmeter - if value is above 500 Ohms the core is likely broken. Replace it.
To test without an Ohm meter, use a flashlight bulb and flashlight batteries, some wire and run the loop through the element. If bulb lights, core is ok.
If broken, take it in to any small appliance store as most oven elements are VERY similar. Likely they will have one in stock. They will be cheaper than over the internet.
Posted on Mar 25, 2008
barkencoa
  • 3463 Answers
SOURCE: Neff B1432 oven element and fan not working
If the element has failed again in such a short time , then I would suspect that the fan is the culprit.
If the fan is not working, then the element overheats, and burns itself out.
The fact that the fan spins freely, proves nothing, as the fan can be still faulty.
The only way to prove if the fan is faulty, is to remove the oven from the housing, and remove the rear outer panel of oven,.test with a meter set to ac mains and test the fan motor terminals to see if there is power there when oven is set to heat, disconnect the element first. ,if there is ,and the fan is not running then the motor is faulty..
If there is no voltage there, then problem is elsewhere, and you will have to investigate furher.
Plz rate my solution.
Thanks.
Posted on Jan 12, 2009
mastatech
  • 478 Answers
SOURCE: replace element in top of oven of an f241 candy cooker.
There should be two screws at the inside back of oven. However, once you have the new element look for the holes in the new one
Posted on Mar 20, 2009
barkencoa
  • 3463 Answers
SOURCE: Candy F254/3X single fan oven, grill works, oven doesn't.
If fan is working o/k, then you need to fit a new oven element
Please`rate my solution.
Thanks.
Posted on Aug 24, 2009
Testimonial: "Possibly looking for a bit more info. My manual talks about top and bottom elements. I take it the grill is the top element."
barkencoa
  • 3463 Answers
SOURCE: how do a change the element on a candy oven ,
You have to gain access to the element by removing the outer rear panel of oven, if it is built in, then this means removing it from the housing.
Once you have removed the cover, and possibly the top panel, you will see how the element is fitted.
It is a fairly straight forward repair to do.
Please rate my solution.
Thankyou.
Posted on Jan 25, 2010
Candy oven FL134 n uk will not heat up! (Since I had a power cut) The grill is working fine
I think that should be checked round heating element (RC) and change over switch (CO).
Dado
Feb 13, 2015 | Candy Ovens
HI I HAVE CANDY OVEN FDP299 231/1 THE BACK FAN HITS THE COVER IS THE FAN WORN OUT BECAUSE IT IS ONLY 3 YEARS OLD
I trust that you are talking about the fan forced fan hitting the safety cover. The clearances between the fan blade and the guard are normally small. Sometimes the heat can warp the fan or cover causing both to come into contact. If you are handy you can normally bend the cover or the fan back into place without too much effort.
Feb 09, 2011 | Candy Ovens
My candy fan oven has no heat when turned on
If the fan is working o/k, then it is going to be a faulty oven element, fitting a new one should solve the problem.
Mar 29, 2010 | Candy Ovens
My candy oven r43/3xuk wont switch on. The power
If the fan is working o/k then it is likely to be a faulty oven element if it is a
electrically heated oven.
If it were the timer, not even the fan would work.
Mar 28, 2010 | Ovens
CANDY OVEN
It will be the oven element that has failed, you need to fit a new one.
It is located at the rear of the oven compartment.
Feb 22, 2010 | Candy F248P Electric Single Oven
When i switch the oven on the oven trips the main circuit. the oven used to work normal then it started to trip out after it had been on for a long period. you could leeave it off for 10 mins then it would...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Feb 15, 2010 | Candy F248P Electric Single Oven
We have a Candy FNP 815 multi-function oven. we do not have a manual for it. every time electric goes off, we cannot get it going again. we try pushing buttons and nothing works, please help!! from a cook...
this will show you in the video
Candy Oven not heating? How to replace a Candy fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 31, 2010 | Candy Ovens
Oven not heating but fan working
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for candy element How to Repair Home Appliances
Jan 16, 2010 | Candy Ovens
Thanks.
Aug 24, 2009 | Candy F248P Electric Single Oven
Hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Thanks.
Jan 12, 2009 | Neff B1641 Single circotherm super...
Ovens Logo
258 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
