Question about HP Mini 1000 Netbook
Fan is noisy -loud wheezing sound.No dust. Banging on case sometimes stops the noise.
  • HP Master
  • 32,281 Answers
The fan has a noisy/worn bearing, I recommend replace the fan.
Banging the laptop base is not recommended, you could damage the hard disk.
Posted on Oct 16, 2010
LG fridge making loud noise
Bonjour,
jeepers are we talking about a wheeze, a clunk, a whirr, a buzz, a rattle, a hum, random modulated or cyclic, low or high frequency, persistent or intermittent? Or could you just be hearing fan noise.
If it sounds like tin pieces clinking against something metallic. The fan blades may be striking ice or frost or the shroud.
Could be a bad or worn fan motor bearing, or a defrost problem causing frost build up.
Just a FYI
Some LG models have been reported online as having many many operating issues.
Hope this helps
Jul 11, 2012 | LG Refrigerators
Desktop computer fan runs constantly
Desktop fans do run constantly, you cannot avoid this.
The reason they get loud is because there will be a build up of dust on the fan blades.
To rectify this problem turn off the computer and remove the power cord from the rear. Then you need to remove the side panel from the base unit to expose the motherboard.
You will see that inside the case it is full of dust. Look at the CPU fan (the fan on the motherboard) also take notice of any case fans too, they are at the back.
To clean the fans and the case you can use a clean dry paintbrush or compressed air.
Once the inside of the case is cleaned you will see a noticeable drop in noise.
Regards.
Jul 03, 2010 | HP Compaq Presario SR2150NX PC Desktop
My machine is making a loud banging noise
These are the things that cause my machine to make a "banging" sound:
The machines with the horizontal/drop-in bobbin sometimes collect lint in the bobbin case.
Sewing fabric backed with a synthetic/foam/vinyl or adhesive.
Wrong size needle for the type of fabric being sewn.
Mar 13, 2010 | Sewing Machines
The fan of dell gx280 producing a loud sound, how I fix it ?
Sometimes something is stuck in the grill and the blades keep touching it, other times the bearings have worn down and the fan or entire power supply needs replacing.  I used to hit my PCs noisy fan with the palm of my hand and the loud noise stopped!
Mar 11, 2010 | Dell OptiPlex GX280 PC Desktop
Makes a loud banging noise as if the load is underbalanced even through the load is balanced.
HI There
Try this even tho you said it's balanced. Sometimes it looks like but a slight unbalanced can cause this problem.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Let me know how this goes and thank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | Kenmore Washing Machines
Hi, we have a humming sound that is really loud,
Yes, its fan noise and you need to replace noisy fan.
Let me know exact model of your Sony TV and need to know what fan is producing noise to provide you part number and parts shop info to buy that fan.
Jul 31, 2009 | Sony Grand WEGA KF-50WE620 Television
GE side by side Refrigerator makes LOUD SQUEAK when running
Noise can come from these areas:
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Mar 24, 2009 | GE Refrigerators
Loud Banging Noise
if its a loud banging noise when the unit kicks off then broken spring in compressor will have to replace compressor check your 2-5th year warrenty in your owners manuel
May 14, 2008 | Hotpoint HTS18GBR
HP Mini 1000 Netbook Logo
385 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
