Question about Canon MV30i Mini DV Digital Camcorder
I cannot load any tape - there is tape slack.
    Genius:
  • 1,812 Answers
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Oct 18, 2010
C3210 error shows in sony dsr45 ap dvcam
C 3210 is means : LOAD direction loading motor timeout,
Main region how it happen are,
1.if there is moisture in ur TAPE or if ur tape had an slack tape during search And Video head is dirty.
Best is to clean head drum or disconnect the AC power cord.
After reconnecting it,
May 31, 2014 | Sony DSR-45 Mini DV VCR
Tape is playing back in fast forward only
It is possible the tape loaded on the wrong side of the drive. If you romove the tape, look for slack and tighten up, try it again or another tape. Otherwise it is likely that a spring for the pressure roller is off or broken. This is not easially repairable.
Oct 19, 2011 | Sony M-670V Handheld Cassette Voice...
Auto off Unloading Lock I do not achieve that my chamber(camera) panasonic dvx100 expels the tape
When the movement of mechanical position does not completed
to move unloading direction within regular time.
must remove cas. cover and if tape is not slacked apply 4 volts on loading motor connector and the cas. will go out.This problem is not repairable by not authorized personnel.
Oct 22, 2009 | Panasonic AG-DVX100 Mini DV Digital...
When a tape is stopped and ejection is engaged the slack in the tape jams in the rollers. I've tried a vcr cleaning tape and a spray of electronic aerosol. Nothing works. The machine is brand new....
The take-up reel should remove the slack from the tape. Try looking around that area for anything wrong. If it wasn't a new machine I would suggest a lot of things, but the only thing I can think of is either something got damaged in transit or a foreign object is in somewhere.
Sep 25, 2009 | Televison & Video
How does the vcr release the tape to be ejected?
When in play the tape is pulled out of the cassette & wrapped around a path that takes it across the heads using guide arms.When you press STOP/EJECT. the guide arms move back leaving the tape slack, at the same time a clutch device engages the take up spool & rotates to turn the spool in the cassette & wind the slack tape back into the cassette. When the arms are fully retracted a selector switch has moved into position to activate a motor which turns the mechanism to bring the cassette housing back up to the start position & relaeses the tape. If there is still tape catching the mechanism when you try to eject or some of the tape not fully back inside the cassette, this is most likely because the take up spool is not turning quickly enough to take up the slack tape.
Aug 19, 2009 | Symphonic Televison & Video
Tape End Sensor Error - UVW1800
these error codes point to possible problems with one or both reel motors.
Dec 11, 2008 | Sony Betacam SP Small Videocassette 30...
VCR Problem
your cassette may be too stuck & strong for the vcr to load. or check if the vcr set of driving & loading belts are not slack
Oct 12, 2008 | Samsung DVD-V1000 DVD Player/VCR
JVC HR-S9700EK
Hi, This is a common problem with some VHS units. The problem is that the tape does not fully extend over the video head and the slack sensor shuts the unit off. This involves the motor and driving mechanism that actuates the spreader arms that moves the tape. Usually this is caused by slippage of a small rubber belt. Though the repair work involve is relatively easy, removing the mechanism and replacing the belt would require that you be familiar with component placement and certain timing sequence of tape loading. Your best bet probably would be to seek the services of a qualified professional. Hope this be of some help/idea. post back how things are or should you need additional information. good luck and kind regards.
Sep 30, 2007 | JVC HR-S9500 S-VHS VCR
Tape Ejects Immediately
There are normally 2 causes. One is some obstruction in the tape path. Please open the cover of the VCR and shake and see for foriegn objects. Nothing??? Then there is one more possibility - Belts are loose.. Check the Tape Loading motor belt.Is it slack? This can happen over time.Change the belt.
Feb 04, 2007 | Panasonic NV-HD680 VCR
Tape is stuck in the machine, and I really need the tape!
sounds like vcr has dumped its eprom settings,you will have to bring it to sony dealer to have it repaired or you can manually remove tape by useing the loading motor and turning it by hand
Nov 17, 2006 | Sony SLV-SE730 VHS VCR
Canon MV30i Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
