Question about GoVideo VR2940 DVD Recorder/VCR
One touch copying
Can I perform the one-touch copying without the remote? When I try I get a message on the tv screen that says "No Signal, There is no live picture at the input. Please check connections"
I do have a good tape in and a blank DVD-RW.
Thanks, Jeff
Of course, press copy, the screen should ask what record speed, then press copy again. This should solve your problem.
Posted on Aug 12, 2008
My Durabrand dwt1304 was hooked up to cable. I now have relocated the TV into my workshop and am attempting to hook it up to a digital converter and an antenna. Turning the TV on, I am getting a...
I suggest to go back to the menu and make sure in the connection or signal type to select antenna.. Since you had it hooked up to cable it may not have been selected to go back to antenna. Hope this helps you out.
Feb 04, 2011 | Durabrand DWT1304 13" TV
Disable the Key counter on my Konica 7130
HI,
Please refer the manual by clicking on the below link.This will solve your problem.
http://help.nceas.ucsb.edu/images/2/2a/Konica.pdf
Oct 07, 2008 | Office Equipment & Supplies
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
Was watching recorded events, left the room and came back to a black screen, with no sound....tried unplugging dvr and back in with no luck...changed tvs still same result
christy39467,
When you had the black screen on your TV, did you have a banner on the top of the screen displaying the channel and information about the channel? If so, then unplugging the receiver from the electrical outlet for 10 seconds and plugging back in will resolve that issue.
If you had the black screen without the banner, it is a different issue. Please let me know if you had any other messages on your TV screen (No signal, weak signal, etc.).
Ray Calo
DISH Network
Nov 28, 2010 | DISH Network IR Remote Control
Remote does not send signal to tv
Gather up all the remote controls that you think are not working and a digital camera.Turn the digital camera on, all you need to do is look at is the digital screen while performing the process.No need for turning off all the lights (but may be helpful in seeing the IR signal).
Point the remote towards the lens of the camera as you would when pointing the remote towards the TV.Press and hold any button on the remote while viewing the screen on the camera. Note: some buttons may not transmit signals via default. Best button to try first is the power button.While holding the button on the remote and viewing the digital camera screen if you see a blueish light, that means the infrared signal is working properly, there is a problem with the direct connection (if its a universal remote, try setting it up, if its not, you're probably not pointing it correctly).
Sep 16, 2010 | Sony RM-Y167 Remote Control
Handshake problems. can't get TV on -- get no signal. talk w/ tech at logitech, they adjust timing, it works and the next day it doesn't work.
Need more info. It sounds like the TV is turning on with the remote and displaying a "no signal" status?
What devices/sources are you trying to watch?
Nov 24, 2009 | Logitech Harmony One Advanced Universal...
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
I get a "no signal" message when using HTMI or Component cables
on the remote, press "progessive" until you get a signal through hdmi to your tv
Jan 13, 2009 | Toshiba SD-K860 DVD Player
When i turn on y Vizio LCD TV theres a blue screen that says no
Your TV is probably in RGB mode which means its looking for a computer signal. Plug a computer into your TV and then it will stay on. Then you can change it back to TV mode.
Dec 24, 2008 | Vizio GV42L 42 in. LCD Television
Weak or no signal message
  1. Since my problem (Samsung/Comcast) began with a channel selection button pushed on the TV remote when it should have been pushed on the cable remote, I figured the problem lay with the TV.  Although I was getting the "weak or no signal" msg., the actual signal strength bar graphic showed it to be strong. Disconnecting did no good. I surmised that the TV was simply not recognizing the box.
  2. I looked at the manual for my Samsung 750 model.
  3. Page 20 discussed "Selecting the source". I accessed the TV menu and selected "Input", then chose the "HD..." item from the highlighted list. Voila! My tv works again.
Jun 08, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
GoVideo VR2940 DVD Recorder/VCR Logo
94 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
