Question about Canon PIXMA MP150 All-In-One InkJet Printer
My mp150 is showing to replace the waste ink absorber. I think its all about reseting the EPROM. Can i do it in home? Can it done by any sofrware?
  • 634 Answers
You have to replace the waste ink absorber means that you have to replace ink cartridge.
Follow bellow steps to replace it.
  • First of all you will need these things napkin,replacement ink absorber.
  • Move the cartridge cradle center of the printing unit.Unplug the printer so that it will remain in its position.
  • Locate the waste ink absorber in their black rubber frame.It will likely be on the right side of your printer and will be located underneath the area where the ink cartridges rest when your printer is in standby mode.
  • To soak up any excess ink that may be in the pads by pressing it down onto the top of the frame, use napkin for soak up.
  • Pull the rubber frame free from the printer and carefully remove ink absorber.
  • Insert a new ink absorber pad into the printer by same inverse method.Be careful to pulling and pushing.
  • Hold the power button of your printer until it resets.
  • Wait for green power button then press and release power button again. It should blink for two to three seconds.It indicates that your printer is now reseted.
Posted on Oct 16, 2010
Error 19
Hi there-
Below are a list of the error codes for this model.
E16-E19 = Failed to scan head alignment sheet.
You can find this information at http://www.usa.canon.com/cusa/home
CANON MP140, MP145, MP150, MP160 RESET ERROR CODES
[Info140] pixel_trans.gif RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Nov 29, 2013 | Canon PIXMA MP150 All-In-One InkJet...
Hi
Do you need to reset the counter in MP150?
Anyways remember that you need to repalce the absorbers also later. Follow the below procedure and you can start using the printer again.
PROCEDURE I. Enter Service Mode:
  • Plug in power cable
  • Hold down STOP/RESET button
  • Hold down POWER button
  • Release STOP/RESET
  • Press STOP/RESET twice in a row
II.Execute Waste Ink Counter Reset Operation:
  • Press STOP/RESET button 4 times (Indicator lamp will blink alternately Orange/Green each time the button is pressed)
  • Turn off the printer by pressing POWER button (wait until the printer is completely OFF)
When you turn on the printer,waste ink absorber full error is cleared and the printer work normally.
Original source: http://www.printerclinic.com/reset-waste-ink-counter-canon-pixma-mp150/#ixzz1SaAjTfWu
Jul 19, 2011 | Canon PIXMA MP150 All-In-One InkJet...
My canon pixma mp150 says error
How to clear Error Code Canon printers MP150 MP160
CANNON Printers
Unplug the printer for at least 2 minutes from the wall.
2. Plug the printer back in but leave the printer turned off.
3. Enter Service Mode
a. Hold Stop/Reset button and the Power button for 5 seconds
b. Release Stop/Reset button but continue to hold Power button
c. Press Stop/Reset twice
d. Release the Power Button
e. Wait for the light to stop flashing. The printer is now in service mode. The display may be blank or simply read "Canon" during this time.
4. Do an EPROM reset.
a. Press the Stop/Reset button 3 times.
b. Press the Power button twice. The printer will save the changes and then it will reboot. A little cd/dvd icon will appear in the LCD screen.
3. The printer will probably now require the same setting up as when you first unpacked it. That is, you will need to select a language and let the printer do a head alignment.
The printer is now enabled.
MP150/MP160 ERROR CODES:
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD over current error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 01, 2011 | Canon imageCLASS MF7480 Laser Printer
Sign showing Waste Ink Absorber is almost full. What should I do?
It means that your well used printer has reached the point that it needs maintenance: your printer waste ink pads and reservoir need to be removed and cleaned/replaced AND the internal counter reset.
It is 'officially' recommneded that you take your printer to Canon prnter service centre but I think that buying a new cheap printer would be a cheaper option!
You an also try to maintain and fix the problem your printer yourself: resetting the counter is 'relatively' simple (by going to the Service menu) BUT YOU MUST clean the waste ink pads and reservoir or RISK A MAJOR INK OVEFLOW DISASTER.
If you want to do it yourself, just Google for 'MP150 Waste ink counter' ....
Hope it helps!
Jan 07, 2011 | Canon PIXMA MP150 All-In-One InkJet...
My printer shows E 2 7. how can i fix it?
i believe on this model the error code means that the ink tank is full...
http://www.mediafire.com/?s2pa54m5z2wqwru
this is a link to my hosting site where you can download the software reset tool for a the MP models...
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
  • Start with printer on then run this software
  • Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
Additional information error codes for the MP models...
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E15 = Ink cartridge is not installed E16 – Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E29 = EEPROM error
E35 15 = USB Host VBUD overcurrent error – USB
Aug 07, 2010 | Canon PIXMA MP150 All-In-One InkJet...
What is waste ink obserber? How it will be replaced?
waste ink pad absorber is like a waste tank made of absorbent pads, in here the waste ink is absorbed. In time this waste ink pad will be saturated or full. When it happens the printer will suddenly stop working. The printer needs to be reset to function again and the waste ink pad replaced to prevent flooding of waste ink inside the printer. The waste ink pad is replaced by disassembling the printer.
Jan 17, 2010 | Canon PIXMA MP150 All-In-One InkJet...
The printer display shows the waste ink tank absorber is almost full.
INK ABSOBER
After replacement:
1. Reset the waste ink counter.
Adjustment / Settings,
Waste ink counter setting]
- EEPROM information
print
Oct 08, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error 8
Dear sir your problem is or E8 mean
Aug 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Ink absorber full
you have to reset the waste ink counter of the printer, for this download the software like IP tools, then reset it,
like it or not please rate it
Oct 09, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
157 people viewed this question
old marine
old marine
