CD ROM THE WIRES FROM THE POWER SUPPLY and motherboard are different. I am new ...
  • 44 Answers
Do you have a atx motherboard ?
Posted on Jun 03, 2008
My presario 900 wont start
Either the motherboard is "dead" or the power-supply is "dead".
It's easiest to FIRST try a different power-supply.
Jan 04, 2014 | Compaq Presario 900 /1500 Series EVO...
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Please describe your my drive is not reading any disk dvd and cd .
Secure that the power supply of your DVD/CD-ROM is connected. Then, if it still doesn't read, buy a new DVD/CD-ROM. Most of the times, it's just the power supply that is not properly connected to your ROM.
Dec 03, 2010 | Computers & Internet
Hoew to install CD Drive
You want to install a CD Drive. Ok you are Following these steps....
  1. Unplug the power cable from your power supply and open your Computer case.
  2. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays
  3. Before you install a CD-ROM, make sure you have the proper jumper settings. You are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up.
  4. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay.
  5. Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a SLAVE connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
  6. Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
  7. Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, go into your motherboards BIOS and search around for the IDE channels, they need to be set to automatically.
Thank U
Aug 28, 2009 | LG Computers & Internet
Looking for a Motherboard for a accr E650 had replace board still will not work emial at coffee59@telus.net
It is _NOT_ likely that the replacement motherboard is "bad".
So, borrow a power-supply from a friend, and see if your new motherboard works when powered by a different power-supply.
What "symptoms" are you observing?
Failing to POST (Power On Self Test) ?
Failing to boot from an official Microsoft Windows XP CD-ROM?
If you have more than one stick of RAM, try removing one.
Does that solve your problem?
May 18, 2009 | Acer Computers & Internet
Intel 845epi board not booting
Please go through the following option :
1) Check the master and slave jumper settings of hard disk and CD-ROM. Hard disk jumper setting should be Master and CD-ROM should be slave.
2) Check the cable of hard disk and CD-ROM.
3) Use different power supply which should be in good condition and than attach your hard disk and CD-ROM.
Mar 20, 2009 | Intel D845GVSR Motherboard
Minium load & EPS standard
You just need to make sure the power supply matches your motherboard is by Wattage, so that is all you have to be concerned about when buying a power supply..400Watts, 500Watts...The +12V, +5V, +3.3V is the power that your motherboard needs for itself and the hardware hooked up to it. Like the CD ROM has a plug to the power supply and it may use 12V. The motherboard also has a power connector and it may use +5V, etc. All you need to do is get the right wattage match for the motherboard, then use the correct wires to plug in the motherboard, CD-ROM, HardDrive, etc. The adapters are keyed so you should not have any problem figuring out which goes where, however, I would recommend writing it down if you can.
If you have any questions let me know.
Don't forget to rate this with 4 stars before you log out.
Jan 17, 2009 | Zippy 400W EPS POWER SUPPLY (HG26400P)...
Pc wont boot
Have you recently experienced a power surge or had an electrical (thunder) storm in your area? Potentially your motherboard and/or processor could be toast since the fan running and CD Rom drive opening will continue to function because they receive power separately from the motherboard via the power supply. If you have access to a different compatible processor, you could try to install it in the motherboard to rule out a motherboard failure, otherwise you're looking for a new motherboard.
Jan 12, 2008 | Computers & Internet
New install of msi mainboard, no display on monitar or cd rom work
reinstall ur motherboard and cheak properly that ur mbo dont touch with earthing ( cheak ur power supply proper earthing )
Jan 05, 2008 | Intel Motherboard
CD/DVD ROM disappears
I would think either your IDE cable is faulty or the IDE connector on the motherboard, try swapping cables or use a double IDE cable on IDE 1 connector. You may have a faulty drive ide connection input in which case a new DVD Rom is the answer, only cheap nowadays.
Nov 07, 2006 | Samsung (SC-140B) Internal 40x CD-ROM...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
