Question about Xantrex Technology Heart Xar 12 Alternator Regulater
How do I replace a motorcraft electronic regulator with this one.. wires on the motorcraft regulator marked I ' A' S ' F I am assuming "ignition" Alternator output ' Stator" Field"
Power window not working
First, do you have power to the switch? If not check fuse and wiring. If yes, is switch passing power to motor? If yes but no movement, replace motor.
Sep 30, 2014 | Motorcraft WLRA-4 Power Window Regulator
460 cu spark plug gap
On that big 7.5 liter engine, .042-.046 stock; if hotter cam go .046-.050 and make sure ignition is in good shape. preferrably aftermarket coil at least or ign box set up.
Aug 20, 2014 | Motorcraft 1990 Ford Bronco II Fuel...
Power window not working driver side 1995 monte carlo
First confirm power to the switch - check fuse & wiring. Is switch passing power to the motor? If so, replace motor, or at least try and get it moving...
Jul 27, 2014 | Motorcraft WLRA-4 Power Window Regulator
99 ford windstar driverwindow
Did you also replace the motor? If not, test operation of the motor when the switch is activated. Is the motor getting voltage when you activate the switch? If not, correct the bad wiring condition. If all parts are operating correctly but the window still does not go down, the window has become jammed in its track. (There are no other parts to the power window assembly.)
May 26, 2014 | Motorcraft Window Regulator for 99 1999...
How to replace a drivers side window regulator & motor
Not as complicated as it sounds. First you have to remove inside door handle, usually a couple of hidden screws. Then, you need a thin trim removal tool or stiff putty knife to slip under the edges of the inside door panel. As you slide it around the perimeter, you should run into a number of pop fasteners. Just twist your knife and they should release. Unplug your control switch and remove plastic vapour barrier to access ports in the door frame. Assuming window does not operate, you may have to fiddle around a bit to disengage the motor/regulator ... There is always a way. Assembly is just the reverse.
Mar 01, 2014 | WLRA-43 Power Window Regulator for 2007...
2001 f-250 brakes lites don't work. fuses good and installed new pedel switch still no brake lites
Could be as simple as bulbs died. Second I would check if lights have good grounding (these things tend to corrode over time. Usually black wire and have connection to vehicle's chassis). Or could be broken wire/shorted wire.
Nov 06, 2013 | Motorcraft 2001 Ford F-250 Super Duty Fuel...
P0190 diagnostic fuel rail pressure circuit a
What year , make , model and engine size ? You vehicle does not have a fuel pressure regulator . You vehicle has electronic returnless fuel system . There is a fuel pump driver module which controls the fuel pump with PWM .pulse width modulation.
Ford Electronic Returnless Fuel Systems Clip
P0190 Fuel Rail Pressure Sensor Circuit
Aug 29, 2017 | Ford Focus Cars & Trucks
I GOT A CODE P-0304 NOT FIRING change spark plugs and wires car ran for about therr weeks code can back car runs rough again what should I DO ?
What kind of plugs and wires did you put in? What engine do you have? If it's the V6, these engines are sensitive to the entire ignition system - use Motocraft only, and you shouldn't have any more problems, assuming there's no other problems anywhere. If you find you need an ignition coil block, do NOY use one of the cheal aftermarket replacements! Spend the bucks to get a Motorcraft.
Sep 29, 2010 | 2001 Ford Mustang
My truck starts then runs for around six minutes well missing and backfireing, then it shuts off and i cant get it started again for a couple hours. if i give it to much throutle it kills the motor also....
replace the TFI ignition module (mounted on the outside of the distributor) and the distruibutor pickup ( inside the distributor) and the problem will go away, I would also replace the coil if it is orignal.
here are the parts you need.
UNITED IGNITION WIRE Part # M425
w/ Push-on Type Rotor-Mod. Mounts On Dist; Electronic Ignition
$22.00
5645e51.jpg MOTORCRAFT Part # DU30C Distributor pick up $57.00
574e3e8.jpg STANDARD MOTOR PRODUCTS Part #FD478T Ign Coil $13.00
Aug 04, 2010 | 1987 Ford F 150
Xantrex Technology Heart Xar 12 Alternator Regulater Logo
138 people viewed this question
Top Xantrex Technology Boating Experts
Craig Butler
Craig Butler
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
