Question about Ricoh FT5832 Copier
Copyer what does the code sc104 mean
    New Friend:
  • 31 Answers
Once you watch inside look for esposure lamp continuity and terminals,thermal fuse,mirrors displaced,home sensor and white strip in cover glass, and u wanna may check supply power pack,this are the basics
Posted on Feb 14, 2015
  • 14 Answers
This is a very old machine but the code indicates an exposure problem. a sensor is not dectecting the exposure lamp comeing on when it should. This can only be solved with a service call. Possible optics board problem or a bad connection from the exposure area to tne circuit board. Remove the back of the machine an ensure all connections coming from the lamp area are plugged in. remove and reinsert the connectors. You might get lucky and that is all it is.
Dave t
Posted on Jun 15, 2008
Toshiba 207 -f14
Hold down the key's "0", "8" and start the copyer.
After that it will apper (AD) or (ADJ), tst "389" and press the start key.
Then turn off the copyer and turn it on again,that's it.
Jul 03, 2014 | Toshiba e-Studio 207 Copier
Minolta error disply on ( pc )
What code show in the display and what you do clearely describe
Aug 18, 2013 | Minolta Di152 Laser Printer
Can't get the top off the water container
Ray, we had the same problem. We ran the lid under hot water. We put the small towel attachment over the handle and used channel locks. It loosened gradually
Oct 14, 2011 | Euro-Pro Omega SC104 Steam Vacuum
My Copyer Has an error (H4)When the Electicity Voltag was Down The machin was on. I thing this is Copyer Problem. Please Help me
Peform the following procedure to enter the simulation mode and canceling the code ;-
"#" key ? Interrupt key ?"C" key ? Interrupt key ? 14 ? Start key
Dec 24, 2010 | Sharp AR-5320 Black and White Copier
Error F14 in my Toshiba e-studio 166
how to reset error code f14 in the toshiba e-studio 160
May 12, 2010 | Toshiba e-STUDIO166 Printer
I cleaned the toner of my coper machine and when i
Might want to get a new image unit. Did you recently replace the image unit. Did you use a vacuum cleaner to clean toner??? . (DO NOT USE A VACUUM CLEANER TO CLEAN TONER STATIC ELECTRICTY CAN DESTROY THE SENSOR UNDER the Image unit.
Try this site and get new image unit if available you have legacy Minolta machine.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Oct 30, 2009 | Minolta DiALTA Di250 All-In-One Laser...
I have pagepro 1300W poor quality copies
please your copyer couver is open and out of you in rcartriese out of copyer and clean air compres and check the fuzer light and punch roller and dram roller is also is currentluy ok and aply paper and start copyer.
Sep 15, 2009 | Minolta PagePro 1300W Laser Printer
I have a problem with code ''E000007-0000'' (canon IR2230)
A E-000007-000 means that the fixing film in the fixing unit can not find the "Home Postion" for the film. Most likely the fixing film is ripped and the film has proble moved to one side. Basicly you are going to have to have the film adjusted back to HP or the film needs to be replaced. Have you seen any little pieces of thin Black plastic come out of the copier, also is the toner not bring fixed into the paper.... Good Luck..... You may need to call in for reinforcements to solve the code... It will not clear till it is repaired
Apr 27, 2009 | Canon Office Equipment & Supplies
Error code C-0510
Code C-0510 means a low fuser temperature.
This can happen after a long copy job has been run.
To clear the code:
Power machine off
Turn on the machine with the stop key held down.
Turn off, then on again.
The code should be gone.
Apr 08, 2008 | Konica Minolta DiALTA Di183F Copier
Ricoh FT5832 Copier Logo
56 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
