Question about Durabrand DWT2704 TV
DEAD SET First no vert just a line in the screen,next morning turn on and dead set no line but just low a wheezing sound when i plug it up. cannot find a sam's on this set thanks in advance Jonesy82@cox.net
  • 4,234 Answers
Try addressing the vertical problem first. If the vertical IC has shorted, it can prevent the set from starting properly. That being said, it is also possible that there is a power supply problem (regulator) that was not providing the proper voltages for the vertical circuit. If that is the case, addition troubleshooting needs to be done with test equipment. Figure on a parts cost between $12-$25. Add in the local labor rate for the total repair cost.
Dan
Posted on Jun 03, 2008
Need to know where to set low power set up for amp thanks
There is no specific dead key setting for an ampifier. Each amplifier requires different dead key to operate at it peak effeciency AND to sound the best it can. If I knew what type of amp it was I could give you a better idea. Just for a reference point I will give you these numbers. For your basic amplifier ( 2 pill - 4 pill non high-drive) you could safely set the carrier at 1 - 3 watts. This is why the majic number for most people is a 2 watt dead key. For a High-Drive amplifier you really have a broad range of settings for deadkey. Generally anywhere between 2 - 8 watts. Some can even handle 10 watts. This DOES NOT mean that they need a HIGH dead key to operate properly. Just FYI, what you run into with improper dead key is either a really choppy, splattery, overmodulated sound with a deadkey that is to low, OR, a really pinched up, tight sound with a dead key that is to high. Also, a HIGH dead key can cause an amplifier to over heat, causing the transistors (pills) to fail prematurely.
To set your dead key "properly" you really should have a technician "match up" the radio with the amplifier. This means, he will hook up the radio and amp that you plan to use with one another in line and tune (set dead key) the radio to "match" the amp. This will give you the optimal audio and performance without overdriving the amp.
Hope this helped. Lost Jeep, Athens GA, 10-7 !!
Feb 17, 2011 | Connex 3300 240-Channels Base CB Radio
Need info wont turn on
the set will not operate with out proper vertical signal/deflection. you may have bridged pins together when resoldering. use a 25w or 35w soldering iron so as not to lift copper traces from pc board. always use solder wick to remove old solder and DO NOT keep on pad to long. mch
Feb 20, 2009 | Hitachi 36UX01S 36" TV
Sound but no picture, menu looks bowed/hourglass screen
This is a common problem on projection sets and if you have someone carefully resolder the pins of the convergence chips, it will probably solve your problem. If you continue to use the set, the amps will fail and leave a dead set condition. What needs to be done is to disconnect the power, remove rear cover, loosen all snug wiring making sure to mark any wires that you disconnect, remove screws holding chassis in and undo plastic hooks at front of chassis, access bottom of circuit boards and with low wattage soldering iron resolder convergence amps, reinstall chassis and rehook all plugs in original places especially ground wires and high voltage leads, and test. If the soldering iron is too powerful it will damage the chips, also, be sure each solder joint is clean and not touching the one next to it or you will fry circuitry. Hope this helps. Russmann.
Jan 28, 2009 | Mitsubishi VS-60703 60" Rear Projection...
Doesn't respond
Compaq MV 540 (old dog monitors) DEAD 100% DEAD.
OSD dead too. it seems.
built in year 2000, its 17 years old, and you fix things that old
why> why do that, used LCD can be had for 20 bucks.
why slave over any relic CRT like this,,, for a musiem??
using the VGA cable
the monitor will go to sleep, lacking any PC sync lines Vert/horz
by design per VESA rules on that !
step one , use a PC.
set the PC up to do the max resolution on the CRT
some PC cant do that, (new PC)
im reading your users guide now, 1sec, google , hit.
first force the PC to 1024x768 resolution and 60 vert. refresh max.
now the CRT can work an not any of above number higher .
see? use working monitor to do that FIRST.
now plug in the vga,cable last. on the monitor under test.
power led means
green = power ok
amber or yellow are sleep or standby.
so that means, there is no sync.
or if the OSD works (does it>) turn the silly sleep timer off in the monitor. via OSD .
the operators guide, tells you to go to PC safe mode.
this mode sets reso real low. 800x600 and all monitors work there.
no sleep timer inside monitor i can find.,
lots of ways for any CRT to fail even the CRT itself
(loss of sweep)
loss of cathode video drive
the VGA card inside, can fail. killing dead all cathod drive.
the power supplies or regs inside can fail.
the HV can fail. 10,000 volts (dont touch it if long life is good)
some survive, or fly back hit head on wall and crush skull,
seen it and done it so,,, there you go.(ripped gash in arm once)
the 2nd anode is very high voltage, avoid it, and win,.
respect it.
Sep 20, 2017 | Compaq MV 540 15" CRT Monitor
TV is DEAD without any prior symptoms
opening the tv you will see a fuse  it is surely open - you have to chenge with the same type and rating- pay attention to make this
just after did you disconnect the pewer cord from ac outlet- delfo
Mar 21, 2008 | Televison & Video
Hand set goes dead
Next time it goes dead, try wiggling the cord where it plugs in the handset and where it plugs into the phone. If the problem goes away, you will need a new cord.
Hope this helps, and if so, please rate my advice.
Feb 05, 2008 | RCA 25202RE3 Corded Phone
Power
if the tv set have no sound no picture, they call it dead set your tv need a repairman technician to trace your tv what was part was damage. but if your tv has standby mode mybe you entered the timer code.
Aug 20, 2007 | JVC AV-32D305 32" TV
My mobile set is dead
1-888-NOKIA-2U or http://www.nokiausa.com/A4433809 I would first check to see if its under warranty or if you have insurance on your mobile use it. sounds like its dead Mate. you really cant reformat or reset without turning it on, try powering it on while its plugged in the wall also.
Jul 30, 2007 | Nokia 1100
Vertical hold
You dont have enough vertical sweep!! Best thing to check is the vert output device and I think its an IC . BUT before that check the b+ going to that device and see if its low. I will run through a silicon diode right next to the ic. Measure both sides of the diode and if theres a big voltage drop then the diodes bad. Now also these sets are common for the b+ filter cap off thge flyback transformer. Its the voltage line that feeds that diode and the vert output section. Now measure all caps out of cucuit as most will measure good if you dont. Also just for giggles right nrxt to the big IC that has the vert ,horizontal video and sound drive there is if im not mistaking the vert parts start with c4-- or the ic will be ic4-- Its a small cap that will sayc4-- attached to nothing but the ground and one pin of the ic. I've seen this cap cause all sorts of vert problems in the past as its the vert waveshaper capacitor for the vert osc/drive. Good Luck
Apr 17, 2006 | Sharp 25VT-J100 TV
TV screen comes in and out when first turned on.
is the video going in and out or is the whole set with the sound going off as well. If the sound stays its a cold solder connection on the vert output device or the B+ line feeding the ic or if the whole set is going on or off its a cold solder connection on the Horizontal driver transformer. Without more info its hard to tell.
Apr 02, 2006 | Sony KV-32S65 32" TV
Televison & Video Logo
49 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
