Question about Dishwashers
Water is not draining away in my electrolux esl 624 dishwasher. Is it my filter and if so how do I clean please? Thanks
  • 44 Answers
Best off to call a certified repair company such as Sears.
Posted on Oct 16, 2010
Hi wont start. just making a loud whiring noise.
According to your description of the fault, something was blocking drain turbine of main motor. Dishwashers always first start drain water because calibration of water level inside dishwasher (empty). In your case, the main motor is same motor for washing and draining. Runing in one direction means washing, runing to oposite side means draining.
The solution is to open a turbine pump and remove all obstacles and visual check turbine impeller,ceramic seal and plastic sleeve on the motor shaft.
Dado
Mar 26, 2015 | Electrolux Dishwashers
Electrolux ESL 43010 does not get hot ,and the dishes are not clean any ideas?
Hi - If the unit is not drying nor cleaning properly, there are two main things to check first. Is the incoming water temperature at least 120F (49C)? If not, I strongly suggest that the temperature be adjusted on your water heater. Are you using rinse aid? Use a rinse agent to increase drying performance and using Sanitize or Air Dry Off mode also helps improve drying. If any proves to be ineffective, contact a professional to move forward accurately.
Oct 26, 2012 | Electrolux 23 in. ESL6114 Built-in...
My Dishwasher is not draining the water away, & the tap signal light is on?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 22, 2011 | Tecnik 18 in. TKD7000 Built-in Dishwasher
Does not drain
Hi
Daniel
Aug 21, 2011 | Electrolux Frigidaire Professional Series...
It washes the dishes but the water wont go away i have cleaned the filter and surrounding area but water wont go away any ideas please thanks
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 05, 2010 | Indesit Dishwashers
Dishwasher won't drain water. Cleaned out the
it has to be a clog in the drain hose or drain pump has a restriction in it. if the you here a hum but not draining probably the pump is still good but its blocked. let me know with a4 thumbs up post
Feb 27, 2010 | Electrolux Frigidaire Professional Series...
Water is left in the cavity beneath the base filter
water under the filter is normal. Most diswashers do not drain completley- this acts as an air lock to prvent odours coming thru the drain hose
Jun 29, 2009 | GE Nautilus 24" Built-in Dishwasher
Water not draining
PLEASE REMEMBER THAT THE MACHINE DOES LEAVE A LITTLE AMOUNT OF WATER BEHIND.AS LONG AS THE WATER IS NOT ABOVE THE FILTER MEANING THE MESH AT THE BOTTOM THERE IS NOTHING WRONG WITH THE MACHINE.GOODLUCK.MOHAMED
Sep 18, 2008 | Electrolux Frigidaire Professional Series...
Dishwasher not working properly
I have trouble with only the top not cleaning properly and have found blockages in the spinning jets at the top, may be worth checking
Mar 02, 2008 | Electrolux 23 in. ESL624 Built-in...
Dishwashers Logo
222 people viewed this question
Top Dishwashers Experts
