Question about LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive with Gigabit Ethernet & USB 2.0 Interface, 7200 rpm... IDE Hard Drive
Not turning on.... I turned it off to move its location and now i cant turn it on...Power cable and everything is in place and live, but no joy..
Same problem. Bought a new power supply at extortionate price from Lacie but still no joy. I'm hoping to find a way of converting to a dumb external USB HD.
Posted on Dec 02, 2010
Cant open my hard drive in my laptop
Locate the power cable and USB cable that came with your hard drive.
Connect cables to the appropriate locations on the back of the hard drive.
Sometimes a USB cable doubles as the power source, so you might not need a wall outlet to power the device.
Turn on your computer and allow your operating system time to load before continuing.
Plug the hard drive into the power outlet if necessary, but wait on powering up the device.
Connect the USB cable to the computer while the hard drive is in the "Off" position.
If the USB cable doubles as the power source, the device might turn itself on once connected.
Turn on the hard drive and wait until the hardware has been detected by the operating system. A message should pop up that lets you know new hardware has been detected.
Click on the "Start" menu and go to "My Computer."
Notice all your disk drives are listed in this window. The external hard drive should be visible, and holding the mouse cursor over the location will help you locate the correct drive.
Right click on the location of the drive, and move the cursor to "Open" or "Explore" and click.
Hope this helps
Sep 26, 2012 | Transcend StoreJet 25 Mobile 500GB USB 20...
How do i get my hp1200 printer to print, is on a off line mode
Hi Joy,
Disconnect the printer completely from the PC.Unplug its power cable too.
Reboot your PC.
Connect everything again from scratch but use a different USB port to connect to the PC.Make sure everything is well connected.Try printing now.Cant print?
Under printers and faxes,check whether 'work offline' is checked by right clicking on the printers icon and 'Uncheck.Still cant print?
Uninstall the printer driver on your PC,reboot the PC and install software again.If you don't have the installation disks,install from this Hp Support site making sure you select the driver that corresponds with your Operating System[Windows 7,Vista,Windows XP etc]
Hope this helps.Thanks!
Please rate this answer.
Dec 02, 2011 | Office Equipment & Supplies
It wont turn on the power works but i think the audio cord is broke idk i cant c a thing visually but the ps3 turns on fine
If you recently moved the PS3 to a different location or switched TV's you may need to hard reset the system due to the default settings not being in place.
otherwise its your HDMI cable. they tend to go bad rather frequently
Aug 21, 2011 | Sony Playstation 3 (PS3) Console
Cartridge error,refer to devise documentation to troubleshoot
Hello
Turn on the printer and open the cover where the ink cartridge is located. Remove the cartridge.
Place the ink cartridge back in the carriage. Close the cover. Turn the printer off for a minute.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, move on
Remove the cartridge and use a clean, lint-free, dry cloth to gently wipe the contacts.
Wipe from the top of the contact to the bottom. Do this for each contact.
Place the HP ink cartridge back in the carriage. Turn the printer off for a minute.
Turn on the HP printer, open the cover and remove both the black and color cartridge. Close the cover.
Remove the power cord from the outlet and disconnect the cables running to the computer and/or router. Wait one minute, and then plug in the power cord and then the cables.
Open the cover and install the black and color ink cartridges. Turn the printer on.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, you will need to buy new ink cartridges. Office Max or Wal-Mart have ink cartridges for almost every model of HP Deskjet, Photosmart and Officejet printers.
Jun 10, 2011 | HP Officejet 5610 All-In-One InkJet...
I dont know how to set up my xbox live with an eathernet cable can you help?
Hi there
Turn off the Xbox 360 by pressing the power button on the front of the console. Afterward, shut off your modem by unplugging its power cord.
  • 2 Insert one end of the Ethernet cable into the Ethernet port located at the back of your Xbox 360 console. After that, insert the other end of the cable into your modem.
  • 3 Replug the power cord into your modem to turn it back on. Once it is active, press the power button on your Xbox 360 to turn it on.
  • 4 Navigate to "My Xbox" then "System Settings." Afterwards, select "Network Settings" then "Test Xbox LIVE Connection." You will be notified on-screen if the connection is successful.
  • Read more: How to Set Up Xbox LIVE with an Ethernet Cable | eHow.com http://www.ehow.com/how_6714462_set-xbox-live-ethernet-cable.html#ixzz0xBK8Zctz
    GOODLUCK!!
    Aug 20, 2010 | Microsoft Xbox 360 Console
    Cant get on the internet
    The longer the cable, the slower the connection.
    It should work with the cable as it is not "too" long.
    I would try turning the modem and router off for one minute and then turning back on.
    Jennifer
    Dec 29, 2009 | Dell Dimension 2400 PC Desktop
    I have a 2001 206 gti and the engine just died
    hiya mate if you have got a live at the fuel pump when engine is turning over then your relay is working.
    you could possably have a fauly crank position sensor (which can be checked using a code reader) which would stop the engine from starting, also check the fuel pressure switch has not been activated (this is located on the n/s/f inner wing and is a small black unit with a red cap on it)
    it would also be a good idea to make sure the timing belt has not snapped.
    Sep 29, 2009 | Peugeot Liberte Cars & Trucks
    The power indication display is flashing with all colors visible.
    The flashing will come on if the chair is in neutral or if the charger is still plugged in when you turn it on. Place the chair in neutral (freewheel) by shifting the levers out, then place firmly back into drive.
    Unplug from the charger and it should fire up. Sometimes, the chair will also go into "sleep mode".
    Check your owners manual for this. Note, some have sleep mode potential but it's not in the manual, and if someone inadvertantly hits the right series of motions with the joystick, you can inadvertantly put it to sleep. Try turning the chair off, wait three seconds and power back up, then immediately press the "horn" button. This wakes up most of them. Others you need to power off, turn back on and then move the joystick forward, backward then forward again.
    Good luck
    Jun 23, 2009 | Electric Mobility Power Electric Scooter...
    Cant read wirring diagram
    as long as the steering lock no longer works you can leave the original switch where it is and mount your new switch in a convenient place. unplug the cables from under the steering column and extend them to your new switch. you should only have 4 cables there to go on your new switch. the battery cable is the one that is live all the time, a thick cable, the ignition is the one that makes the ignition lights come on when the key is turned, a thick cable, the accessory cable is the one that becomes live when turned to 1st position on key, a thinner cable, the starter cable is the one that goes to the starter motor when key turned to start a thick cable. hope this helps
    Apr 23, 2009 | 1986 Ford Ranger 2WD
    No power
    pull detergent drawer out place coin in large plastic screw under draw and turn.dont forget to turn back!..
    Apr 05, 2009 | Dyson Flowcheck CRO1 Front Load Washer
    Open Questions:
    See all LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive Questions
    LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive with Gigabit Ethernet & USB 2.0 Interface, 7200 rpm... IDE Hard Drive Logo
    149 people viewed this question
    Top LaCie Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
