Brand new Dell Vostro 430, in troublefree use for two weeks, sudden does not start up any more. After turning the Vostro on: - it shows the startup screen with the Dell-logo in the center, the intel logo at the right bottom, and the text "Vostro 430" above, and "BIOS 2.2.0" below the progress bar and the options F2 and F12 at the top right. - the progress bar fills up to a quarter, - the progress bar fills up to a third, - the progress bar fills up to half the bar, - then the screen goes black and show a blinking cursor on the top left cursor In this state the Vostro remains. Nothing more happens. No sounds form the Vostro other then the fan. The Vostro responds to almost nothing. It only responds to pressing Ctrl-Alt-Del. This makes it say "Entering powersave mode" and 5 seconds later it starts up again, ending up at the same black screen with cursor over again.
  • 4 more comments
  • tim9527 Oct 16, 2010
    I have also tried to turn it of, unhook the power cable, wait for the green led at the back of the Vostro to go out, wait for 15 seconds or so, hook up the power cable again and pressing the power-on button again. This has made no difference.
  • David Seilhan Oct 16, 2010
    Do you have the Operation Disc XP, Vista, Windows 7 witch ever one is installed on it?
    Yep. The OS is Windows 7. The disc is titled "Operating system" and subtitled "Reinstallation DVD Windows 7 Professional 32-bit". It also says: "Already installed on your system". What to do?
    I bought two almost identical Vostro's, so I have two of these disks. Can't tell the disks apart. Is that a problem. Probably not.
    Hm. I put in this Operation Disk and pressed Ctrl-Alt-Del, waited for the startupscreen with Dell-logo, pressed F12, selected CD/DVD as boot system and pressed enter. Same black screen with cursor appeared.
    I also have a disk called "Dell Resource Media" on which it says "You must boot your pc from this media to run diagnostics". Sounds helpfull. I will do that now.
    Selecting the boot device CD-DVD also does not make a difference when the diagnostics cd is in there. After selecting the boot-device and pressing enter, directly the same black screen with the blinking cursor appears. The boot options are "HDD:P0", "HDD:P1"", "CD-DVD", "USB: Dell ..", "USB: WDC...", "Pre-boot system assessment" and "Boot utility Partition". I have also tried all the others, one after the other. The result is the same for every choice: directly the black screen with the blinking cursor.
    n the f2-setup I tried several options without improvement:
    - at "CPU-configuraion" I disabled every option, so the CPU is used in the most simple operational status; no solution
    - Disabled "Quick boot", so it will not skipp any test; no solution
    - at "Integrated LAN controllers" I disabled everything; Hurray!!! I see my windows screen again. Can't use my keyboard anymore. Okay, reboot and F2 and switch on the USB-controllers. Solved.
    Strange: I can reboot and enable all LAN-controllers again and the Vostro keeps running fine. So no clear cause is to be found.
    Genius:
  • 1,584 Answers
Press DEL on startup and select "last best known config that worked" If that doesn't work you have probably corrupted the Win registry.Will need to take back to store, beware that if its a software fault you will have to pay and may lose all your data n the HDD!!!
Posted on Oct 16, 2010
Testimonial: "Luckily I had no corrupt windows registry and all my data is safe. Another solution (switching of several LAN-controllers) did the trick."
  • David Seilhan Oct 17, 2010
    My apologies for not getting back to your response. I glad cbacer was able to help you. I you have this problem again go to this sitehttp://www.sevenforums.com/tutorials/341...
Suddenly the internal Hitachi dvd drive, model no HL-DT-ST RD-RS BH30N, has stopped working. I get this under Device Status: "Windows cannot start this hardware device because its configuration inform
If you are a non-technical user then don't edit registry keys manually the best solution is to use the best registry cleaner that will also fix other registry errors. Use Intel Software Partner Reginout.
Dec 02, 2012 | Computers & Internet
How can i unblocked the applications or programs that already install on my laptop dell vostro 1014?
Try to click start then go to all programe or new promagram and it will show all new and old program then press right click on that program that you want and choose (show on desktop)
Nov 09, 2011 | Dell Vostro 1014 Notebook
Dell Vostro 3500 suddenly shut down, start up and works fine, after 2 minutes turn off without any warning message this happened after i installed bios upgrade A10 from dell.com
this is happening because of bios upgrade but not in a bad way. May be there is a hardware problem just starting so new bios upgrade is detecting that and thats why its restarting.
basically sudden shut down occurs in either cases- Fan not working or hard disk(or RAM) gone bad.
my advise is to contact dell customer support and they will guide you thru trouble shooting steps.
they will guide you if your warranty is not there.
Jan 02, 2011 | Dell VOSTRO 3500 Notebook
My Packard Bell (bought May 2010 new) laptop has a screen flicker problem. For the past week, every now and then the left half of the screen, or sometimes the bottom half of the screen, gets distorted with...
<font size="3"><i><span style="FONT-FAMILY: Arial; COLOR: #cb0101" lang="EN-US">4400mAh, 11.10V</span></i><span style="FONT-FAMILY: Arial; COLOR: #333333" lang="EN-US"> Dell Vostro 1710 Battery Replacement<span style="mso-spacerun: yes"> </span></span></font><span class="redfont1"><b><span style="FONT-FAMILY: Verdana; FONT-SIZE: 16.5pt; mso-bidi-font-family: Arial" lang="EN-US"><font color="#cb0101">$ 72.58</font></span></b></span><br /> <span style="FONT-FAMILY: Arial; COLOR: #333333" lang="EN-US"><font size="3">Dell Vostro 1710 Battery</font></span><br /> <span class="htmlval1"><span style="FONT-FAMILY: 'Courier New'" lang="EN-US"><font size="3"><font color="#0000ff">Discount Dell Vostro 1710 Battery 11.1V 4400mAh,fit for Dell Vostro 1710, Dell Vostro 1720 Laptops.Full 1-year warranty and 30-day money back!</font></font></span></span><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">ShippingArea:</span></b><b><span style="FONT-FAMILY: Verdana; COLOR: #cc0000; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">We ship all over the world!</span></b><b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US"></span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Brand :Dell Vostro 1710</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Type :Li-ion</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Voltage :11.10V</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Capacity : 4400mAh</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Ltem(Cell):6-cell</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Color :Black</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Dimension :270.90 x 50.00 x <st1:chmetcnv w:st="on" tcsc="0" numbertype="1" negative="False" hasspace="False" sourcevalue="20.2" unitname="mm">20.2mm</st1:chmetcnv></span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Weight :<st1:chmetcnv w:st="on" tcsc="0" numbertype="1" negative="False" hasspace="False" sourcevalue="665" unitname="g">665g</st1:chmetcnv></span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery SKU :DE017K</span></b><br /> <span lang="EN-US"><a href="http://www.battery-sale.net/dell-vostro-1710-battery.html">http://www.battery-sale.net/dell-vostro-1710-battery.html</a><span style="mso-spacerun: yes"> </span></span>
Aug 27, 2010 | Computers & Internet
Dell Vostro 430 - cannot play out sound from pc
Should have an audio card indeed. But if there are audio connections on the back it will definitely have an audio card installed.
Did you check the Device Manager to see if the audio drivers are installed?
In case you need to find drivers and can't find them on the Dell site, try driver finder, great program. Will also find the audio drivers on other sites if Dell does not have them.
May 14, 2010 | Dell Vostro 430 Desktop Computer (Intel...
Brand new Dell Vostro 220S won't power up
Depending where you are check that the voltage is correct , it should show 110 for US and 220 for EU and other countries
Ensure that the processor power cable is securely connected to the system
board power connector (see your Service Manual at support.dell.com).
•Ensure that the main power cable and the front panel cable are securely
connected to the system board connector (see your Service Manual at
support.dell.com).
Jan 07, 2010 | Dell Vostro 220S PC Desktop
Dell Vostro A860 Battery Charge problems  brand new laptop
If you system is brand new and the battery is not functioning properly, you need to contact Dell Techncial Support to get your issue resolved under the warranty. (800-624-9896)
Generally, and new portable system should run 2 to 4 hours (Depending on the capacity of the battery and what is beong done on the system) if you are not getting that performance out of the battery contact tech support.
Nov 13, 2009 | Dell Vostro A860 Notebook
I need driver dell vostro a840
Here's a link with someone having a similar problem and solving it.
http://www.techenclave.com/laptops/dell-vostro-a840-drivers-windows-xp-135785.html
See if that helps.
Jun 25, 2009 | Dell (430-3572) Wireless Adapter
Computers & Internet Logo
506 people viewed this question
David Payne
David Payne
