Question about SanDisk Sansa MP3 Player
I am not able to switch on my player.i have tried to reset it but that was not helpful.i have formatted it once it was not helpful too. so what should i do now.
May be it is its softwre or hardware problem, u better show it any wherre.....
Posted on Oct 16, 2010
My YO-U2R Mo3 player doesn't work. its not switch on. once i didi format. please answer
Try resetting the Mp3 player. You might a tiny hole on your player for reset, you can use office pin and reset. You can visit manufacturer's website and check on FAQ http://www.scribd.com/doc/62999/SAMSUNG-MP3-YPU2-MANUAL
You can also upgrade the firmware of the player from the manufacturer's website.
Aug 18, 2011 | Samsung YP-U2 MP3 Player
Tip
Sansa Mp3 player frozen? How to reset and format if needed.
To reset your Mp3 player.1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch.3. To turn the player on, slide the Power switch up then release instantly.
If that does not get your player working again, try and Format to clear any corrupt files that may be present.
You will lose all your music - sorry. Also try: 1. From the Main Menu, in the player -> select Settings -> Format.2. Select Yes.
You can also format using Media Player if you have unfrozen your player.1. ->start Media PlayerIf you have Media Player 10 --- Connect the player to the PC in MTP (See next step to change to MTP mode) .
1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC with the USB cable. once you have done that...
Click on the Sync tab.(be sure your player shows in the pull down menu)Click the pencil icon on the upper right corner of the window.Click OK to start formatting. Now if you have Media Player 11---Click the Sync tab.On the left panel, look for the device. It is usually the last device listed.Right-click on the device and select FormatClick OK to format.
on Jan 24, 2010 | Audio Players & Recorders
How do you reset a Mp3 player with 512 mb but it doesnt have a reset button?
To reset your Sansa Mp3 player. 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
You will lose all your music - sorry. For the Sansa Clip: 1. From the Main Menu, in the player -> select Settings -> Format. 2. Select Yes.
You can also format using Media Player if you have unfrozen your player. 1. ->start Media PlayerIf you have Media Player 10 --- Connect the Sansa player to the PC in MTP (See next step to change to MTP mode) .
Sep 17, 2010 | Audio Players & Recorders
Will not turn on
To reset your Sansa Mp3 player.1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. If that does not get your player working again, try and Format to clear any corrupt files that may be present. You will lose all your music - sorry. For the Sansa Clip: 1. From the Main Menu, in the player -> select Settings -> Format. 2. Select Yes. You can also format using Media Player if you have unfrozen your player.1. ->start Media PlayerIf you have Media Player 10 --- Connect the Sansa player to the PC in MTP (See next step to change to MTP mode) . 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC with the USB cable. once you have done that... Click on the Sync tab.(be sure your player shows in the pull down menu)Click the pencil icon on the upper right corner of the window.Click OK to start formatting. Now if you have Media Player 11---Click the Sync tab.On the left panel, look for the device. It is usually the last device listed.Right-click on the device and select FormatClick OK to format.
Apr 16, 2010 | SanDisk Sansa Fuze MP3 Player
It says that it has faild to load main image switch to recovery moad
try resetting the device first you should slide the Power switch up and hold it for approximately 20 seconds.
then. release the Power switch once the device is powered down.
Turn the device back on.
if that does not work then download and install sansa firmware updater from this link
http://kb.sandisk.com/app/answers/detail/a_id/156/kw/firmware/r_id/101834
if your problem is not solved after this then format your device.FORMATTING WILL ERASE ALL YOUR DATA SO ITS ADVICED TO BACK UP YOUR DATA BEFORE FORMATTING
From the Main Menu, select More > Settings/Options > System Settings > Format.
Mar 07, 2010 | SanDisk Sansa e260 MP3 Player
Bad tracks
To reset your Sansa Mp3 player.1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. If that does not get your player working again, try and Format to clear any corrupt files that may be present. You will lose all your music - sorry. For the Sansa Clip: From the Main Menu, in the player -> select Settings -> Format. Select Yes. You can also format using Media Player if you have unfrozen your player.1. ->start Media PlayerIf you have Media Player 10 --- Connect the Sansa player to the PC in MTP (See next step to change to MTP mode) . 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC with the USB cable. once you have done that... Click on the Sync tab.(be sure your player shows in the pull down menu)Click the pencil icon on the upper right corner of the window.Click OK to start formatting. Now if you have Media Player 11---Click the Sync tab.On the left panel, look for the device. It is usually the last device listed.Right-click on the device and select FormatClick OK to format.
Try my tip posted here -- > http://www.fixya.com/support/r4055689-download_mp3s_player <- copy this address into a new window.
Feb 14, 2010 | SanDisk Sansa e250 MP3 Player
WHENEVER I SWITCH ON AND TRY TO PLAY ANY MUSIC FILE IT SHUT DOWN.EVEN I FORMATTED IT ONCE
First reset yours by the Back button;
If not solved;
Reset again by the button, the On the Computer by Fat32 Format, and then Copy the Initial Files that were on your MD when you Bought;
Good luck
Nov 01, 2009 | Sony Network Walkman NW-E005 MP3 Player
Mp3 zen not recognised by firmware
I think I can help.  I had a similar issue where the recovery tool would recognize my mp3 but the firmware would not.  This is what I did:    Turn on your Zen, Holding the power switch in the on position. While holding the Power switch on (very important), Reset the Zen by inserting a small object in the Reset hole on the bottom of the Zen (I used an earring). You will see a menu: Clean Up, Format, Reload OS/Firmware, Reboot. I decided to go down the list until something worked.  I ran Clean Up first and that didn't work for me, so I tried Format.  Note that this will remove all of your data.
Once Format runs, Reboot the MP3 player and plug it up to the computer. Run MP3 Recovery Tool. At this point, the firmware recognized my MP3 and installed successfully. Once installed, my computer recognized my Zen.
Nov 21, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen freezes
This should help you right here: Detach the player from the PC and turn the unit off. Then slide the power switch towards the power icon and hold the switch. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove. Release the power button when the recovery mode appears. Select format (all) and select yes to format the player. After the player has finished formatting, select reboot. Then retransfer the tracks to the player as doing the format will erase the whole player.
Jul 24, 2008 | Creative Labs ZEN Vision:M Digital Media...
Sandisk sansa e200
I had this same problem on my sansa and tryed the previous solution with no luck. Out of frustration i email the sansa technical support. Try these steps to format the player: -Turn on the player and access MENU > SETTINGS > USB > MSC - Once the player is set to MSC mode, reconnect it to the computer and open the My Computer window. - Once you see the Sansa icon in the My Computer window, right-click it and choose FORMAT - In the Format window, choose FAT 32 and make sure that Quick Format is NOT selected, then choose START -Once the format has completed, disconnect the player from the computer to allow it to refresh. If you plan on using Windows Media Player to transfer files, return to the USB menu and set the player to MTP mode. Otherwise, leave the player in MSC mode and you can now resume transferring files. Formatting your player will deleate all files but you can putt them back on!!! Best of luck!
Apr 25, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa MP3 Player Logo
88 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
