Question about GoPro Digital Hero 3 Digital Camera
Stuck in tel mode gopro HD tried charging battery, plugging unplugging av/USB cord in diff. Combinations like the forums say no luck!
My hd hero camera is stuck on display tEL.....help
Posted on Dec 29, 2010
  • jorgeeeee Jan 06, 2011
    did you sorted it out yet? how??
F900lhd stuck on mass storage screen
If you have warranty, use it!
Otherwise, try connect and disconnect to a computer running any Windows...
Sep 27, 2014 | GoPro F900lhd Pro In Car Mobile Dash...
Camera will not turn on when i try charging is one red flash
You can not power the camera while plugged into a usb port on a computer, only using a wall plug or car lighter. Also when you insert a battery into a hero3 or 3+ black model you must wait 4 seconds before trying to turn it on or it wont turn on until you remove the battery and then reinsert it while waiting 4 seconds to try and power it up:
Need a night vision or flat lens for your gopro contour or drift hd cameras?
RageCams Will Price Match & offer better custom tailored installation kits with their lenses to fill the gaps & hold focus which is very important. We offer more HQ lenses / replacement parts & have serviced more gopro cameras than anyone on the net & at the highest quality service available. Scratched your gopro lens or damage your led readout screen? We can replace it for you quickly or offer you the parts to do it yourself. HD Wearable Video Custom Mods By RageCams
Feb 02, 2013 | GoPro HD Hero 3: Silver Edition Camera
Gopro charging problems flashing
GoPro battery dead. Won't charge in the camera. No charge light comes on when you connect the camera to a USB. There's the scenario. Good tip on the GoPro battery shocking technique posted by Rabscuttle above. I discovered that my vehicle USB cigarette lighter adapter drains the GoPro battery when it's turned off. With the GoPro battery completely dead, the camera will not charge it. If the GoPro battery voltage falls below a certain point, the camera's circuitry is set to turn off the internal charger as if there's no battery in the camera at all. The recommended solution is to buy an external charger, which is able to charge a completely dead battery. The battery shocking method saves that expense.
Connecting a 9 volt battery to the GoPro battery for 30 seconds can give the battery enough charge to allow the camera to recognize the battery. A 9 volt battery from a smoke detector, a pair of jumper leads, and two straight pins is what I used to get my GoPro battery charged enough to allow the camera to recognize the battery and begin charging.
battery_zps064fc8f6.jpg?t=1415296281
img_2564_zpse9e14b4e.jpg?t=1415296297
May 30, 2012 | GoPro Cameras
Gopro hero screen is blank and the red light stays on
May 25, 2012 | GoPro HD Motorsports HERO Camcorder
GoPro HD Hero repair power button???
Do you know A thing that there's inside some lighters, those lighters, I mean, it isn't a lighter stone, it's other kinda lighter, it's a lighter that you have to push the button and it gives a "shock" at the gas, and the fire come out, well, you need to disassemble that kinda lighter and get the thing that makes shock when you push it, and give a shock in your go pro by the usb, it works if you do correctly.
I have a broken gopro, and I just get the way to give shock and do it at the usb on gopro, and the gopro turns on!
Mar 08, 2012 | GoPro HD Motorsports HERO Camcorder
Stuck in video mode
I had the same. I plug it into the computer and unplugged it several times, took out the micro SD card. Finally it said "no SD" after a while. Pulled out battery and put back in then plugged into computer again, and back to normal it seems. Sorry this is not a step by step but I was just trying random things till it worked. Did not re-test to see if it is OK for the next recording session.
Feb 21, 2012 | GoPro HD Hero 960 Video Camera
My new gopro camera is not recognized by my mac when plugged in via usb...?
You need to push the POWER/MODE button once it is connected and the red charging light is on. It will then say "usb" and will show up on the desktop for you.
Feb 04, 2010 | GoPro Digital Hero 3 Digital Camera
Compaq Presario V2000 laptop stuck in hibernate or sleep mode. Power light, battery charge light and HD lights are all on, nothing on screen, no working sound of HD. I have unplugged/plugged, taken the...
Try booting into the BIOS Screen and resetting to factory defaults. If that fails suggest swapping the hard drive out and re-install the Operating System - Save your old data and migrate the data off the old drive. You can buy an external drive adapter to connect the harddrive to a USB port to migrate you data.
Good Luck!
Sep 09, 2009 | Compaq Presario 1275 Notebook
GoPro Digital Hero 3 Digital Camera Logo
2,739 people viewed this question
Top GoPro Cameras Experts
David Steeves
David Steeves
Level 1 Expert
abdul rauf
abdul rauf
Are you a GoPro Camera Expert? Answer questions, earn points and help others
