Question about Dualit 83350 Professional Work Top Blender
Can I unscrew the base of my blender to clean it properly
Why is it leaking all the time?
gasket is the most likely candidate. The gasket is either cracked, damaged or gone. If it is missing then it most likely fell off when cleaning. Unscrew the base and see if it is in there. It is also possible it is not seated properly.
Mar 07, 2016 | Cuisinart BFP-10 7-Speed Blender
I cant unscrew the bottom of the glass jar to clean it.
If u cannot unscrew it is a problem. People normally twist anti clockwise where as in the blenders to unscrew it is twisted clockwise.
Aug 11, 2014 | GE small appliance blenders 169106 User...
Krups blender switch lights, but motor doesn't turn
Hi I take it that the bottom was not screwed tight when the milk spilled. Try unscrewing the bottom, take it apart and clean it in warm water and mild washing liquid . Put it together again and screw tightly. And off it should go.
kolbrun
Mar 14, 2014 | Krups KB790 Blender
How do i get the bottom off the blender jar?
The best way that I've found to remove the bottom from the blender jar is to put the blender jar back on the blender base (make sure it locks in place) and then turn the jar to the right. You'll feel the jar detaching from the base. Once it's loosened up, remove from the base and finish turning the bottom, manually. Before I found this method, I had tried everything to get the plastic bottom detached from the jar. Without removing the bottom, there's no way to clean it properly and rather than be unsafe I'd need to throw the whole works in the trash. But the method I've described above works every time!
Aug 13, 2011 | Jenn-Air JBL800 Work Top Blender
How do i remove the blades to clean them ?
The base should unscrew from the jar. Take careful note of the order that the pieces come out, and replace them in the reverse order.
Best regards, --W/D--
Mar 06, 2011 | Oster 6808 10 Speed Blender
My blender base has become discoloured with a sort of green mouldy streaks, how do i clean
If you remove the blinder base where the blades are you can put it all in the dishwasher. To do this grab the handle on the pitcher then unscrew the plastic base from the glass. make sure that you look how it comes apart first. then put in the dishwasher to clean. Then reassemble the way you took apart.
Jan 11, 2011 | Oster 12-Speed Brushed Nickel Blender...
I have the blender and I'm not sure if I want to put it in the dishwasher. Is it dishwasher safe? If not, how do you appropriately clean it? It doesn't come apart easily. I just need to know how to clean...
We put the top part of aur bleander through the dishwasher all the time... no problems....just take it off of the base and unscrew the chopper from the jar...throw the little parts in the utensil cup and you are good to go...
heatman101
Aug 07, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
How to remove the jar base? In order to thorougly clean the jar you need access to remove the gasket, blade assembly, and jar base.
It just unscrews CCW. If it has never been romoved it may be quite a task to get it loose. Do not loose the rubber gasket in the process of cleaning it. You will never get another one without buying the whole assy.
Mar 10, 2010 | Blenders
Top part of base broke off
This just happened to me too, and I think I just fixed it.  First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99).  I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are.  Remove the rubber skirt to reveal four screws that hold the motor in.  They are way in there so you'll need a long screw driver.  Remove the motor and unscrew the old coupling.  Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck.  I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks.  If your blender is the same, remove the bottom nut, fan blade and two washers.  This gave enough of a rod to grip to get the old coupling off.  (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck!  Hope that helps!
Jan 09, 2008 | Oster 465 Work Top Blender
Dualit 83350 Professional Work Top Blender Logo
Top Dualit Blenders Experts
eyecam
Are you a Dualit Blender Expert? Answer questions, earn points and help others
