Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
So.. i appreciate the solution but i can't even get video to install drivers. i get nothing and i have no clue what to do since the mobo and processor are new, along with memory. also no post beeps
    President:
  • 2,351 Answers
Hi tmomonet, did you install you're PCI-E video card in the correct slot? Open you're manual to page 2-18. Once you have gone over that part of you're manual you will need to enter the bios to check some settings so you're video card boots with the system. (Please make sure you're PCI-E video card is installed fully into the PCI-E blue slot). (Some PCI-E cards also need extra power, if youre's does it will have a power connector on the rear of the card).
Once into the bios, open you're manual to page 4-20. Open PCIPnP. Than go to page 4-26. At the bottom of the page you will see, Primary Display Adapter. Change to PCI-E & not to PCI.
Save & exit the bios. You should gain video display. Once windows finishes loading, install your video card software.
Good Luck!
Mike
Posted on Jun 08, 2008
GPU hardware not recognised
Hello the homepage is here:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=583#dl
Try to download a manual if you don`t have it.
If any drivers for the mainboard is missing install them.
Install the newest NVIDIA graphic driver from here:
http://www.geforce.com/drivers/results/49949
This is the 64 bit version.
Check also if the graphic card is properly insertet
in the slot on the mainboard.
And the graphic card has to support PCI-E X16
This graphic card needs extenal power
from the power supply to work
the power supply has a wire with pci-e stamped in did you connect this ???.
Try to disable the onboard graphic in the device manager.
Good luck
Nov 15, 2012 | Biostar TZ75B ATX Intel Motherboard with...
Does apentium 2 processor support a tv card
Yes, for the most part. I ran a tv tunercard in my old 486.. But , you also need to keep in mind that the tuner card has to 1) Match an empty isa/pci/agp/pci-e slot on your mainboard. 2) Have drivers available for the operating system installed on your computer. 3)Have a tv signal available (cable, satellite OR antenna)
Please post again if you have more questions..
Regards
Apr 16, 2010 | IBM (02K2776) Pentium II, 350 MHz...
Upgrading the p4m900T-M2 mobo from P4 3.2Mhz to E8200 2.66Mhz
hello u must have the processor for your motherboard to work I mean the one that has been working .
with that smell of burning means the processor ur trying to ugrape was not suited for the board so pray that the motherboard is ok
have fune
bye
Sep 12, 2009 | EliteGroup P4M800PRO-M Motherboard
Turned off PC one night working fine. Next time try to use, PC wont boot. No video display, no bios, no posts, nothing. Gateway Desktop GT 5464 w/ integrated video, Intel E2140 Processor, Intel 945GC Mobo....
Have you tried booting it from yor CD drive with bootable software?
Any led flashing anywhere in the computer?
If not, we are talking about energy problem. Try fitting the energy cord firmly, try connecting the battery charger in a different power outlet.
Aug 26, 2009 | Intel Pentium Dual Core E2140 / 1.6 GHz...
MOBO DRIVERS
what is your m/board brand and model number?
Apr 24, 2008 | Biostar GF7050V-M7 nVIDIA GeFORCE 7050...
No power...? part.(2)
its very complicated maybe your motherboard is dead,, okey disconnect all power to hdd, cd rom, floppy.. then try to remove video card or if you have another video card install it.. If nothing happen again... I,m sorry
goodluck
Mar 14, 2008 | MSI P4MAM2-V Motherboard
New cpu but no video output
I SEE YOU MENTIONED NOTHING ABOUT INSTALLING ANY DRIVERS FOR THE HD'S DID YOU?
GOOD DAY
KZ
Feb 28, 2008 | Intel Motherboard
Boot error / No video out
Ajit,
The beeps are usually due to RAM or key board issues.
I would try by plugging it into a VGA socket of a monitor to see if it works.
Do you have heat problems? one suggestion is to try and reset the bios to default by moving the jumper on the mobo to do a hard reset.
good luck
Smeags.
Oct 23, 2007 | ASUS M2NPV-VM Motherboard
Not posting
Maybe a silly question to ask; but did you connect the processor power lead, as unlike some processors this needs a seperate supply.
Dec 18, 2006 | Mach Speed MK8-939A (VIPERMK8939A)...
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
67 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
