Question about Philips 105S61 (White) 15" CRT Monitor
I have installed windows 7, It is booting up and i could see only boot screen that three windows balls would come up. There after monitor says "attention frequency out of range Horizonal:53 hz and vertical 70hz" and displays nothing. System is booted as i could hear sounds and also working when booted with other monitor that was used while installing. Please help me.
  • 125 Answers
Install xp....becoz ur screen resolution is not for window 7
Posted on Oct 16, 2010
My Compaq Presario fall down and its screen gone colourless its not show anything normal when boot windows 7 it's colour goes red colour after booting showing very low quality colour....what I
Check the GPU and motherboard are OK by plugging an external monitor into the VGA socket and then booting. If the external screen is OK, replace the LCD screen.
Oct 09, 2014 | Computers & Internet
Tip
How to change boot screen in XP..???
1. First download and install Tuneup Utilities
2. Now click on Customize Windows -> Tuneup Styler
3. It'll open a new window. Click on "Boot Screen" link in left-side pane.
4. Now click on "Add -> Load Boot Screen From File..." option.
5. Select your boot screen file and click on "Install Boot Screen" button.
6. You can also create your own boot screens. To create new boot screen, click on "New Screen" button. It'll open a new window. Now click on "Search Local Drives" link and select the image.
You can also set the image alignment, borders, background color and progress bar position.
7. Once you finish, click on "Save boot screen" link and provide a name to your boot screen.
8. You can even see the preview of the boot screen by clicking on "Show large preview" link or by clicking on the image in Preview pane:
9. That's it, your new boot screen is ready. You can apply it by clicking on "Install Boot Screen" button.
on Jul 19, 2010 | Computers & Internet
I tried to clean the dell vostro 1014 fan, after i assembled the fan and turned on the laptop it appear black screen with dim image on my laptop screen, When I plug in external monitor it shows boot s
It sounsd like your GPU may be BGA chip and would require a re-flow/re-ball if your laptop shows graphical distortion on both monitors.
However I would first try taking the laptop apart again and double check you have connected everything properly.
Mar 20, 2014 | Dell Vostro 1014 Laptop Computer
Running bios/boot menu through external monitor
Even if you press F8 and use the boot menu, you will need to type the administrator password. The other alternative is to use a Win OS disc and reinstall from scratch using the COA number underside of your laptop.
Jan 18, 2014 | Computers & Internet
Compatible with MS Office 2013 and Windows 7
Go to safe mode and uninstall the application or restore system
Press f8 while booting up to get into safe mode...
Dec 21, 2013 | Dell E173FP 17" LCD Monitor
After post screen monitor goes into standby and cannot boot from dvd
Not picking up video card, or rather losing communications. Use VGA port if available on you card, and make sure monitor is set to same connection port.
Nov 11, 2012 | Computers & Internet
Window 7 every 20 minutes hang
Many things could be causing this, the first thing I would do is boot into safe mode and see if the issue continues.
Safe Mode
Just before the Windows 7 splash screen (black with windows logo) appears, press the F8 key to enterAdvanced Boot Options.
You should now see the Advanced Boot Options screen. If not, you may have missed the short window of opportunity to press F8 in the previous step and Windows 7 is probably now continuing to boot normally assuming it's able to. If this is the case, just restart your computer and try pressing F8 again.
Here you are presented with three variations of Windows 7 Safe Mode you may enter:
  • Safe Mode - This is the default option and is usually the best choice. This mode will load only the absolute minimum processes necessary to start Windows 7.
Mar 15, 2011 | Toshiba Satellite L305D-S5935 15.4-Inch...
Windows logon screen flashes for 6 minutes
After the 6 minutes, what happens? Does Windows finally load? Does it power OFF?
Let's assume Windows eventually does load. The problem wouldn't be the monitor, instead look at your boot devices. You "could" have a USB Flash drive installed on your computer and that may affect the boot process. Try removing any external USB drives from your computer and try booting again. If it does load quicker, you have to check the internal configuration / setup screens on your computer. There is a boot sequence or boot order sequence that needs to be altered.
Mar 09, 2011 | Acer AL1715 (Black, Silver) 17" LCD...
I m lookin for installing dual boot with Vista ultimate n Windows 7, gotta dvd for both, any help??
If you wan to fresh install, here you can do ::
Try following steps.
Restart the PC, Press Delete for some time
It will lead you to BIOS setting
Go to the Boot Priority menu,
select DVD ROM as First Boot and HDD as Second Boot
Now Insert your Operating system CD: Vista Ultimate
Restart the PC and when screen says " Press any key to continue"
hit "enter"
Let the CD load and then select New Installation
Format the drive by pressing L, and then create three partition , 100 GB for Vista Ultimate, 100 GB for Windows 7 and rest for data.
Hit enter and let os Load
After complete OS loading, system will restart and again you will see " Press any key to continue"
DO NOT PRESS ANY KEY.
OS will boot and register it with microsft. create login and then remove OS DVD,
Insert the Windows 7 DVD
restrt the system, Hit enter when it says " enter any key to continue"
select new installation, point to the earlier created partition for windows 7 installation
proceed with same procedure.
after complete installation, when you restart the pc, you will find both the BOOT entries at booting.
do not forget to load device drivers on both the OS.
Enjoy!
Sep 07, 2010 | Acer Aspire 5610-4648 Notebook
Computer won't boot when connected to DGM LCD monitor.
I have the same problem. Did you find a solution ?
Dec 28, 2009 | Computers & Internet
Philips 105S61 (White) 15" CRT Monitor Logo
85 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
