Question about Gigabyte mATX GF6100/NF405 PCI-E Motherboard
Cannot access BIOS
When I try to access BIOS(delete key) I get a screen saying "detecting arrays..." and then just sits there. I've cleared the CMOS(gave it overnight) to no avail. ECS technical support is worthless. Any ideas?
  • Anonymous Oct 12, 2008
    Exact same problem. The mother board is fine and works great but I have never been able to access the bios.
At first you pick up the battary in mother board & Checked the jumper settings for cleared the CMOS. then this board keep in land of 45 min without CPU.
Posted on Jun 03, 2008
Getting detecting array message
And what else? If the system just hangs at detecting it's expecting to find an array of hard drives attached to the system. Do you have an array that it can boot to? Does it load the OS finally? Was it working before? Did you make changes to the bios ro the array controller bios?
Nov 13, 2013 | Gateway GT4016 Desktop PC
G31-M7 TE keyboard problems
you have to run the DRIVERS CD FIRST.
Apr 11, 2013 | Biostar G31-M7 TE Motherboard
No keyboard promps will get me back into BIOS from the (CASE HAS BEEN OPENED) and alarm screen. How do I get round it?
usually the keys to enter the bios is f1,f2,f10,delete, and sometimes you must continuously press esc key and then you can access to bios by one of the keys listed above ,,, you can also reset the bios configurations by the clear jumper located on the motherboard (some model have a bios clear button instead of jumper ) or by removing the 2032 battery for 15 seconds ....
Mar 04, 2012 | Computers & Internet
MediaShield ROM BIOS 6.33 detecting array on the screen of an emachine pc
You need to be more clear than that. You say detecting an array? What kind of array? When does it say that? Do you mean you have an array of hard drives installed? If so, then so what?
Sep 25, 2011 | E-Machines eMachines Desktop PC
How do i access the BIOS of my pc? when my plug and play compatable sound system is connected to my onboard sound, the computer does not detect the device
You can access the BIOS by rebooting the computer. Upon bootup, press DEL button (you may want to press it several times). The BIOS or CMOS settings will appear. You may need to enable USB devices for your computer. Good luck!
Oct 25, 2009 | Audio Players & Recorders
Trying to create a server using the ASRock k7vt6 mobo
turns out the RAID enable in the bios is also used to enable the SATA. but this doesn't mean you have to use RAID to use SATA drives! there's a separate bios to configure the RAID that you can access after the initial boot screen by pressing tab. here, you can delete an existing array or create a new one. deleting the array makes the motherboard see both drives separately, like I wanted. problem solved :)
Aug 01, 2009 | Asrock K7VT6 (K7VT6 RAID) Motherboard
BIOS setting
To access the BIOS, reboot the computer and as soon as it starts to boot and shows the inital screen of your moterboard manufacturer press F2 or DELETE key. This key may vary as per the manuacturer of the motherboard.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 24, 2009 | Intel D945GCCR Motherboard
Bios how to clear
Hi mdgsc,
You don't need to clear the Bios, what you need to do is open the bios, by either the delete key, or F2 key, or when your computer reboots, it should tell you on the first screen what key to push to get into the Bios setup. Once your in there, look for Boot drives, and change your boot drive to first priority your CDROM dirve, so it will look first at your CDROM, prior to your hard drive. That message is because it's looking at the hard drive.
Give a try,
Good Luck and don't forget to leave a rating based on my solution.
Thanks Mark
Apr 09, 2009 | Compaq Computers & Internet
HELP! I can not access "setup" (by pressing the delete key). When I press the delete key it say, "entering setup", then shuts down. I have tried barebones, 1 stick of ram in each of the 4 slots, nothing...
Have you tried clearing the bios? there's a jumper in the motherboard that let's you erase all settings done in the bios and return it to its original state. Some motherboards even include a password erase jumper for the bios. Check your motherboard manual for the location. Just place the jumper in the clear position and return it back. Some motherboards may require you to turn on the pc while in the clear position and then turn them on again in the normal position to perform a through clearing.
If this isn't working you might be dealing with a corrupted bios... data on it might have got altered by a virus or some error. So now it doesn't work as it should.
If you can't boot your PC and enter windows or browse the internet, then you must work from another computer and download a bios image from the manufacturer web page and look for an alternate method of bios update that lets you update your bios from a floppy disk or maybe from a pendrive.
If you can access windows and the only problem is that you can't access bios, then do a bios update through windows directly, downloading the new bios image from the manufacturer's webpage.
Take note some motherboards won't boot up if there's a problem with the CPU fan, to protect the CPU from burning.
Jan 04, 2009 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Scanning array... forever
Is your BIOS set to boot from cd if it is not you have nothing on computer for it to do
Jul 30, 2008 | PC Chips PCChips A13G+ v3.0 Motherboard -...
Gigabyte mATX GF6100/NF405 PCI-E Motherboard Logo
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
