Question about Garden
I have a Husky/Kohler/ courage XT-7 Pressure washer. Water is coming out of the chemical injector with or without the motor running. With the trigger pulled it pulls through the injector release the trigger and it shoots back out the injector. What to do?
  • 5,138 Answers
You need to replace the seals,like little washer seals in hose.Look for them at Lowes ,sears,etc.
Posted on Nov 01, 2010
Husky 1800 Pressure Washer motor will not turn off when wand trigger is released
I think you have one of two things going on hear, an overpressure problem or a carburetor issue with the engine.
Jul 25, 2017 | Husky Garden
What is causing my pressure washer engine to stop hard/suddenly?
Your engine is experiencing a heat seizure... the piston sticking in the cylinder as it expands under heat with poor lubrication.
May 02, 2017 | Garden
No pressure on my husky power washer 1650
Basic Issues As an electric-powered washer, a circuit overload may cause your Husky 1600 to shut down or prevent it from starting. In this case, check your home's electrical service panel for a tripped breaker or a blown fuse -- the 1600 requires a dedicated circuit rated at a minimum of 15 amps. To prevent a blown fuse, avoid using other large devices on the same circuit as your washer. If you use an extension cord, it must be rated at 15 amps as well. Before moving on to more complex troubleshooting measures, check the gun safety trigger and release the lock if your 1600's trigger will not move. Water Woes Releasing air from the pump serves as a simple fix for low-pressure water output; remove the wand and allow the washer to run as you depress the gun's trigger until the water output normalizes. If your water output seems to lack detergent, ensure that the clear tube is securely connected to the detergent nozzle. Likewise, check the connected water supply and make sure the faucet is fully open and that there are no kinks in the hose to ensure optimal pressure. Using a shorter garden hose makes for stronger pressure, as well -- Husky recommends a hose with a maximum length of 50 feet for a city water supply. Clearing Clogs If your Husky 1600's pressure seems lacking or its water flow is obstructed, clean the nozzle by removing the wand from the gun, clearing the nozzle hole of obstructions with a stiff wire and flushing the nozzle with clean water. Similarly, clean the washer's inner water screen, located behind the garden hose connector, by removing the screen and flushing it with water. This also corrects low or irregular pressure and may remedy a unit that does not stop releasing water when the trigger is released. Model HD1600 features a chemical solution reservoir with a similar screen; clean this screen in the same fashion if you experience chemical intake issues. More to Consider If your power washer issues go beyond troubleshooting basics, contact Husky's customer service department at 800-381-0999. Husky recommends contacting customer service when your 1600 has problems with its pump, bypass valve, discharge valve or manifold assembly, for instance. Because this series of powerwashers was originally offered around 2001 through 2008, Husky's one-year limited warranty no longer covers the cost of replacement parts or repairs.
Sponsored Links
Sep 29, 2016 | Garden
Husky 2600 psi with Kohler Courage x7 173cc engine. Why does it leak gasoline?
Bad gas line, loose gas line clamp, cracked gas tank. Defective bowl to carb gasket.
Mar 26, 2016 | Garden
What is causing water to leak out of the resovior when the power washer is running?
I am assuming you mean the chemical resovoir tank? If water is running out of it then water is coming back up your chemical injector. This usually means at some point the ball and spring in your injector got stuck...typically people take them apart at the nipple to ry and fix it. not realizing there is a small ball and spring in that nipple. This is actually a ball valve to prevent water from coming out of the chemical injector nipple. Replace the ball and spring if needed as well as the oring seat in the nipple. This will stop your tank from filling up. Good luck
Sep 06, 2014 | Honda GCV160 5.5HP 2300PSI GAS-POWERED...
Gas leaking from carb when not in use.how to fix.
clean the float needle and check its not ridged where it seats ! if so replace !
May 27, 2014 | Kohler NET HP COURAGE XT-7 SERIES VERTICAL...
Honda 160 homelite pressure washer 2700 psi no pressure
Water comes out the nozzle, but low pressure? ( more than when the motor is not running)
I would check the check valves and the unloader.
If the amount of water coming out the nozzle is the same when the motor is running or not running.
Either the key that connects the motor shaft to the pump shaft is sheared, or the pump is trash.
No water comes out the nozzle would indicate a clogged inlet filter or blockage at the gun valve or nozzle.
May 05, 2014 | Homelite Pressure Washer. Honda 2700 psi...
Wont spray
I hope the engine wont spray... if it's a pressure washer thats not spraying the name of the unit would help... but does it build pressure but doesn't spray - check the wand
does it even build pressure ??? no - replace pump
Oct 18, 2013 | Kohler NET HP COURAGE XT-7 SERIES VERTICAL...
Husky HU 80522 pressure washer - some pressure to the spray gun. water coming from the pump goes straight to the sifon hose used for detergent. Can this line be clamped of if not used?
This unit has a Faip pump on the unit, no water should come out the chemical injector. The chemical injector can be closed off with no problem by installing a plug where the chemical injector hose bard is currently located.
You can also replace the chemical injector, here is a link to view the part.
www.allpartsinc.com/ProductDesc.aspx?code=KTRI91351
Mar 29, 2012 | Garden
Garden Logo
785 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
