What do you look for in a job? as an accountant executive
    Genius:
  • 1,218 Answers
What does this have to do with FAX machines.???
Posted on Oct 18, 2010
I have Kyocer KM-1650. i have employed someone and am not trusting the guy.i need steps to set up the job accounting passward.
Press System Menu / Counter.
Press down arrow and select Job Accounting by pressing Enter.
Enter Admin Pin Code - 1600
Press down arrow to Edit Job Accounting.
Press Enter.
Press down arrow to New Registration.
Enter pin code.
To Switch Job Accounting on:
Press down arrow to Accounting On/Off and press Enter.
Press down arrow to on and press Enter.
Press Reset. (Yellow Button)
ID Code Screen will appear.
Mar 22, 2017 | Kyocera Mita KM-1650 All-In-One Printer
HOW DO I PRINT A BROCHURE
You can put special media on side bypass feed tray. Then select paper type/thickness. Choose the bypass tray and paper type when sending print job from your PC. Job status light will blink and you need to go to the copier to execute the print job for special paper.
Sep 26, 2014 | Toshiba estudio 255 Copier
Corrupt administrator account
Create another account with full administrator privileges. Save and exit the configuration. Reboot and login on the new account you created. Execute a few programs. Reboot a few times, do different things to see if any problems develop. Once you are satisfied that the account is sane (not corrupted) , transfer your personal data files (from the old administrator account) to the new account. You can then delete the old administrator account.
Feb 07, 2014 | Toshiba Satellite P775-S7100 17.3" Laptop...
I start the machine and after 5 seconds give me the 116-324 error code
Thats called an exception error. One of 2 things. Either it needs a complete software upload, or the network control board, called the ESS board has failed.
You can try these steps
This step will delete any print or copy job that is in process, and then perform a reboot.
To execute: simultaneously press and hold the 1, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
This step will delete all pending print or copy jobs in the job queue, and then perform a reboot.
To execute: simultaneously press and hold the 6, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
This step will delete all pending print or copy jobs in the IOT job queue (DC 3535: does not delete any job data stored in the Network Controller), initializes the IOT HDD (refer to ADJ 9.8 for details), and will and then perform a reboot. All customer data on the HDD will be deleted.
To execute: simultaneously press and hold the 4, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
This routine will set all IOT ESS NVM values to default. Do not attempt this procedure unless there is a known-good Machine Settings floppy, an accurate Configuration Report and/or other data that will enable you to reload the correct NVM values for this machine.
This step will initialize the IOT ESS NVM (SYS-System and SYS-User) and then perform a reboot.
To execute: simultaneously press and hold the 3, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
The last one IOT ESS NVM will clear all your netrowk settings.
May 07, 2011 | Xerox WorkCentre M-24 Color Copier
Pls help me: xerox workcentre 24 code: 116-372
Ugh.. That is a formatter software issue. Try these resets
arrwup.gif Log Initialization
arrwup.gif Spool Initialization
arrwup.gif HDD Initialization
arrwup.gif ESS NVM Initialization caution.gif CAUTION
If these do not work the system software needs reloaded or the ESS network board needs to be replaced.
Mar 12, 2011 | Xerox WorkCentre M-24 Color Copier
I'm getting The job under execution exists. when I try to logon as admin on the copier
If there is an active job printing or copying when you try to logon, you will receive this error. Check the ;Jobs; tab and wait until the job is complete.
Nov 15, 2010 | NEC Office Equipment & Supplies
Need to print a report of past print jobs
If you have CentreWare IS you can do the following (taken from the manual):
You can find the manual link here: http://www.office.xerox.com/userdoc/P6250/6250_Web/pdfs/reference_guide.pdf
On page 97 of the manual it states:
Using Printer Management Features
Job Accounting
The printer stores information about print jobs in a log file. The log file is stored either in the
printer’s memory or on an optional hard disk if one is installed in the printer. If the log file is
stored in the printer’s memory, it is lost when the printer is reset. It is recommended that a hard
disk be used for job accounting.
The log file lists job records. Each record contains fields such as user name, job name, pages
printed, job times, and toner and ink used. Not all fields are supported by all printers. For
information go to CentreWare IS online help or CentreWare Web online help.
The job accounting values reported vary depending on the protocol and print command used
when each job was printed. For example, using NPRINT over NetWare provides the printer
with the most information about the job being printed. When using Windows and NetWare, the
job name is often LST: or LST:BANNER. Other jobs from other ports may provide less
information about the job.
Job accounting is available through CentreWare IS and CentreWare Web.
Using CentreWare IS
1. Launch your web browser.
2. Enter your printer's IP address in the browser’s Address field (http://xxx.xxx.xxx.xxx).
3. On the right side of the main CentreWare IS page, click Jobs.
The “Job Accounting Links” page provides links that enable you to browse, download, and
clear job accounting records.
For complete information on CentreWare IS job accounting, including clearing job
information, downloading job information to a file, and job accounting file formats, go to
CentreWare IS Online Help.
Hope this helps!
WizardRepair
Jul 17, 2009 | Xerox Phaser 6250DP Laser Printer
Code for blinking label in visual basic
follow this
http://www.pcmag.com/article2/0,2817,1951108,00.asp
Is the line executed? Did you start the Timer (calling start method or
setting enabled=true)? Do you execute other code while you expect the Timer
to tick? If you do, the Timer won't tick before the code has finished it's job. To solve it, execute the other code in another thread. This prevents the main thread that also keeps the Timer ticking, from being blocked by the other code.
Jan 29, 2009 | Microsoft Visual Basic 6.0 for PC
Printing seperate account totals from copier
Press System/menu counter
Scroll down to User/Job accounting
Press Enter
Scroll down to job account set
Press Enter
Scroll down to Account Report
Press Enter
Select Yes
The Job accounting report is printed.
May 23, 2008 | Kyocera CS-2050 Black and White Copier
23 people viewed this question
jasbo
jasbo
