Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby shampooer not sucking
Problem: the kirby shampooer is not sucking anything up. The tray is pretty much empty although the tank has been completely used up. I checked and made sure the belt was attatched, the filter in place. I don't think there are any leaks in the hose. ideas?
  • 357 Answers
Can I absorb water with the kirby without using the shampooer? Is there a way?
No you will suck water into the motor, you must use a shampooer tray.
Aug 12, 2017 | Kirby Vacuums
Shampooer does not distribute foam
It usually means you have no filter or a defective filter in your shampooer hose,or your not using kirby shampoo.
Dec 09, 2011 | Kirby G6 Bagged Upright Vacuum
What parts go to a Kirby Shampooer?
There is a shampooer head with shampooer brushroll, water tank, small hose that hooks to the tank, collection tray
Need to use the Kirby shampoo. It goes down as wet suds but you pick up the suds with the vacuum when it drys. Fill tank adding 1 cap full of soap (kirby soap only) per level on the side, this attaches on the side where the bag is attached
After using the shampooer you need to reattach the vacuum bag and main brushroll nozzle as though you were just vacuuming up dirt.
Instructions:
Lift the front of your kirby up (front part with light) open the handle on the dail in the front (if epquipt), remove the power head, put on height adjustment on highest level, turn dial on front of power head until you see 2 red arrows facing each other, unlock by turning knob, power head should come right off, get shampooer out the power head for shampooer with collection tray, make sure dial is set red on red, put on front of Kirby and lock in, turn dial to green on green arrows, fill tank adding 1 cap full of soap (Kirby soap only) per level on the side, this attaches on the side where the bag is attached, line up arrow and notch and turn, to hook up hose put Kirby down to lowest level, notched end of hose hooks in on tray other end on the tank,on/off switch refers to the foam, Turn machine on to lay the foam & scrub carpet, take shampooer back off to extract the foam once it's dry.
Good luck.
Aug 20, 2009 | Kirby G5 Bagged Upright Vacuum
There is no foam in the hose as I run the kirby shampooer. What could the problem be?
Check out the manual HERE.
It may be clogged valve on the solution tank.
Very dirty or clogged sponge (shampooer tank)
Very dirty or clogged screen(shampooer tank where hose is connected)
It is pretty common that that small screen comes out and stays in the hose elbow.
Rocky
Aug 15, 2009 | Kirby Ultimate G Bagged Upright Vacuum
My Kirby shampooer - G4 - hardly used any water from the tank and no suds at all. Pet hair did blow out of the small slotted holes in the tray as I moved the shampooer back and forth, but the carpet was...
Few things:
Make sure the sponge and the valve under the sponge (water tank) is clean.
Make sure you follow the instructions (f you do not have the manual you can find one HERE)
See if the straw inside the water tank is not clogged (happens when you use toilet tissue or some other paper to dry inside of the tank after you shampoo)
Noise - if it is noisy al the time - it may need new shampooer brush roll. Also check the tray - bar brush roll bearings overheat and melt the tray... Never submerse brush roll in water when cleaning it. Clean it simply by lifting the shampooer nozzle and letting it spin for 10-20 seconds. If you have tu put it under running water - put it back in the shampooer nozzle (with tray and shield) put on Kirby and turn it on for 20 seconds or so. If it stays soaken wet - moisture damages barings.
Good luck
Feb 28, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Sentria shampooer
HERE is the shampooer manual. There is no suction involved picking up the water. It simply scrubs the solution off the rug and throws it in the tray in front of the Kirby vacuum.
Jul 19, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Help with shamppoer for kirby g4
this site may be helpful
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
make sure the brushes on the shampooer head are spinning and that you have the shampooer head lowered all the way down to its lowest setting.
Jan 07, 2008 | Kirby G4 Bagged Upright Vacuum
Kirby Sentria
Your shampooer is not broken. (sorry Fanny)
You are missing a wee screen that fits on the hole where the little hose plugs into the tank. Check inside the hose end or down inside your shampooer box. Here's a link to my online Kirby shampooer instructions...
Hope I helped!
Marci
Nov 05, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Shampooer
View my shampooer use guide onling by clicking this link....pay special attantion to the part about the little suds screen that goes on the small hole in the tank where the hose connects.
Marci
Oct 12, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
251 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
