Question about Canon Office Equipment & Supplies
Canon LBP 2410 Lazer Colour Printer -
Our printer was working well but occassionaly a light black mudge 30mm wide would appear on a printed A4 sheet.
The unit is some 3 years old and a service tech, reported "it is not worth repairing".... It cost us some $900.00 3 years ago!!!
Advice or a recommended technician East of Melbourne would be appreciated.
Regards, Noel
  • 1 more comment
  • Noel Heather Jun 06, 2008
    Thank you for your advice... I have checked the fuser film - it appears to be OK for the area I can see and feel.
    When I turn the unit ON I receive this report:
    ""Printer error.
    Try to turn the printer on again after turning off the power and waiting 3 seconds. If a service error is displayed even with the printer turned off and then on again, turn off the printer and contact the service representative where you purchased the printer. When contacting the service representative, inform them of the error code displayed and symptoms.
    Error Code : E000""
    Does this help any further diagonsis??
    Noel (without-a-printer)
    PS
    I am unable to locate a Canon Service for LBP-2410 in the Melbourne East region; any suggestions please???
  • Noel Heather Jun 08, 2008
    Thank you for your excellent detail response.
    We appreciated you kind assistance.
    Warm regards,
    Noel Heather
    Thank you for your prompt response. The location you have indicated is the State Sales Office and is very close to us... I have a feeling that they do not carry out repairs there, however I will give them a try.
    Otherwise, the other local service centers you have indicated will be of assistance.
    Again, thank you for you helpful advice.
    Warm regards,
    Noel Heather
  • Canon Master
  • 19,396 Answers
Try this reset procedure, it is for a different model, if we find the right reset procedure for your model it can fix it.
Posted on Jun 07, 2008
  • Canon Master
  • 13,433 Answers
E000 - seems like a hardware side problem.
There should be a canon service centre in Melbourne - 33 lakeside drive burwood east.
  • 983 Answers
Printing not dark enough or varied in darkness
If the print is a dismal gray rather than a sharp black, you are probably almost out of toner. This can manifest itself evenly across the entire page or in splotches or stripes, depending on the printer.
Sometimes you can wring a little bit more out of a toner cartridge by taking it out and gently shaking it from side to side (never up and down, as toner can spill out). You can also try turning up the printer’s contrast adjustment, if it has such a knob (usually on the back side if it exists). Faded print can also result from a dirty corona wire, because a dirty wire inhibits a full electrical charge from being passed.
If the printouts are consistently varied in density, and you have to frequently remove the toner cartridge and shake it to redistribute the toner inside it, make sure the printer is sitting on an even, flat surface.
Horizontal black lines
A horizontal black line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem. Measure the distance between the errant black lines on the page and then use Table A to determine which part might be causing the problem. Table A
Distance between lines
Faulty part
0.5”
Registration assembly
1.5”
Upper registration roller
1.75”
Lower registration roller
2.0”
Toner cartridge developer roller
2.56”
Lower fusing assembly roller
3.16”
Upper fusing assembly roller
3.75”
Toner cartridge photo drum
Regularly spaced splotches
If there are evenly spaced black spots but they don’t extend all the way across the page, the problem is probably a scratch or flaw in the drum or a build-up of toner on the fusing roller. If the spots are less than three inches apart vertically, it’s probably the drum, because the drum has a larger diameter than the fusing roller.
Vertical black line on edge of page
This can indicate an almost empty or faulty toner cartridge or (less frequently) some spilled toner inside the printer.
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jun 07, 2008
    Now that you are familiar with the printing process, you can probably
    guess some of the common problems and their causes even before I explain
    them. The best way to determine the cause is to identify at what point in
    the process the printer is breaking down.
    Loose or smeared toner
    Here’s an easy one. If the toner is loose (that is, not fused to the
    paper), the fuser is not melting the toner, and thus the toner is not
    fusing with the paper. Make sure the fuser is heating; if not, replace it.
    Similarly, smeared toner happens because the nonstick coating on the
    fusing roller is scratched or has baked-on debris. You can try to clean it
    with a soft cloth and alcohol, but make sure you let it cool down first!
    Note
    In this
    article, I recommend replacing certain parts, but unless you are
    a technician working for an authorized service center for that
    type of printer, you might not be able to get the needed parts
    easily.
    Smeared output can also result when you refeed a printed page into the
    printer to make a double-sided page. This happens because the rubber
    rollers that grip the paper to pull it into the printer can pick up toner
    from the first side’s printing and smear it.
    Vertical
    white areas
    To fix this problem, clean the corona wires. Why? This problem is
    caused by either the main corona or the transfer corona being covered with
    toner in a certain spot. A quick fix is to change the toner cartridge,
    even if it isn’t empty. Because the primary corona is located in the
    cartridge, this will correct problems with a dirty primary corona.
    To clean corona wires, use a special felt-lined tool that comes with your
    printer or use an alcohol-dipped cotton swab. But be very careful! Corona
    wires are thin and easy to break with too much pressure. To locate the
    primary corona, remove the toner cartridge and look for an exposed wire.
    The transfer corona’s location depends on the printer, but it is usually
    protected with a webbing of filament threads. Not all laser printers allow
    you access to the transfer corona, so check your manual if you can’t
    find it.
    Gray mist
    If the white areas look like they have been lightly sprayed with a
    gray mist, making them look slightly dirty or dingy, the problem is also
    likely to be a dirty corona wire. (See the preceding section.)
    This can also be the result of turning the printer’s print density
    control up too high. The newer the drum, the lower this setting can be. As
    the drum ages, you must turn up the print density control higher to
    achieve sharp black printouts. However, if you turn it up too high, the
    entire page acquires a dirty gray tinge. Some printers include the drum in
    the toner cartridge, so you get a new one each time you change toner. On
    other printers, the drum is separate, and you must eventually replace it
    when it wears out.
How to use printer Canon LBP 5050N if one of the colour cartridge is empty
printers need all cartridges to work properly
replace the empty cartridge with a full one and proceed with the printing
Dec 31, 2015 | Canon LaserShot LBP5050N A4 Colour Laser ,...
I'm using half of A4 size paper and when I print my file on it, it takes 20 seconds after feeding the paper. Is there anything I can do to make it faster?
I fixed your capitalisation, punctuation and grammar. Half of an A4 sheet is an A5 sheet and should take half as long to print an A4 sheet. Print speed is dependent on a number of variables;
Density of colour, the more colour or more blocks of black take longer. Yours is monochrome and these are the specs. You should get 12 pages per minute. It may be that your computer is slow and also is low on available RAM memory. This is an old printer and you may think about upgrading. I had one of these 10 years ago.
Benefits
  • 12 ppm mono printing
  • Zero warm-up time from sleep mode
  • First Print Out Time in only 9.3 seconds
  • Up to 2400 x 600dpi print resolution
  • Energy efficient and quiet operation
  • Easy to use All-in-One cartridge
You should get 12 pages per minutes
Sep 16, 2015 | Canon LASER SHOT LBP-2900 Printer
My Canon lbp 2410 will print in black and white but not colour i have changed the drum cartridge and replace all colour toners Thanks Vicki
Check your printer settings in properties. It may be that the mono black only box is ticked. Untick the box for printing in colour.
May 19, 2011 | Canon LBP 2410 Laser Printer
Canon LBP 3300 printer A4 Paper is already loaded in Cassatt 1 but "Load custom paper in manual feed slot" massage shown when given print comment
these instructions r for win xp
go to printers and faxes select canon lbp3300, right click and select printing preferences set out put paper size as A4.
Apr 16, 2011 | Canon LASER SHOT LBP 3300 Printer
Canon lasershot lbp 2410- when it is colour to be printed nothing is printed, some faint yellow only but if set to monochrome it is OK-this printer has made BW 1100 and colour 890 prints. Please help me...
turn on/off, unplug, plug in2_bing.gif, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | Canon LBP 2410 Laser Printer
How to take self test page form Canon LBP-2410 printer
Go to printers and faxes, right click on the LBP-2410 go to properties at the bottom and you'll see the print test page on the General tab
May 06, 2009 | Canon LBP 2410 Laser Printer
Canon lbp 2410 windows test page only prints out windows logo in yellow no other colors
no idea how to fix this, I have the same problem!! Have reseated all the toners etc, and if I print in black and white, it prints fine - but when I switch to colour, the only thing that appears ont he page is the yellow corner of the windows logo.
Mar 11, 2009 | Canon LBP 2410 Laser Printer
Canon 2410 error E001
Go to "Additional Functions"
Hit # key
Clear All errors
Jun 10, 2008 | Canon LBP 2410 Laser Printer
250 people viewed this question
old marine
old marine
