2 months ago ive bought new charger...cause there was a fault with my previous one. It might also be a socket on laptop, so ive fixed both of it!but in the recent time,something went wrong...my charger started to blink,ive changed it again...the same result...Than advicer in near by shop said it might be battery...Ive changed it...Now claptop says computer plugged in,battery not charging and blue light still flashing!Help me please!What could it be!?Is it hardware?!
    Sergeant:
  • 235 Answers
Turn everything off. Take off the battery. Connect the ac adapter and turn on your computer. If it works with the ac adapter connected and your battery off then you have a defective battery.
If it does not work then it's either your ac adapter or your dc jack inside your computer. Try a different ac adapter at the store you bought the battery and you'll know if your adapter is bad. If it works with another adapter then exchange the adapter again (I know, I know, I've been there). If it does not work with another adapter then you're back to the dc jack but at least you'll know for sure.
Make sure that whoever is replacing the dc jack is good at soldering and replaces it not just solders the same one back on. Don't forget the shield to the dc jack. Good luck!
Posted on Oct 16, 2010
Why my Chargers are broken quickly?
I think your charger has bad quality because you have maintained it well. You can purchase a new charger from Mubuy.com. Good luck to you!
Jan 06, 2013 | Computers & Internet
My laptop doesnt charge propely
the charging port in the laptop is either loose or has a bad soilder on it.
Apr 22, 2012 | Fujitsu Siemens ESPRIMO MOBILE V5535...
My acer aspire 5738 charge only works when i toggle the charger head and if i move the laptop it stops charging, i bought the laptop second hand 2 months ago. thanks in advance for any advice given :-)
The DC jack, where you plug the power adapter cable, might be loose or defective, & needs to be either re-soldered or replaced.
In order to do this, the laptop needs to be disassembled & the motherboard taken out. Also, the motherboard needs to be checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Alternatively, the charger wire just next to the charger head might be damaged.
Some wire has frayed apart and is making intermittent contact with itself. This could be fixed by either replacing the charger with a new one, or replacing the charger head & the few centimeters of the wire connecting it to the charger & re-soldering a new charger head instead.
Apr 18, 2011 | Acer Aspire 5720-6661 Notebook PC
Hello, As i was working on, suddenly my laptop was shut down without any indications. and i tried to start it but it did not. after plugging in the battery charger it started. After that if i remove the...
Looks like you have a faulty battery, since you bought your laptop 4 months ago, I think it is still covered by their warranty. Please try to contact the manufacturer about the possible battery replacement. :)
Some of the things to do/check if the manufacturer requires you to return your laptop to them: 1. Backup all your important files to a different media/storage, like an external hard drive or burn them to blank DVD's
2. You can also tell them that it MIGHT be your charger that's faulty. Either way, they SHOULD check the battery and charger.
Nov 18, 2010 | Acer Computers & Internet
I have a netbook and ive had my netbook for a couple of months but now when i put my charger in i have to hold it at different angles for my netbook to charge whats wrong with it?
The laptop most likely has a faulty power socket, or the power socket needs resoldering onto the motherboard (ie a dry solder joint). To fix this fault the laptop need to be dismantled completely to get at the power socket to replace or resolder.
If the laptop is brand new then I suggest you get it repaired under warranty.
You can repair it yourself if you have the skills, if not then take it to your computer repair shop, I suggest you get a quote first.
Aug 26, 2010 | Acer Aspire One PC Notebook
Charger not working properly.
1st thing is to borrow a charger from a friend if they have 1 and if it works on then buy a new charger, if the fault continues then the DC jack will need to be replaced any reputible pc repair shop can do this for you
Dec 02, 2009 | Acer Aspire 5920-6727 Notebook
Samsung NC10 will not boot up
Take it back to the store and get the manufacturers to fix it.
Jun 13, 2009 | Samsung NC10-14GW Notebook
Dell Laptop Charger, wont charge bat. but keeps computer running.
Dell has cheap chargers, the wire snapped on the inside underneath the rubber. My ex boyfriends charger had the same thing happen. You need to buy a totally new charger .
Jan 21, 2009 | Dell Latitude D531 Laptop Computer PC...
Medion notebook under warranty less than a year old it was plugged in and charging yesterday when there was sparks coming from the charger slot, and a few sparks were released. This had given me a bit of...
Sounds like the charge socket is not properly seated on the motherboard. I would call customer service on where you bought the laptop and tell them the situation. But by all mean DO NO continue to use it. You may do damage that they say "Is your fault"
Trust me I have had clients that have "Been there .. done that"
Good luck
Nov 24, 2008 | Medion Computers & Internet
Computers & Internet Logo
David Payne
David Payne
