Question about Ryobi Garden
I have a Ryobi router ERT2100VK. It is quite new but dropped on floor . It worked for abot 20 seconds then dead. Any ideas on how to fix info@wekawood.com
  • 4 more comments
  • info99643 Oct 16, 2010
    Switch seems fine Any more ideas ?
  • info99643 Oct 19, 2010
    I already put it in the shop. You were right. Wish you had told me that the first time and I would have saved some bucks. Thanks.
  • 5,603 Answers
I would open it up and look for:
Broken wire
Damage brush or brush holder
Damaged trigger or wiring around it.
ALSO test the cord. Often when something falls the cord is yanked and a wire get broken inside or at attachment points. A multimeter set to read resistance is your friend.
Posted on Oct 16, 2010
  • 10,865 Answers
Hello. Chances are that the fall broke the switch. If you are handy you can do a continuity test to see if the switch is bad. If not, consider sending it into a ryobi repair center. http://www.ryobitools.com/support/service_center_locators
Click on the blue line to locate the ryobi center closest to you. Joe
Router dropping connection to start with , I would cycle the power and it would go back to working. Now it's stopped all together getting online.
if your broadband provider has no issues, try to reset the router through the reset button at its back for about 10 seconds. do this with the router disconnected from the computer and power. after that, with the computer turned off, reconnect the router and set it up again if you need specific settings and test the connection. you may also need to try using another cable to connect the router to your modem.
Mar 13, 2011 | Linksys Wireless-G WRT54G Router
Connect to network wirelessly with in 20 feet when go down to second floor network indicates no internet , but it can find router , run network trouble shooter but not much , dell has not helped ...
Hello
Signal is either too weak or something is causing it to drop out.You can try a reboot of the router.
If this doesnt work then you may need to get a wireless switch to pick up the signal from the first floor to the second.Which will need to be located in an open area like stairs.Metal decking and flouresent lights can cause the signal to drop.
Or you can buy a cable and hardwire it.Or a stronger router with a better signal.
Nov 02, 2010 | Dell Vostro 1014 Laptop Computer
Hi there.... doesnt work anymore...its totally dead... any idea what to do in this case? its brand new...used only abot 30-40 shots
take it back for warranty replacement, or give me the specific brand and moel number and I will try and help
Oct 25, 2010 | Air Tools & Compressors
We have a floor inverter, the timer display and power button keep flashing on the internal unit. Even after we have turned all the power off to it, no luck, Any ideas
Try to disconnect the battery for abot 15 seconds.
Check the battery voltage before and after disconnecting.
If no success after connecting back of a well charged battery, try to find the problem again with this information layed on.
Jul 16, 2010 | Fujitsu Electronics - Others
New Ryobi 18v lithium battery goes dead after a couple of seconds. Is there any solution other than returning it?
No, just return it, for the money they should give you one that works. It is common to get a defective Ryobi 18v lithium battery. I've had 2 out of 7 purchased that wouldn't hold a charge. But when you get a good one they work awesome!
Jan 24, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Dead ryobi 9.6 volt battery recharge?
email me i will send you the instructions ,,its easy and it works ,,,to pfcatering@optusnet.com.au cheers peter
Apr 10, 2009 | Ryobi Multi-Volt Battery Charger
Can a bad ryobi 18 drill ruin a new 18volt ryobi battery
If the drill has a short in it, then yes, it could short the battery out. Probably in the trigger switch.
Jan 24, 2009 | Ryobi Multi-Volt Battery Charger
Linksys N router drops signal
Its not dropping you because of the spectrums, it works on line of sight. If you are in a basement and your router is upstairs it has to go thru a floor and the strength is weakened. Go into your router and increase the signal strength. But you have to mod your firmware.
http://www.coderetard.com/2008/05/30/install-dd-wrt-firmware-on-linksys-wrt150n-wrt160n-wireless-routers/
Here is a link to update your firmware.
Jan 24, 2009 | Linksys Wireless-N WRT150N Router
Garden Logo
135 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
